Jump to content
Fact or Myth - Conflicting Info- Rubber Care and Silicon
  • Please log in to reply
39 replies to this topic
#1 auburnryan
auburnryan
    Registered User
  • Members
  • PipPip
  • 19 posts
Posted 07 May 2008 - 09:29 AM
So I bought into the school of thought on NOT using Silicon product on tires etc. a few years back.
I still see some info (very littel factual info) on detrimental effects of silicon based products on rubber online...
I also see conflicting info that silicon based products (like di-electric silicone grease) are the best way to stop wear from ozone wearing on your weather stripping and rubber seals. On such contributor says he lead a GM rubber division for ~10 years.
Now I'm concerned with trim and weatherstripping specifically. Trying to relieve some cracking on some exterior rubber which is cracking. Wurth is now selling some marketed silicone-free stuff. 1z has Gummi Pfledge that is no longer really a grease, but more liquid.
So - is Silcone good or bad for protecting rubber?
#2 2002 Z06
2002 Z06
    Registered User
  • Members
  • 167 posts
Posted 07 May 2008 - 09:37 AM
I am torn myself. I see that the silicone makes the rubber look good for a while but whne it dries it ends up brownish colored depending on the silicone used.
InIt2WinIt - No Sacrifice, No Victory.
#3 CleanFreak2
CleanFreak2
    Registered User
  • Members
  • 186 posts
Posted 07 May 2008 - 09:38 AM
Subscribed....
#4 DETAILKING
DETAILKING
    Registered User
  • Members
  • 3,268 posts
Posted 07 May 2008 - 10:03 AM
The following is from an article that David B wrote:
Your bike's tires have several formidable enemies: water, formaldehyde, petroleum distillates, ultraviolet light, and ozone. Water washes away the natural oils in rubber that keep it elastic. Formaldehyde and petroleum distillates act as a solvent, eating rubber on contact. When ozone, an odorless gas which is part of the air we breathe, is combined with ultraviolet (UV) light, a reaction occurs that attacks the tire and its polymers (the agents that bind the rubber).
To protect against ozone and UV damage, a stabilizer molecule called a competitive absorber is blended with the tire polymer. Competitive absorbers work by capturing and absorbing UV radiation and converting it to heat which is dissipated harmlessly. All tire manufacturers use the same competitive absorber, called carbon black. This is why all tires are black.
These absorbers are sacrificial; they expend themselves in performing their function of converting UV light to heat. However, as carbon black loses its ability to perform, it turns gray. This is one reason why black tires discolor as they age.
To protect from further ozone damage, tire manufacturers add a wax compound to their formulas. Tires flex when they are in motion, causing the wax molecules to migrate to the surface. This forms as a protective barrier between the air (ozone and oxygen), water and the tire polymer. In the tire trade this is called blooming. When tires are parked for extended periods, blooming does not occur and ozone quickly attacks the tire polymer. With UV light and ozone working in concert, the degradation is accelerated, resulting in drying, discoloration and cracking.
To combat the negative effects of water, solvents and UV light on tires, the bike care industry has created tire dressings. These dressings condition the tire, restoring essential moisture. Tire dressings fall into two groups:
1. Liquid Silicone Oil Dressings – These penetrating-type silicones form a flexible protective shield on rubber. Liquid silicone seals small openings with a film to prevent penetration of moisture and dirt. Most silicone dressings leave a never-dry gloss film. There are many myths regarding silicone, specifically the negative long-term effects of silicone on rubber and vinyl. The fact is, silicone is an inert material. The benefit of silicone is its ability to easily penetrate the tire’s surface and not evaporate. Some silicone-based dressings contain petroleum distillates as a cleaning agent. Petroleum distillates are harmful to rubber and vinyl, and will cause rubber and vinyl to crack. If you decide to use a silicone oil tire dressing, make sure it does not contain a cleaner.
