The 7424 says to "Use 5 inch Pad Only". Can I use 6.5in pads? What are the cons of doing so or not getting a 6" backing plate?
It`s the matter of the counter weight. People have changed it to use the 6" BP and others have not. From my understanding it`s a matter of vibration.
I purchased the 7336 (it`s the same machine but w/ a CW for a 6" BP).
"J"
The only thing that I have noticed using 5 in. backing plate on a larger pad will provide excessive wear on the pads from the topside if pressure is applied. I use a six inch backing plate on my PC all the time. I also use 7.5 inch pads a lot. Mostly because I use my rotary from time to time.
icic.
Which 6" backing plate should I use? What about this
Porter-Cable Backing Pads, Polishing Pads & Counterweights
or these
Hook And Loop Backing Plates feature Velcro brand hook & loop fasteners to hold foam pads in place. lake country backing plate, lake country foam
If I get the 6" backing plate, do I need a counter weight as well?
like cw , I use a 5" counterweight , a six inch backing plate and 7.5" pads ...not much vibration vs the 6" counterweight (have used them side by side) and i use the VC pads that have a hard and molded backing so there has been no wear in over 4 years of use
Wait, confused myself here. Does the PC 7424 not come with a backing plate at all? I know it comes with the 5" counter weight...
I got from a local person, brand new though. I`m guessing not, since I see nothing that looks like one lol.
Also,
Saw this on the AG site
# The Flexible Backing Plate LC-43-125DA measures 5 Inches in Diameter and is perfect for pads up to 7.5”.
# The Flexible Backing Plate LC-43-148DA measures 6 Inches in Diameter and is perfect for pads 7.5" up to 8.5”.
So should I get the 5" BP? I`m going to be using 6.5" pads...Confusing
I use a 6" BP w/ 6-1/2" pads. I personally like the flexible BP.
You just don`t want the BP to beyond the edges of the pad.
"J"
Can I use the 6" flexible BP Dual-Action Hook & Loop Flexible Backing Plate 6" for Meguairs pads? Or would I need to get the Meguairs BPhttp://www.autodetailingsolutions.com/FlexibleDABackingPlate.htm
Pretty sure you can use the Dual-Action Hook & Loop Flexible Backing Plate 6" with the meg`s pads
Edit: It says this on the main page
All of our Flexible Dual Action Backing Plates offer these outstanding features:
# VELCRO® brand hook & loop fasteners molded into the polyurethane to prevent separation while polishing
Does that mean it supports velcro type pads?
Some people prefer the 5 inch backing plate with 5 or 5.5 inch pads as they seem to correct a bit better than the larger 6.5 inch pads with a 6 inch backing plate.
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
