Backing plates & pads...simplified?
OH_TL_81
Hey folks,
Been checking out this page for the past week and am amazed with all the knowledge accumulated in one central spot.
I've got an 06 Acura TL that I have applied the following:
-Duragloss car wash
-Meg's NXT Liquid Wax (Realize NOW all the alternatives out there)
-Duragloss AW
I have PC 7424 and am looking to acquire a new backing plate and pads...I have searched and read for hours...and hopefully someone can shed some light on the following
-Backing plate: 5" or 6"? Do 6.5" pads fit 5" BP's? Are different brands (Sonus, LC) compatible with different BP's?...any thoughts?
-What does the "DA" (Dual Action) reference to some product lines refer to? Usually the pads are thicker, but why?
-And of course, the very generic? what combinations do you recommend w/out breaking the bank?
Any help is appreciated?
Since the pads are basically velcro, I would assume a 5" backing plate would be fine with a 6.5" buffing pad...you just wouldn't have as much area "backed" which may or may not be an issue.
The DA refers to the path the pad travels. A rotary polisher/sander simply spins the disc in a circle...like when you balance and spin a dinner plate on a stick.
The DA polishers/sanders spin the disc and also moves the center rotation point in a circle. Think of it as you're spinning the dinner plate on the stick but you're also moving the hand holding the stick in a circular motion.
This dual action (wood sanders call it random orbit) helps to prevent the sanding/polishing action being concentrated in one location and therefore helps to create a smoother, burn free finish.
Pads marked with DA simple refer to pads intended to be used with the DA polisher.