2. Water-Based Dressings – The water-based dressings do not contain silicone oils, petroleum distillates, waxes, or other dangerous solvents that can harm and dull the surface of rubber and vinyl over time. Most water-based dressings use a water-based silicone, which offers a non-greasy, satin finish. The best products contain UV blocking agents to help keep tires and rubber from cracking, fading and hardening.
#5 auburnryan
auburnryan
    Registered User
  • Members
  • PipPip
  • 19 posts
Posted 07 May 2008 - 10:37 AM
Thanks King - Curious - have you used any of the Gummi Plege products on your BMW? He used some here - http://www.autopia.o...734-post39.html
#1 - refreshing me that petroleum distillates are the harmful portion, not really silicone. Here's and excerpt of what I'm seeing online " For the weather-stripping, use a non-solvent based, silicone lubricant or grease. Mequiars Vinyl and Rubber Cleaner and Conditioner is one example and GM Goodwrench Dielectric Silicone Grease (part no. 12345579) is another. If you choose to use the silicone grease, apply a small amount to the weather-stripping using your fingers. Wipe off any excess with a clean rag."
Now for #2 - skeptical of the "water-based silicone" - Impossible I say... but anyways the problem here is the ability to last. My 303 just won't stand up to extended exposure to the elements.
#6 Setec Astronomy
Setec Astronomy
    Registered User
  • Members
  • 10,397 posts
Posted 07 May 2008 - 10:41 AM
I'm curious about what the 10-year GM guy had to say--got a link?
New & Improved! "Truly filled with inconceivable hatred" --South Florida Review
What little I know about detailing I learned from David Fermani.
#7 auburnryan
auburnryan
    Registered User
  • Members
  • PipPip
  • 19 posts
Posted 07 May 2008 - 10:53 AM
Had to find it...I hate you for wasting more of my time - I'm so Obsessive-Compulsive on this stuff :)
And it was 10 -year old info, not 10 year "rubber man" - oops
Cadillac Owners Group - View Single Post - Silicone grease to condition weatherstrips
My father was the manufacturing engineer in charge of making weatherstripping for GM (then Delphi) at his plant. He then moved to be the global manufacturing engineer manager for engine mounts, so my info is at least 10 years old, but he said to use silicone lube (when he was at my house he bought some Penske lube stuff I still use). But you need to spray it on a rag or paper towel. If you spray it directly on the rubber the propellent in the lube will dry out the weatherstripping. The main thing is to make sure what you use is silicone based, since it is silicone rubber. Siloxane is what they soak them in after extrusion to moisten them, so if you can get that (which I could at my old job), use it.
#8 Setec Astronomy
Setec Astronomy
    Registered User
  • Members
  • 10,397 posts
Posted 07 May 2008 - 11:02 AM
I talked to Dow Corning about this maybe 20 years ago, and they recommended DC 7, which is a light silicone dielectric grease, for weatherstripping, and I think for tires.
#9 auburnryan
auburnryan
    Registered User
  • Members
  • PipPip
  • 19 posts
Posted 07 May 2008 - 11:18 AM
I am thinking this (silicone dielectric grease) is a good product for those rubber seal "covers" around the windows and other trim. Mine are cracking, due to exposure I imagine (not garaged).
Thanks for the input folks - considering this "researched" in my mind...
#10 SuperBee364
SuperBee364
    Registered User
  • Members
  • 4,563 posts
Posted 07 May 2008 - 11:50 AM
Great stuff here... subscribed
Sage advice from Greg Nichols: "Hey, Supe? Always make sure your pressure washer tip is firmly attached to the end of the high pressure wand before pointing it at the windshield of a car, mmmkay?"
#11 RTexasF
RTexasF
    Registered User
  • Members
  • 895 posts
Posted 07 May 2008 - 12:51 PM
Here's what Honda uses for rubber weatherstripping and to stop squeaks. It's expensive but amazingly effective in my usage of it.
