Jump to content
Hot/Cold Water Help or Hurt The Car Wash
  • Please log in to reply
5 replies to this topic
#1 Lost Pup
Lost Pup
    Registered User
  • Members
  • 420 posts
Posted 12 February 2002 - 04:26 PM
Question is:
Is there any advantage to mix say hot water in the car wash bucket as well as the rinse hose ?
The hose faucet valve in the garage needs replacement and I wondered if adding a hot/cold mix valve would have any benefit with the wash application. The hot water supply is right next to the cold.
Pros
1. No more trucking 5 gallon buckets of hot water to the kiddy pool. This part convinced the wife.
In reguard to the car wash:
Will hot or warm wash/rinse rwater remove the Klasse SG any sooner ?
Thoughts ?
Thanks
#2 Dave C.
Dave C.
    Registered User
  • Members
  • 380 posts
Posted 12 February 2002 - 07:02 PM
Your water in my opinion should be near the temp of the surface. You don't want extremes that's for sure i.e. cold water on hot glass, hot water on cold glass. Warm water is ok, hot water is not. Not too warm though.
1999 Subaru Legacy Sedan
E-mail: DaveC@autopia.cc or ddcloyd@hotmail.com
#3 Guess My Name
Guess My Name
    Registered User
  • Members
  • 3,223 posts
Posted 13 February 2002 - 08:18 AM
Warm water helps in the cleaning process.
Plus it is easier on the hand
Neat Vehicle Freak
My Website Which needs some detailing as well.....
My Truck Album
2002 Chevy Avalanche
#4 Guest__*
Guest__*
  • Guests
Posted 13 February 2002 - 10:50 AM
If you use hot or even too warm of water you shock your paint by putting hot water on a cold car and it might cause the paint to slightly crack. Wear/tear
I think the best way to wash your car is use water that is the temperature of the cars paint.
Ex... Put your hand on the paint if it is really cold use cold water. If is hot use very warm water not too hot to burn yourself. This shocking of the paint I got from another detailing website. Makes sense thouh.
:bounce
#5 Intel486
Intel486
    Registered User
  • Members
  • 2,964 posts
Posted 13 February 2002 - 12:16 PM
I always try to use warm water. In the summer the water is hot enough but in the winter I add a little hot water to the bucket to make it luke warm. I think the warm water will help lift off the baked on dirt. If you live in areas that they use salt, then warm water will probably help dissolve the salt better.
#6 darbh
darbh
    Registered User
  • Members
  • 612 posts
Posted 15 February 2002 - 05:40 PM
Warm water is the way to go -- it will clean better. The concerns about temperature differences are not imaginary, but only are of concern if the temperature differences are significant.
Semi-Weekly Z2; Infinite Z6; Z-10 Leather Cond.; Z-16 Tire Gloss;
MF, Charisma Select, Canning Vale and Platinum Towels; WeatherShield car cover
