Go Back   Autopia.org > REGIONAL FORUMS > United Kingdom
Old 12-28-05, 06:13   #1 (permalink)
hutchingsp is offline
Polisher other than a PC?
As subject really. Is there any "middle ground" between doing the car by hand and spending £170 or so on a Porter-Cable?
I can't justify spending that sort of money, but I'm unsure how good or bad these orbital polishers you see at Argos and Halfords are.
cheers,
Paul
Paul
Old 12-28-05, 09:48   #2 (permalink)
Lowejackson's Avatar
Lowejackson is offline
You could always buy a rotary for less than £100 but it wont be as safe to use as a PC. My biggest regret with the PC was delaying buying one for nearly two years.
They are occasionally sold on the Meguairs UK site (second hand)
Old 12-28-05, 10:11   #3 (permalink)
I was looking at something like this - http://www.motor-world.co.uk/outdoor...p?prod_id=4120
I thought random orbit meant safer as the pad varies rather than just spinning on a single axis?
Paul
Old 12-28-05, 10:12   #4 (permalink)
Shiny Lil Detlr's Avatar
Shiny Lil Detlr is offline
Contact: Send a message via AIM to Shiny Lil Detlr
cheers,
Paul
The cheap orbitals you are referring to will most definitely be too weak to do much good. They're great/fine for applying LSPs, but there's no way you can correct defects with it adequately. By comparison with the PC, they aren't worth the money, IMO.
Old 12-28-05, 10:15   #5 (permalink)
buzzb is offline
Hi Paul- I've read excellent things about the DeWalt DW443. You might want to do a search and see what you think. I don't know if it's cheaper for you though. Hope that helps!
Old 12-28-05, 12:58   #6 (permalink)
Yes, a random orbital buffer is safer compared to a rotary. The motor-world unit looks like a useful tool for applying wax but little else but I could be wrong as I cannot find any published data on it.
Maybe it is worth buying a rotary and trying it on a bonnet from a scrap yard. My understanding is that as long as you keep the speed below 1000rpm and use a normal polishing pad you are less likely to get into trouble. I have not tried a rotary but there is a huge amount of detail here on techniques etc for using one.
As for a PC, it has not only made the polishing process a lot quicker, it also took the shine level up by a large margin. A PC is not a cost, it is an investment
Old 12-28-05, 01:58   #7 (permalink)
Richt's Avatar
Richt is offline
Like Steven I delayed getting a PC for a long time and now think WHY!!!!! It will pay for itself in no time at all IMO - just in time saving and results. It is a inital outlay, but if it is too much to strech to now I would put aside the money you are prepared to spend on a UK alternative for now and add a bit each month till you have the PC funds, you wont regret it.
Old 12-29-05, 02:07   #8 (permalink)
It's not the money itself, it's whether I can justify one. I'm also wondering if there are alternatives to importing, buying transformers etc.
I'm not suggesting they aren't good, but Autopia is 99% a US userbase so it's going to focus on products available in the US - I'm wondering if there aren't UK products available that are just as good but simply don't get the exposure/coverage as, other than bodyshops, most people over here wash their car on a Sunday once a month if that, IYSWIM?
Paul
Paul
Old 12-29-05, 06:33   #9 (permalink)
Paul
As far as I've ever read, there are no tools that would be a direct comparison to the PC; though I've heard of similar tools like the Rotex (don't recall what model number -- you may want to search) that are native to Europe. If there are any stores that are equivalent to Home Depot or a tool vendor, you may just want to stop in and see what they've got in an orbital/random-orbital/dual-action sanding/polishing tool. Even if it isn't advertised as a polisher, if you can adapt a backing plate to it you probably could use it for polishing.
Old 12-29-05, 07:56   #10 (permalink)
Master Detailer
chpsk8's Avatar
chpsk8 is offline
Are there any bodyshop supply places in the UK that you could consult. I'm sure they use something that would be equivilant. Or maybe a detail shop thats local could give you an idea or two. I forgot about the power conversion. Running a PC there sounds like a pain, there's got to be a better solution for you folks ni the UK.
Old 12-29-05, 08:06   #11 (permalink)
Master Detailer
chpsk8's Avatar
chpsk8 is offline
How about something like this...
Rotary Polisher
70 "quid" including VAT. Might be something to start with. I started with an old Black and Decker rotary before moving to a PC. Rotaries are fine if you use your noodle and dont' sit in one spot. For the money it's worth a shot.
Do you have access to air? You might be able to find a DA air polisher. IF you can find a good one you can dial in the RPM pretty easily. The problem with air is having to wait for the compressor to catch up. Air DA's use a load of air so if you have a typical 5 gallon tank you'll be lucky to finish a panel before waitting for the air to catch up. Scratch the air idea... sounds worse the more I type!
Old 12-29-05, 08:07   #12 (permalink)
riggsyUK's Avatar
riggsyUK is offline
Ive just got a smartool make by AutoSmart.. seems ok but aint given it a whirl yet..
will be using it over weekend when my pads arrive..
SMARTOOL
[IMG] code is Off