Posted Image
#12 stigg
stigg
    Registered User
  • Members
  • PipPipPip
  • 37 posts
Posted 07 May 2008 - 03:57 PM
Everything in this post corresponds to things I believe to be true. good stuff.
#13 Nic Walker
Nic Walker
    Registered User
  • Members
  • 153 posts
Posted 07 May 2008 - 04:31 PM
I was really getting interested in this thread...especially about the Gummi Pfledge and the Di electric grease........and then became confused :(. I have some of the Gummi Pfledge and it sure makes the weatherstripping look Great/New, but in the thread no one finished or came to a conclusion on its worth/value.....and also no comparrison with di electric grease was reached.
Questions please:
Does the Gummi contain any petro ingreediants rendering it harmful to weatherstripping?
Is di electric grease better (protection wise) than the Gummi? Which is more appropriate for protection and looks please?
If the di electric is better thant the Gummi, is any particular make (manufacturer) other than the Honda Stuff better than others. I have a giant tube of the stuff that I bought from Auto Zone or Advance but it is just some off the wall di electric grease....is this appropriate for use on weatherstrips?
I am just a novice and I hope my questions are not out of line....
Thanks,
Nic
:usa
Opps - forgot....303 is only mentioned briefly and not discussed. Is the properties of 303 not desirable? Would it enhance longevity of the weatherstripping to use 303 1st as a base for added protection and then one of the others on top for enhanced protection and looks?
thanks
#14 Setec Astronomy
Setec Astronomy
    Registered User
  • Members
  • 10,397 posts
Posted 07 May 2008 - 04:41 PM
The Gummi Pfledge seems unique to me, I don't take it out of the bottle as Accumulator seemed to imply he does (in another thread), but it seems to be a clear liquid and it creates an amazing transformation on weatherstripping (when I say weatherstripping, I'm referring to the seals around doors that you can't see when the door is closed, and to a lesser extent sunroof seals, which you can). The grease is an old-school (and apparently still used) remedy for the same thing, sticking and squeaking of door seals. The technique was to rub it in, then wipe it dry with a rag.
#15 BigJimZ28
BigJimZ28
    Registered User
  • Members
  • 3,586 posts
Posted 07 May 2008 - 04:45 PM
Posted Image
save yourself some $ & buy dielectric grease
have use it and spray Silicon lube for years per old GM info
(it is still recommended @ the dealer last time I checked)
food for thought ....I have a 81 Z-28 Camaro that has been outside 24-7 for the 10+ years I have owned it and treating the top-top seals and door seals with dielectric grease & spray Silicon lube
and THEY STILL DO NOT LEAK! if you know anything about these cars that is a feat
also the seals on the conv top of my 97 z-28 camaro are in great shape for 11 years old and spending as much time as possible @ the shore
#16 Setec Astronomy
Setec Astronomy
    Registered User
  • Members
  • 10,397 posts
Posted 07 May 2008 - 04:50 PM
Is that where I heard it from? It sucks to get old..
#17 BigJimZ28
BigJimZ28
    Registered User
  • Members
  • 3,586 posts
Posted 07 May 2008 - 04:56 PM
could be
as far as I know the only choice is to die young ...... now that would suck
#18 Setec Astronomy
Setec Astronomy
    Registered User
  • Members
  • 10,397 posts
Posted 07 May 2008 - 05:02 PM
Hey man, die young, stay pretty! Too bad I already missed my chance ;)
#19 wannafbody
wannafbody
    Registered User
  • Members
  • 7,022 posts
Posted 07 May 2008 - 05:43 PM
When it comes to tires I'd suggest calling the manufacturer and ask them. Michelin used to advise against using silicone based tire dressings but that was several years ago.
2000 WS6 TA NBM
#20 Accumulator
Accumulator
    Registered User
  • Members
  • 36,136 posts
Posted 08 May 2008 - 08:00 AM
..die young, stay pretty...
Been listening to Blondie lately? ;)
