New to the board here, just hoping to share what I saw yesterday when trying out these three products. The surface used was my GN (black of course) which had a fresh paint job about 2 years ago. From washing and dusting, the car naturally gets micro-scratches and some swirl marks and just a bit of a haze or dullness that isn't really noticable until you really stare in florescent lighting.
Anyway, the car is clean but I wiped an area down with quick detailer to make sure. I then rubbed a section with 3M SMR and remembered why I put the stuff on the shelf for a while! The area was much cloudier and swirly than before I used it. Then, over the same area I used the 3M Hand Glaze and, wow, it was night and day, not only did it remove what the SMR did, but it vastly improved the finish compared to the untouched areas surrounding it. I put some Pinnacle Souveran over that spot and it slickened it up a bit but really didn't change the overall shine.
Then on an area next to this, I used some Meguiars cleaner/wax (NOTE - this is the stuff in the red bottle, the $4.99 stuff, I see they also have some in a different bottle also 16 oz, also called cleaner/wax, but it is $10 or so). I was horrified. The haze and swirling was worse than the 3M SMR. Hand Glaze to the rescue again. After the Glaze the area shined like the one next to it. I put the Souveran on that spot and again, it couldn't even improve on the shine.
Should I steer clear of the SMR and cleaner/wax or are they doing their intended puporse (especially the SMR) and you are then EXPECTED to go over the car again with a polish/glaze to finish what the previous product started?
