Jump to content
CarPro's Denim orange peel removal pad TESTED....WOW!!!!
  • Please log in to reply
32 replies to this topic
#1 speedfreak81
speedfreak81
    Registered User
  • Members
  • 251 posts
Posted 14 August 2013 - 12:59 PM
I've been wanting to try these pads out for quite a while, but was waiting for the right opportunity. Well the time has finally come, as a previous client of mine just purchased a new to him '06 CLK55 AMB Benzo. He brought the car by last week, and upon looking it over could immediately tell that the whole driver's side had been repainted. It was absolutely FULL of orange peel. :jaw: Rather than spending the time sanding, I decided to give the denim orange peel pads a try!This review is part of full correction for this vehicle, and the rest of the car will follow once the work is complete. I'll start a new thread dedicated to the correction as a whole at that time.
From Car Pro's website: 5 1/4" Denim Orange Peel Removal Pad (V2)
With our CarPro USA Velvet and Denim Orange Peel Removal pads you can now remove or substantially reduce orange peel in the top layer without sanding. While removing orange peel and deep defects you are also polishing the paint rather than leaving sanding marks which reduces the steps needed afterwards.
Posted Image
denim_pad_135mm__09983.1355284074.780.780 by SpeedFreak81, on Flickr
New to Version 2:
  • Multiple Diameter pads available
  • Foam Interlayer changed from 3/8" to 3/16"
  • Redesigned foam interlayer for more effective orange peel removal
  • Redesigned without holes for longer durability
  • Reduce Orange Peel and deep defects while simultaneously polishing paint
  • Equivalent to 2000 grit sandpaper with out the dulling of paint and sanding haze
  • Reduce Orange Peel without sanding
  • Orange peel removal without the haze generated by sanding
  • Polish the paint while removing the ridges of orange peel
  • Less dust and clean up prior to finishing polish
  • Attach to hook & loop backing plate with rotary polisher for best results.
  • Apply a few drops to paint or pad according to your skills and preference
  • Work a 2' x 2' section or larger to keep heat down as needed but remember the larger the area the more time it will take to level orange peel and defects.
  • Begin working polish on low speed for a pass.
  • Step up speed to approximately 1100 rpm (adjust as needed)
  • With proper lighting observe the level of orange peel removal while you work noting precise surface contact without pressure to level ridges.
  • After completing each section wipe off paint with soft microfiber towel
  • Brush pad in direction of fibers to remove residue
  • Apply a couple more drops of polish for next section
  • Switch out pads as needed when cut has been compromised and set aside to clean by hand.
Well, I'll let the results speak for themselves, but I was STUNNED at what I was able to achieve with these pads!!:jaw: I used my Rupes Bigfoot 21 on speed 6 with Meguiar's M105 Ultra Cut Compound. Not only did the combo literally destroy the orange peel, it left a nearly flawless finish behind. NOTE: No finishing polish was used for these shots, they were after compound/orange peel pad ONLY. In an industry where time is literally money, this product has impressed me. Compared to sanding by hand or machine, then compounding, finishing; the time savings is huge.
The only con with these pads is they seem to cake up pretty quickly. I was roughing them up with my nylon pad cleaner brush after each pass, but was only able to do about a 4'x4' section before I had to switch to a fresh pad. I would suspect the level of build up would correlate to the amount of orange peel/clear being removed. Either way, a small price to pay IMO.
Without further delay, here are the pics!!
Couple "befores"
Posted Image
photo1 by SpeedFreak81, on Flickr
Posted Image
DSC_0064 by SpeedFreak81, on Flickr
Posted Image
DSC_0067 by SpeedFreak81, on Flickr
Posted Image
DSC_0071 by SpeedFreak81, on Flickr
Afters
Posted Image
DSC_0072 by SpeedFreak81, on Flickr
Posted Image
DSC_0068 by SpeedFreak81, on Flickr
Posted Image
DSC_0066 by SpeedFreak81, on Flickr
Posted Image
DSC_0065 by SpeedFreak81, on Flickr
Notice the difference in the distinction of image between the untouched area on the left/door vs the right side which was complete
Posted Image
DSC_0070 by SpeedFreak81, on Flickr
Thanks for looking. I'm not the world's greatest photographer, but I think the point is conveyed!
