Jump to content
Chemical Guys V36 and V34 Testing
  • Please log in to reply
8 replies to this topic
#1 Dave KG
Dave KG
    Registered User
  • Members
  • 1,154 posts
Posted 10 August 2011 - 04:32 PM
For some time, Chemical Guys have sort of been forgotten about in terms of correction polishes for machine despite having some decent products in the range... the old Paint Correction products were lovely to use and forgiving, but were in my opinion plagued by the issues of lacking the cut of their competitiors despite matching the finishing abilities.
However, a new range is here - the V-series Optical Grade polishes, and currently there are three in the lineup:
  • V38 - Finishing Polish
  • V36 - Middle Polish (The Workhorse)
  • V34 - Cutting Polish
This review focusses on V36 and V34. V36 has been around a little while, and has previously been tested by Gordon and I in a variety of tests, but V34 is relatively new to the market designed as a heavier cutting polish.
So, for this review, I've put the products alongside Menzerna as a fairly standard benchmark: V36 is first up, and as the middle of the range polish as it currently stands, I have put this against Menzerna's middle workhorse polish, Intensive Polish though recent tests may suggest that V36 is more closely akin to PO203S Power Finish. For testing purposes though... let's see how it does :)
So, one panel marred with moderate to severe swirls and deeper RDS:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Quite a challenge for a workhorse polish, but there's nothing like giving a product a challenge! V36, applied using a Chemical Guys White Hexlogic polishing pad as shown in the video below. As a water based polish we have found that working the product at slower speeds as benefits as it prolongs the work time of the product and allows greater cut to be achieved and a finer finish as the abrasives seem to be better worked... so maximum of 1500rpm, but with focus at 1200rpm and also in the video the set is very long and the residue comes back allowing a second higher speed session to further refine the finish. The very long work time is a big plus of the product already for flexibility and refining:
1 Chemical Guys V36 Long Set - YouTube
The results of this set are shown below:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The correction level is noticeable and quite impressive - most of the swirls dealt with but a lot of the deeper RDS remain, certainly more than Scholl S17+ on an equivalent panel. However, the finish is very good indeed with good clarity achieved and very easy wipe off of the product residue.
By means of comparison, one of the benchmark workhorse polishes was then used in comparison - Menzerna Intensive Polish, using a long regenerating set as shown in the video to maximise its cut and finishing abilities:
2 Menzerna Intensive Polish Regenerating Set - YouTube
The results achieved from 85RD3.02 on an equivalent white hexlogic pad are as follows:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
By comparison, the correction of Intensive Polish is much greater especially looking at the RDS correction and the finishing abilities of the product are also equivalent showing Intensive Polish to be more flexible and capable of greater correction. Take nothing away from V36 here though, it s a very good product that is very capable and in fairness it is perhaps better compared to Menzerna PO203S Power Finish. But in the company of Intensive Polish, it is slightly outclassed.
However, let's turn the attention away from V36 to the new V34, which is more aggressive and will be better placed to tackle deeper RDS. V34 was applied using a Chemical Guys Orange Hexlogic Cutting Pad, and applied to the same region as V36 was above so you can see the RDS that were remaining before the set. V34 applied as shown in the video:
3 Chemical Guys V34 Correction Set - YouTube
As with V36, keeping the speeds a little lower than usual (especially for a correction compound), and a fairly long set to get the best out of the correction and finishing abilities offered. The results achieved are shown below:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The correction level is definitely improved and v34 shows itself here to be roughly equivalent to Intensive Polish in terms of cut, and it also has impressing refining abilities for the level of cut it possesses. If anything, the V34 seems to be more closely aligned to Intensive Polish and viewed this way it is competitive. But this leaves me wondering - where is the more aggressive cutting compound in the range, the Power Gloss or Fast Cut equivalent as at the moment if V34 is the top of the cutting tree, then impressive though it is, the range is missing the heavier cutting compound which is a big hole - hopefully Chemical Guys are on the case for a more aggressive cutting compound :)
For comparison, Power Gloss (S100) on the same orange cutting pad was applied to test the cutting and refining abilities and delivered the following results:
Posted Image
Posted Image
Posted Image
Posted Image
The compound has again pushed the correction and delivered more than V34 has, but has left light marring in the finish which is to be expected from a heavy cutting compound. Given Power Gloss is not the most aggressive compound on the market, this to me highlights the need for the V-series polishes to have a more aggressive one added to the lineup. The polish range is quite impressive as it stands, lovely long work times and impressive refining abilities and they can correct - V34 is a good rival for Intensive Polish and in my eyes stands up well next to it and the likes of S17+. However, it would be nice to see a more aggressive compound completing the lineup. But - Chemical Guys do have a range that is competitive with others on the market, and should certainly not sit around forgotten about - perhaps this is the most impressive bit, and the bit that should be sung from the roof tops :)
"A thing of beauty is a joy for ever: Its loveliness increases; it will never pass into nothingness; .... "
#2 MCA
MCA
    Registered User
  • Members
  • 780 posts
Posted 10 August 2011 - 09:44 PM
Very nice review - I have both v36 and v38 but have not had the chance to use them yet.
I always appreciate your thorough write-ups :biggrin:
#3 V3AutoDetailing
V3AutoDetailing
    Registered User
  • Members
  • PipPipPip
  • 140 posts
Posted 10 August 2011 - 09:57 PM
Nice reveiw, i might consider these in am order. Having a few extra polishes around is never a bad thing.
Wny's Personl Professional Detailer.
http://v3autodetailing.com
#4 JuneBug
JuneBug
    Super Moderator
  • Moderators
  • 3,665 posts
Posted 11 August 2011 - 04:33 AM
There's always several ways to get to a destination; it just seems so old school to go back to 3 step corrections when the majority of the time you can do a one step with Uno or M105 using a MF pad and be done. I realize you can always get a little more gloss if you do a second step with a fine finishing polish, but, if you're doing daily drivers for budget conscious (cheap in other words) then the time is money thing comes in big time.
All I have in this world is my balls and my word, and I don't break them for no one.
Tony Montana
#5 sal329
sal329
    Registered User
  • Members
  • 1,262 posts
Posted 11 August 2011 - 06:40 AM
Thanks for the review Dave always good to see you back behind a rotary. I am curious if you have used these polishes with a DA?
www.diamondautodetails.com
#6 Dave KG
Dave KG
    Registered User
  • Members
  • 1,154 posts
Posted 11 August 2011 - 06:58 AM
The thread about short setting Menz SIP on Kompressor pads will interest you then :)
Gordon, my colleague has on more occasions than me.. I've used them on microfibre pads by DA and they can certainly correct, I think I wrote it up here a little while ago. On foam, a bit like on rotary for me, they work well but are still needing that extra level of cut for the heavier correction jobs.
#7 Tru_Shine
Tru_Shine
    Registered User
  • Members
  • 750 posts
Posted 11 August 2011 - 07:00 AM
Nice review. I wander how good the V34 would do with a Surbuff pad? I guess I know what I'm getting with my next purchase
www.TruShineDetailing.com
#8 Dave KG
Dave KG
    Registered User
  • Members
  • 1,154 posts
Posted 11 August 2011 - 07:13 AM
Gordon is testing the Surbuff pads at the moment and they came into their own on a DA correcting a BM 645 with severe defects by DA... I'll key him into this thread so he can post his findings, he has been using the V-series more than me as well :)
#9 SON1C
SON1C
    Registered User
  • Members
  • 208 posts
Posted 27 April 2012 - 10:16 AM
any more input on this series?
