Never tried it myself but from reading here is what I have learned.
Glass is very hard, much harder than paint. Standard pads and polishes that work wonders on paint do little to nothing on glass.
Cerium Oxide (CeO2) is an abrasive used in the glass industry to polish glass and is needed to have any impact on your windshield. Even using this abrasive it takes a lot of polishing to make a difference. I believe it is the abrasive ingredient in the polishes included in the kit. If not, you can easily find cerium oxide powder on the web.
I've seen one person say this kit does not work while another says it does? That makes no sense until you notice a difference:
Whatever you try be sure to post the results, success or failure, so we can learn from your experience.
- The "not work" fellow polished for about 2 - 3 minutes per section and gave up
- The "works well" fellow polished 30 minutes (or more) per section. A couple hours for the entire windshield