-Brian
SpeedFreakDetailing.com
Brian Lewis - Sterling, VA
#2 Dan
Dan
    Registered User
  • Members
  • 6,153 posts
Posted 14 August 2013 - 01:19 PM
Wow, impressive!
#3 Francisco
Francisco
    Registered User
  • Members
  • PipPipPip
  • 137 posts
Posted 14 August 2013 - 01:29 PM
Humm, going to have to look into these bad boys. Thank bud. Great review. I have a project coming up soon and the owner has advised me that he can see orange peel in some areas of his car as well.
Francisco Santiago
Detailer/Paint Correction Specialist
Facebook.com/pinpointprecisionautodetailing.com
#4 mrclrider
mrclrider
    Registered User
  • Members
  • 517 posts
Posted 14 August 2013 - 01:59 PM
GTFO! that looks great! How many did you use on the whole job?
Sent from my mobile device
Fergy
You're only as good as your last detail
#5 alw6589
alw6589
    Registered User
  • Members
  • PipPip
  • 13 posts
Posted 14 August 2013 - 02:33 PM
Can I use these on my Flex DA??
#6 Thomas Dekany
Thomas Dekany
    Registered User
  • Members
  • 11,478 posts
Posted 14 August 2013 - 03:13 PM
Great job, glad you like these pads. I have them in my bin with my other pads, but haven't tried them yet.
yes you can use them with the flex.
 http://www.tdekany.com Authorized Opti Coat and CQuartz Installer
#7 Thomas Dekany
Thomas Dekany
    Registered User
  • Members
  • 11,478 posts
Posted 14 August 2013 - 03:17 PM
PS - how did you use the 5" pads on the Rupes?
#8 speedfreak81
speedfreak81
    Registered User
  • Members
  • 251 posts
Posted 14 August 2013 - 04:41 PM
The same way I've seen you use those little baby 4" pads on your FLEX.:heh: Yeah I remember those pics.
BTW, so I sprang for a Rupes bc of all the fuss............not overly impressed. The motor is ANEMIC compared to the Flex, and bogs down extremely easily. :(
Brian
#9 Ahheck01
Ahheck01
    Registered User
  • Members
  • 186 posts
Posted 14 August 2013 - 05:32 PM
How many pads did you go through for the car? How many passes to achieve those results?
Thanks!
#10 Nth Degree
Nth Degree
    Registered User
  • Members
  • 818 posts
Posted 14 August 2013 - 06:53 PM
Very impressive. I have also been wanting to try these. Curious to know if you took any measurements of the paint before and after to know how much was removed.
#11 Thomas Dekany
Thomas Dekany
    Registered User
  • Members
  • 11,478 posts
Posted 14 August 2013 - 08:15 PM
I tried mine for the first time yesterday and barely used it, it couldn't do the job. Not sure what to do. I agree, not much juice.
Brian
#12 speedfreak81
speedfreak81
    Registered User
  • Members
  • 251 posts
Posted 15 August 2013 - 04:57 AM
It makes me wonder about all the praise its getting. I have to suspect that these people are probably coming from a porter cable and possibly have never used a Flex before?
#13 C. Charles Hahn
C. Charles Hahn
    Registered User
  • Members
  • 6,763 posts
  • LocationLansing, MI
Posted 15 August 2013 - 02:55 PM
Not so much; I for one owned/still own a Flex DA... and I much prefer the Rupes. The key to getting the most out of a Rupes is to embrace the fact that it requires a different technique than a PC or a Flex. Forget about the KBM, high machine speed and tons of pressure. Low and slow is the way to get the most out of the Rupes. Low machine speed, low pressure, and slow arm speed as you make your passes.
Charlie
Automotive Appearance Specialist - Serving Greater Lansing, Michigan
http://www.cchautoappearance.com/
#14 IHA Mark
IHA Mark
    Registered User
  • Members
  • 775 posts
Posted 15 August 2013 - 02:58 PM
Do the washer mod. It will be a different machine. I thought mine was just an overpriced PC until I did the washer mod.
