Hello all,
I've been reading the different posts for the past weeks on what to use to polish and wax my car and would like any advice you can offer to help me on my following process.
I'm purchasing the PC 7424 set with pads from autogeek for $179. My set has only the LC orange pad 6.5", white pad , and grey pad. Is it necessary to buy the XMT polishing pad conditioner? I would think all you need is enough product on the pad to freely move the PC. Can I lightly mist the pad with water?
I recently brought a car, 2006 Mercury Montego black color, that sat on the dealership's lot for 8 months and has a lot of swirls from dealership washes. Those swirls and long sratches on every inch of the car are really annoying to look at in the bright sun, especially in black.
This would be my process when I receive the PC in a couple of days. Can you look at my process and answer any of the questions you think I should correct to obtain the swirl free look and the shine of a wet bright mirror reflection look:
Thick Microfiber Chenille orange wash mitt (Vroom brand)
Gold Class Wash (should had brought NXT wash)
Scrub rims and tire with Eagle one tire and wheel cleaner.
Dry car with microfiber towel from Sams Club (25 pk for $11). I rubbed the MF hard onto the CD and it did not scratch the CD disk.
Clay bar from Mother's and lube (1/2 of the bar left over from 3 years ago)
Will Meguiars #83 or #21 stain plastic trim of the car? Would any of you use blue painters tape for #83 or #21 ?
-- 1st, I'll use Meguiar's #83 Dual-Action Cleaner/Polish with LC Orange cutting pad at speed 5 in a 2 foot x 2 foot working section.
I heard that it may gum up quickly. I will buff off by hand with a soft Cobra Microfiber Towel.
When should I use the white polishing pad?
I did not purchase #9 SMR because I assume #83 will remove all of the swirls.
If the light swirls are still on the car, should I use the #83 with the white pad?
Or should I use the #83 or #21 with a white pad or gray pad?
I read on autogeek that #21 can eliminate fine swirls and scratches. Does #21 use fillers?
-- 2nd, hoping that all of the swirls are removed from #83, I will apply #21 Synthetic Sealant with gray pad at speed 3 to 4.
Can I spread the #21 over the whole car and can I start removing it all at one time with the white pad?
Or should I remove the #21 by hand with the Cobra MF?
I would apply a 2nd coat in an hour or Should I wait for it to cure and apply another 2nd coat 24 hours later? I hope to get 3 to 4 months lasting protection from this sealant.
And If I'm not satisfy with the shine, should I apply #26 for the bright look?
I don't want the dark black look but the wet bright mirror look from the black.
I heard that NXT Tech paste wax has cleaning properties and may dull the look.
Or can I use NXT Tech paste instead of #26.
Can I use #21 on the clearcoat aluminum wheels because I heard it helps repel alot of the brake dust release from this car ?
Lastly , Am I doing too much work to remove the swirl or should I do something else to shorting the time to remove swirls and wax the car. In need of advice. Thank you.
