Jump to content
Clay bar question???
  • Please log in to reply
22 replies to this topic
#1 neomatrix
neomatrix
    Registered User
  • Members
  • PipPipPip
  • 82 posts
Posted 07 November 2001 - 05:44 PM
I have researched this topic for a while but I still have questions on what's available out there. I have the following products in mind but need your input on the pros and cons. I need your input on how easy to use.
1.) Mothers
2.) 3M - where do you get this anyway?
3.) Pinnacle
4.) Zaino
5.) did I miss another brand...Magic clay???
Thanks again.
<img src=http://u2.lvcm.com/rmp/Car/Lexus2.jpg>
Black Lexus 1998 LS400
Midnignt Blue Honda Accord 1994
Silver BlueGray Nissan Maxima 1990
#2 Josiah
Josiah
    Registered User
  • Members
  • 235 posts
Posted 07 November 2001 - 06:11 PM
I've been researching the Clay Bar options, and I finally settled on Mother's. It got the best reviews from people on autopia, overall. I heard Magic Clay is good... I got Mother's in the little "kit" for about $20, with their nifty little wax and the detail spray, which, although it doesn't say anywhere, I assume is for lub.
Personalized Key Ring Man
#3 Brad
Brad
    Registered User
  • Members
  • 160 posts
1.) Mothers ...good value, low residue, medium resistance, works well.
2.) 3M...works well, a little pricier, low residue.
3.) Pinnacle...smooth, pliable, low residue, easy to rub, pricey.
4.) Zaino..rubbery consistancy, works very well, no residue, pricey, my favorite.
You can't go wrong with any of these.
:up
#4 Josiah
Josiah
    Registered User
  • Members
  • 235 posts
Posted 07 November 2001 - 06:16 PM
So they are all pricey except Mother's? Maybe that's why I went with Mother's clay. :D
Josiah
#5 Bill Lessard
Bill Lessard
    Registered User
  • Members
  • 187 posts
Posted 07 November 2001 - 06:25 PM
As for 3M clay, try their website, www.3M.com.
I have only used 2 of these brands of clay. Clay Magic is very good, and I'm presently using Pinnacle Poly Clay. Also very good.
Nothing could be easier to use, than clay. If you get the lubricant, just spray on a liberal coat, take a flat piece of clay, and rub in a bumper to bumper manner covering several square feet at a time. You will feel how the surface will get very slippery as the surface is cleansed of any surface debris. When you are satisfied, just wipe the finish off, and move to the next area or panel.
Keep kneading and turning your clay to keep it clean. We don't want any scratches. When it's dirty, discard it. You should get several cars out of a piece.
Some clay comes in 1 chunk, and some like Pinnacle give you 3 small bars. Just keep it clean.
Some folks use a liberal mix of auto shampoo and water, or QD lubricant, as the medium instead of the regular clay lube. Some folks even clay as they wash their vehicle. All of the above are your choices. You will find a system that works for you.
When your done, give your vehicle a good wash, and your ready to move on. I think once or twice a year is sufficient to clay your finish. I do mine in the spring, and the fall. Again the choice is up to you.
I'm sure I've forgotten several tips, but other members will help you out.
Welcome to the Forum. It's the best place on the web to get that super shine on your vehicle. Enjoy!
BGL
#6 Brad4rdHay
Brad4rdHay
    Registered User
  • Members
  • 574 posts
Posted 07 November 2001 - 06:47 PM
If you use QD (prefered method) as your lube, i dont see why you should wash afterwards, am i missing something?..?...
#7 TortoiseAWD
TortoiseAWD
    Time's a-wastin',speedy!
  • Members
  • 3,457 posts
Posted 07 November 2001 - 06:53 PM
I recently picked up a Clay Magic bar (blue), and have also used Zaino and Meguair's. My experience with the Meguair's is much like many other posters who've tried it: much smearing and frustration. I gave up after one panel.
I liked the Zaino clay, but I think I prefer the Clay Magic. It's more malleable and "tackier" than the Zaino . . . it glides on paint effortlessly with QD as lube (I used Final Inspection), but the side that you're touching sticks to and forms to your fingers much more so that the stiffer Zaino clay. I felt much more confident that I wasn't going to drop the Clay Magic bar because of this stickiness (you can pull away from the paint and it stays attached to your hand, but will not stick or smear on the paint with lube). Maybe "droppage" isn't a big concern for you more-coordinated detailers, but for a klutz like me, it's something to worry about . . . clay ain't cheap! Also, the CM bar was easier to fold and re-form (imo) than the Z bar.
Overall, though, I've had excellent luck with both CM and the Z clays, and would recommend either.
Tort
If you wish to make an apple pie from scratch, you must first invent the universe. — Carl Sagan
#8 Bill Lessard
Bill Lessard
    Registered User
  • Members
  • 187 posts
Posted 07 November 2001 - 07:10 PM
Brad,
No Brad, you didn't miss anything. My thinking is to remove the excess of any lubriciant. Whether it's a soap film, clay lube, or excess QD when your going to put just SG on your finish.
Didn't mean to confuse anyone, it's just that I would wash my vehicle, no matter what I was going to put on my vehicle. With the exception of AIO, PPCL, SMR or any other cleaner etc.
Maybe that's one of the advantages of claying while you wash, you can go back over the finish with your shampoo, and rinse, and your done. Again, to err on the safe side, I would give it a quick wash, just my method. Enjoy!
BGL
#9 DETAILKING
DETAILKING
    Registered User
  • Members
  • 3,268 posts
Posted 07 November 2001 - 08:42 PM
I like clay magic, mothers, and zaino. Meguires is not so hot........
