Polishes that dust quite a fair bit
buja
Read from a couple of forums that Optimum Polish can be added to other polishes to cut down on the polishing.
while I've read that people have had experience of doing so with mernzerna,
what about the other polishes that are also well known for dusting nightmares, like the ssr 2.5 ?
I have the ssr 2.5 and instead of chucking it out, i should try and use it up... maybe i should get the optimum polish just for the sake of reducing its dusting problem.
not that I will be using optimum polish on its own, as I am using the g220/udm, which will take ages....
wonder if i can use poli seal instead ?
or another alternative might be meguiars #80 , #93 (cant remember which is the stronger one)
heard it's quite oily in nature, and i'm wondering if it will be good to add a drop just to keep the ssr2.5 working longer n less dusting perhaps ?
but on its own, how are #80 and #83 ??? worth considering ?
any opinions ?
anyone tried mixing ssr 2.5 with optimum polish on the pad ?
could it reduce the dusting a little and also make working with ssr 2.5 a bit longer and stronger ?
