Jump to content
Suggestions on how to fix scratch on bumper, plastic body panel
  • Please log in to reply
2 replies to this topic
#1 svander
svander
    Registered User
  • Members
  • Pip
  • 6 posts
Posted 06 May 2007 - 12:46 AM
I had a little mishap last night and cracked my taillight and scratched my bumper as well. :furious: In any case, the taillight is getting replaced (the whole set since they were custom tinted) and now I need to get this scratch repaired.
Please have a look at the pictures of the damage below and if you can, give me your ideas on how to address this. So far, I cleaned up the area as best as I could by running my Porter Cable with Meguiars #83, then #80 for about 30 minutes or so total. Panel became warm, not too hot but I was paranoid about giving it too much cowbell and burning off the paint due to the paint being softer in plastic body panels and such.
Anyway, here are the results so far:
You can see the scratches on the clearcoat on this image:
Posted Image
This one shows the areas where the paint was scratched off:
Posted Image
Closeup of those same areas:
Posted Image
As you can see I removed the taillight housing. The largest scratch is on the very edge of where the taillight sits, which makes it relatively unoticeable. Regardless, I know it's there and not doing anything about it would haunt my dreams (I am pretty particular about my car... enough to create a user account here even though I've browsed this website for a while now). ;)
I read people's opinions on kits such as Langka and Touchup123 (Touchup123 having the most favorable results among those that have used it). However, I need to know if you guys recommending approaching the issue in a different manner, including having a pro handle it (I've already IMd a local pro about it).
Suggestions not only welcome but much appreciated by anyone that has had read this far and has the time to help. Thanks in advance. :xyxthumbs
#2 svander
svander
    Registered User
  • Members
  • Pip
  • 6 posts
Posted 06 May 2007 - 05:04 PM
Anyone has any suggestions?
#3 Accumulator
Accumulator
    Registered User
  • Members
  • 36,152 posts
Posted 07 May 2007 - 09:00 AM
...I read people's opinions on kits such as Langka and Touchup123 (Touchup123 having the most favorable results among those that have used it). However, I need to know if you guys recommending approaching the issue in a different manner, including having a pro handle it (I've already IMd a local pro about it)...
No different suggestions, I'd use touch-up basecoat paint, then Langka, then touch-up clear, then...if you want to try for better...wetsanding, compounding, and polishing.
*I* wouldn't worry too much about getting overly aggressive with the PC. I use the rotary/Cyclo/PC on plastic bumper covers without any problems. Just use common sense and err on the side of caution and you oughta be fine.
FWIW I bet you could do the touch-up about as well as most pros will do. I have one painter who's *MUCH* better at it than I am, really works miracles. But the other painter I use usually doesn't do it as *well* as I do (or I should say, as well as I *sometimes* do :o ).
The most interesting man in all of Autopia Land. (<--I didn't enter that!)