Marion Illinois Auto Detailing
By
Visual Pro Detailing
www.visualprodetailing.com
#15 Thomas Dekany
Thomas Dekany
    Registered User
  • Members
  • 11,478 posts
Posted 15 August 2013 - 04:03 PM
I ordered mine from Kevin, and I put the washer in.
#16 Scottwax
Scottwax
    Registered User
  • Members
  • 33,317 posts
Posted 15 August 2013 - 07:15 PM
Give it some time, I think you'll find it works much better than you think it will. It cuts nearly as fast as my Dewalt rotary and the finish is way better and takes less steps to finish out. The power is very deceptive due to the smoothness. Similar to when I replaced my all aluminum road bike with a more modern geometry aluminum/carbon blend bike. Thought the new bike was slower until I looked down at my bike computer. The much smoother ride betrayed how fast it was.
As far as the denim pads go, definitely need to get my hands on some. That's really impressive!
www.scottwax.com
I test for Optimum, Clearkote, Meguiars
#17 alw6589
alw6589
    Registered User
  • Members
  • PipPip
  • 13 posts
Posted 15 August 2013 - 07:28 PM
Still no answer on a few questions I'm dying to hear about
How many pads for the whole car?
Did you measure with a paint thickness gauge? If not, what method did you use to minimize risk of burning the clear?
How dangerous are these pads without a thickness gauge?
#18 dhyjddtjian
dhyjddtjian
    Banned
  • Banned
  • Pip
  • 7 posts
Posted 17 August 2013 - 05:57 AM
Humm, going to have to look into these bad boys. Posted Image
#19 TOGWT
TOGWT
    Registered User
  • Members
  • 5,291 posts
Posted 17 August 2013 - 06:51 AM
CarPro Orange Peel Removal Pads - you can now remove or substantially reduce orange peel in the top layer without sanding. While removing orange peel and deep defects you are also polishing the paint rather than leaving sanding marks, which reduces the steps needed afterwards.
These pads have a very aggressive abrasive and are deceptive; they have twice the rate of cut of typical wool pads. They don't dull the paint like sanding so it may appear you aren't removing paint but you most certainly are.
They are intended for use by professionals who are very familiar with paint film thickness, using and interpreting the results of a paint thickness gauge (PTG) compounding, polishing, and the dos and don’ts of paint correction. Theses pads are designed for use with a rotary polisher (1000 RPM <) average removal is approximately 5µ (0 .2Mil) - 7.5µ (0. 3 Mil)
These pads are available in two configurations: Denim (2000 Grit) is the more aggressive and designed for the removal of severe texture from refinished paints and Velvet (3000 Grit) is used for removing light orange peel from thin, factory-applied paint; both pads utilizing CarPro Fixer as a lubrication / compound.
Use very little pressure and check the paint surface temperature often. Similar to ‘block sanding’ the pad / backing plate are rigid enough that when used correctly it abrades the paint ridges (high spots) faster than the valleys. Either pad will polish the paint as it removes orange peel requiring only one or two additional polishing steps to create level paint that reflects accurately. These pads should only be used with proper knowledge of clear coat thickness in conjunction with a paint thickness gauge. As with any aggressive abrasion method be very cautious with factory OEM paint.
There are two considerations; (a) how much clear coat (B) how much ultra violet protection can be removed, they are not interchangeable. The following are the maximum allowable clear coat reductions the major USA car manufacturers will allow before the paint warranty becomes void; Chrysler- 0.5 Mil (12µ) Ford – 0.3 Mil (7.5 µ) and GM – 0.5 Mil (12µ)
(Source - Automotive International)
Detailing Art; where applicable Chemistry meets Aesthetics See Autopia Detailing Wiki
#20 CEE DOG
CEE DOG
    Registered User
  • Members
  • 626 posts
Posted 17 August 2013 - 11:33 AM
Thanks for the review!! Great work
Continuous effort - not strength or intelligence - is the key to unlocking our potential Winston Churchill
Store: http://www.carpro-us.com/
Email: Corey@carpro-us.com
Phone: 386-259-0759