#10 Nick
Nick
    Registered User
  • Members
  • PipPipPip
  • 37 posts
Posted 07 November 2001 - 09:50 PM
I got the Mother's clay bar and was surprised by the small size. Question -- do I use it "as is" or should I stretch it a bit so it better fits my hand?
Thanks
#11 darbh
darbh
    Registered User
  • Members
  • 612 posts
Posted 07 November 2001 - 10:06 PM
I clay using car shampoo as the lube (Z7 in my case, because I use Zaino).
I think one possible advantage of using a shampoo as a lube is that the car is getting quite a detailed "washing" as you are claying. The shampoo not only lubricates, it supplies cleaning power, helps with any film, etc. Any residue is mixed, to a greater or lesser extent, with shampoo, so should wash off more easily.
No scientific experiments done, just a theory. But, the results seem good.
Semi-Weekly Z2; Infinite Z6; Z-10 Leather Cond.; Z-16 Tire Gloss;
MF, Charisma Select, Canning Vale and Platinum Towels; WeatherShield car cover
#12 neomatrix
neomatrix
    Registered User
  • Members
  • PipPipPip
  • 82 posts
Posted 08 November 2001 - 08:52 AM
Thanks again for all your input. I have several cars that I want to clay. I have checked the sizes of these products and I found the following info:
1.) Pinnacle Poly Clay Kit - 3 bars of 2oz each $39.95 or $29.95 for the Clay only at CMA
2.) Zaino Z-18 - 1 bar 4 oz $16.95
3.) Mothers Kit - 1 bar 2.82 oz $15 @ Checkers (local) or 3 2.82 oz bars for $22.49 (direct)
4.) Clay Magic Spray & Clay - 1 bar 3.5 oz ($14.95) @ clay-magic.com
5.) 3M - can't find any info even on 3M site ( any links???)
If one is interested in just the clay bar ( I already have FI for lubrication ), then Mother's claybar is the cheapest hands down per ounce ( about $2.65 per oz for the 3-bar package). Everyone else is over $4 per oz. Of course, shipping costs was not included in the calculation. With this info on hand, how much does one really need to clay 3 cars? If it is not much, then Zaino seems attractive and does not look too pricey.
#13 Cybercowboy
Cybercowboy
    Registered User
  • Members
  • 448 posts
Posted 08 November 2001 - 08:56 AM
You get 2 bars for the price you mention. It works out to around $8.50 per bar. Of course you have to pay $6 in shipping, but you can order some other stuff for the same shipping cost to dilute the impact.
2002 Torch Red Corvette convertible
1997 Red/Tan Expedition
1993 Red Eclipse (wife's)
Zaino - tried it...loved it.
#14 neomatrix
neomatrix
    Registered User
  • Members
  • PipPipPip
  • 82 posts
Posted 08 November 2001 - 09:13 AM
Is it 2 bars of 2oz size or 2 bars of 4oz?
#15 Cybercowboy
Cybercowboy
    Registered User
  • Members
  • 448 posts
Posted 08 November 2001 - 09:18 AM
That's what my wife tells me anyway.
The Zaino bars are the 2oz variety, and are nearly identical in appearance to the Mother's clay bars.
#16 BradE
BradE
    Registered User
  • Members
  • 4,474 posts
Posted 08 November 2001 - 09:22 AM
The clays that have been mentioned in this thread are good ones. But a word of caution, stay away from Meguiars clay. Many members here report a quick break down of the clay, and that it causes lots of streaks and smears on the surface.
For store bought clays I would recommend:
Mothers Clay Bar
Clay Magic
Both work well and can be bought locally so you can save the $$ on shipping.
For clays that need to be ordered:
Zaino Clay
Pinnacle Poly Clay
Both of these clays work well also. But, these can get a little pricey once you add shipping.
All four of the clay work great. You just need to get one that fits how much $$$ you are willing to spend, and if you need it right away or if you can wait to have it shipped to you.
Good Luck!!
#17 Intermezzo
Intermezzo
    Registered User
  • Members
  • 2,962 posts
Posted 08 November 2001 - 12:54 PM
Cybercowboy, welcome back!!
The Mother's claybar works well, but because you have to buy a whole package, the value factor is slightly dimished. Fortunately, I live pretty close to a local Zaino distributor. I think the price difference is definitely worth it. The Zaino bar works great!
#18 martini
martini
    Registered User
  • Members
  • PipPipPip
  • 62 posts
Posted 08 November 2001 - 09:15 PM
Quite honestly, I'm not satisfied with the Mothers..
But I have yet to use any other, so I don't have anything to base a comparison on. It just leaves something to be desired for me (in using it, I have not problem with the performance)
1993 VR RX-7
#19 BW
BW
    Registered User
  • Members
  • 2,060 posts
Posted 08 November 2001 - 09:24 PM
I have used 2 Meguiar's ones (white and yellow) and also the Mothers kit and prefer the latter. It's harder to knead, but I prefer ripping it to small pieces so it doesn't matter. The main advantage is it doesn't leave any residue saving me a step.
The Mother's one seems to be a bit weaker than the Meguiar's one for really rough "orange-peel" surfaces though.
But thats what the ABC is for! :D
#20 Josiah
Josiah
    Registered User
  • Members
  • 235 posts
Posted 08 November 2001 - 09:31 PM
Mother's doesn't leave any residue? I was going to Dawn after I used to to use my 3M and Klasse... but if I don't need to? I was going to use their lub, is that where the oils come from? If so, what else can I use for lub?
Josiah
