Jump to content
clogged windshield wiper fluid nozzle
  • Please log in to reply
14 replies to this topic
#1 bigben
bigben
    Registered User
  • Members
  • Pip
  • 3 posts
Posted 02 April 2005 - 10:23 AM
yeah, i'm a newbie on the board...
and after several attempts, i can't get the clog (probably wax) out of my ww fluid nozzle/ejector. i know this must be a common problem, so any tips on how to clean them out? it's driving me nuts!
i have a 2004 toyota tacoma if that makes any difference. thanks,
ben
#2 BigAl3
BigAl3
    this is the place to be!
  • Members
  • 9,764 posts
Posted 02 April 2005 - 10:26 AM
try using a toothpick & toothbrush to get most of it (to blow it out use a can of air with the little straw).
autopia.org - the internet's original "autopia" tried & true
enthusiast detailing forum - accept no imitations!
the search function is your friend...
#3 White95Max
White95Max
    Registered User
  • Members
  • 6,909 posts
If it's just wax buildup on the nozzles, you can use a toothpick to pick the wax out of the nozzle.
In the future you want to either be more careful about getting wax in there, or tape them off with masking tape (I use green 3M masking tape. It leaves no residue on the paint).
Paul...
'99 Mazda Protege LX 5spd, highlight silver - AIO/UPPx2/#16
'03 Mazda Protege5 5spd, sunlight silver - AIO/UPP/Nattys
#4 CutNAction
CutNAction
    Registered User
  • Members
  • 402 posts
Posted 02 April 2005 - 10:27 AM
Ive ever never read a post that anyone has had this problem..hehe but what I would recommend is simply taking a paper clip and open it up and just poke one of the ends in the little hole.
1999 Grand Cherokee Limited V8 4X4 and I'm loving the power!
#5 Intercooled
Intercooled
    Registered User
  • Members
  • 1,208 posts
Are you sure its clogged?
Maybe the spray pump went? thats a typical item to go.
2006 H2 Fusion Orange LE
#6 bigben
bigben
    Registered User
  • Members
  • Pip
  • 3 posts
Posted 02 April 2005 - 10:33 AM
dang! you guys are fast! i'll try picking at it some more an maybe pick up an air can. guy idea about taping it. don't know why i never thought of that. thanks!
ben
#7 Bill D
Bill D
    Registered User
  • Members
  • 10,486 posts
Posted 02 April 2005 - 10:36 AM
Put some naphtha ( lighter fluid) on a Q-tip, agitate, then use a toothpick or paper clip to dissolve the caked up wax. It might take several applications.
In the future, cover up that area of ejectors with a tiny piece of blue painters tape.
Unsuccessful at converting my neighbors to Autopians :sadpace:
Treat it like it's the only one in the world.
#8 BenP
BenP
    Registered User
  • Members
  • 794 posts
Posted 02 April 2005 - 10:44 AM
Use a pin. Stick it in the hole. Simple!
Ben
#9 Accumulator
Accumulator
    Registered User
  • Members
  • 35,797 posts
Posted 02 April 2005 - 11:41 AM
Yeah, use a pin/needle. Or get a set of dental tools/picks. These come in handy for all sorts of things, including *adjusting* some kinds of washer nozzles.
A thin piece of wire will work in a pinch too.
The most interesting man in all of Autopia Land. (<--I didn't enter that!)
#10 perry
perry
    Registered User
  • Members
  • 504 posts
Posted 02 April 2005 - 11:51 AM
Ben
That's what I do.. just use a pin/needle to clear it out. Then spray some fluid, and use that same pin to adjust the nozzles but I just messed up the aim while clearing them out!
#11 buldog
buldog
    Registered User
  • Members
  • 287 posts
Posted 02 April 2005 - 04:22 PM
Remove the hose and blow it out. Don't push it in.
05_Dakota Laramie-Red
04_Pontiac Vibe-Black
#12 Accumulator
Accumulator
    Registered User
  • Members
  • 35,797 posts
Posted 02 April 2005 - 05:48 PM
Originally posted by buldog
... Don't push it in.
That's a good point. When you use the "poke with object" method, you want to *clear* the obstruction, often by breaking it up, not just push it further into the nozzle.
Heh heh, pulling some hoses is a bigger job than most people might want to try ;) Or at least getting them back on will be :D
#13 pdsterns
pdsterns
    Registered User
  • Members
  • 480 posts
Posted 03 April 2005 - 09:52 AM
I think not pushing in is a good idea but a very fine wire will usually do the job from the outside. The wire on parts tags is pretty fine. Make sure it goes in the hole easily, a toothpick is 100 times to thick. Strip insulation off of stranded electrical wire, unwrap a strand and use it.
Peter Sterns
72 Porsche 911E Targa, 85 Audi 4000S Quattro, 03 Honda Element AWD, 04 Honda CRV AWD, 06 Scion Tc
#14 PERRYinLA
PERRYinLA
    Registered User
  • Members
  • 28 posts
Posted 03 April 2005 - 11:06 PM
I've heard the nozzles can also clog from mineral deposits that accumulate as the washer fluid evaporates after each use. If that's the problem, use distilled water in the washer fluid tank from now on.
#15 Autoeng
Autoeng
    Registered User
  • Members
  • 312 posts
Posted 04 April 2005 - 10:23 AM
Some vehicles have inline valves that prevent runback to the tank (in particular some Nissan products). The valve is a metal bearing set on a spring. Eventually the spring gets sticky from stuff in the WW fluid and can't move. I was able to get one owrking again by cleaning with a cleaning fluid but had to replace the other with a fishtank airline connector.
Autoeng
