Jump to content
How long does it take you to do an ONR wash?
  • Please log in to reply
16 replies to this topic
#1 john1r
john1r
    Registered User
  • Members
  • PipPipPip
  • 127 posts
Posted 24 November 2010 - 06:54 PM
As the title says, just wondering how long it takes everyone to do an ONR wash.
Thanks!
#2 AeroCleanse
AeroCleanse
    Registered User
  • Members
  • 1,257 posts
Posted 24 November 2010 - 08:14 PM
Depends on the size of the car. For a 4 door, maybe 20min
BespokeCarDetailing and AeroCleanse, LLC
#3 mblgjr
mblgjr
    Registered User
  • Members
  • 866 posts
Posted 26 November 2010 - 11:20 PM
If the car is dirty; it takes me an hour start to finish whether I'm doing an ONR wash or not.
If it's just been driven on dry days and isn't too bad, nothing real bad on the paint, just dust...then I can do it in 30.
For a typical midsize/small car (Mustang, BMW 3-series) it takes 1- 5gal bucket of wash solution and 2-4 rinse buckets depending on level of dirt.
#4 Bunky
Bunky
    Registered User
  • Members
  • 1,414 posts
Posted 27 November 2010 - 04:56 AM
I am not a pro or an amateur. It takes me about an hour but that is just me. I will usually clean the wheel area with APC and rinse with the residue ONR. If ONR does not affect LSP, it does have limitations.
Al
The need to bead but that's just me.
#5 01GreyStangGT
01GreyStangGT
    Registered User
  • Members
  • PipPipPip
  • 119 posts
Posted 27 November 2010 - 08:03 PM
30-40 minutes to wash my mustang. ONR is one of the neatest products I've ever used.
#6 Scottwax
Scottwax
    Registered User
  • Members
  • 33,425 posts
Posted 27 November 2010 - 09:25 PM
Less than 30 minutes for most sized vehicles unless they are trashed. Then add 10-15 minutes.
www.scottwax.com
I test for Optimum, Clearkote, Meguiars
Authorized Opti-Coat Pro installer
#7 Dan
Dan
    Registered User
  • Members
  • 6,206 posts
Posted 28 November 2010 - 07:06 AM
About 20 for a well maintained car. When I first started and had little faith, probably over an hour, now I'm down to one bucket and very careless with the stuff (though I have hard clears). The wheels take the longest for me, using a pressure washer I can get most of the dirt of in a few seconds where it takes several passes with the ONR.
#8 john1r
john1r
    Registered User
  • Members
  • PipPipPip
  • 127 posts
Posted 28 November 2010 - 07:38 AM
That still sounds like me at this point. Have only done a few ONR washes and am still trying to perfect my technique, wash media, etc...
For those of you doing it in 30 minutes or less, what are you using for the wash (sponge, mf towels, etc?), how many are you using, and are you QDing while drying?
Thanks again!
#9 AeroCleanse
AeroCleanse
    Registered User
  • Members
  • 1,257 posts
Posted 28 November 2010 - 08:23 AM
Thanks again!
I use a MF / Chenille mitt I got from the local Advanced Auto, generally I only need one. I don't use a QD.
#10 Alexshimshimhae
Alexshimshimhae
    Registered User
  • Members
  • 1,162 posts
Posted 28 November 2010 - 08:42 AM
15-20 minutes I'd say for my bmw and lexus
Decades ago, Accumulator sneezed on a car. The owner noticed that his car was imbued with something today this substance is called clear coat.
#11 Dan
Dan
    Registered User
  • Members
  • 6,206 posts
Posted 28 November 2010 - 09:59 AM
I use the target white MF covered sponges. Easy to see if there is still dirt on them. I don't QD while ONRing as I think its faster to come back and QD later. I also don't dry panels as I do the car, I usually dry in quarters.
#12 mblgjr
mblgjr
    Registered User
  • Members
  • 866 posts
Posted 28 November 2010 - 11:40 PM
I've found it best to use the MF covered foam "bones". BigLots has one that is usually blue covered and the Target brand is white. Either works well.
#13 Accumulator
Accumulator
    Registered User
  • Members
  • 35,780 posts
Posted 29 November 2010 - 09:02 AM
At the risk of sounding like some pedantic :nono I really do think that trying to do certain things, like washing a car, quickly is likely to lead to unfortunate occurences. I simply adapt a "it takes as long as it takes" perspective and if that's not feasible I put the job off until it is.
OK, OK...[Accumulator sheepishly climbs down off his soapbox :o ]
#14 Scottwax
Scottwax
    Registered User
  • Members
  • 33,425 posts
Posted 29 November 2010 - 08:48 PM
Same here, cleaned out Big Lots of their blue MF pads about 2 years ago. They hold up so well I've only gone through 5 of the 12 I bought.
www.scottwax.com
#15 stotte20
stotte20
    Registered User
  • Members
  • PipPipPip
  • 92 posts
Posted 29 November 2010 - 09:15 PM
today i did a honda crv and it took about 15-20 min to wash that, and about 25 to wash a dennali. thats not including wheels and such, i also used a sheepskin mit. but what meathods is every one using for fenderwells and wheels and tires, while doing the onr wash? where i live it gets cold so i have now converted over to using onr for all washes. i took the power washer out of my van so that is out of the question till spring. ive been using a steamer and it seems to work well but any input is great.
#16 Innovative Detailing
    Registered User
  • Members
  • 253 posts
Posted 29 November 2010 - 11:07 PM
The other day using my DetailingCaddy and Poly's on my wife's Mazda 3, I was able to do the complete exterior including rims in about 10 min. For fender wells, wheel barrels and tires I can use the same system, just more towels are required. I choose to use terry towels for these dirtier areas, one thing that really does help is to pre saturate the wheel barrels. Then fill a bucket with about 1 gal of water and a cap of Poly's, then using a Daytona Wheel Brush, I hit the barrels and all the brake dust comes right off.
With the use of this caddy, I no longer need to haul around a pressure washer or a steamer...and I am completely compliant with zero waste water discharge.
Edited by Innovative Detailing, 29 November 2010 - 11:48 PM.
David M. Sylican
Headlight Lens Restoral
O.C. California
#17 john1r
john1r
    Registered User
  • Members
  • PipPipPip
  • 127 posts
Posted 30 November 2010 - 07:58 AM
To confirm, is this the 'bone' everyone is referring to: Amazon.com: microfiber bone - Car Care: Automotive ?
Also, for anyone who has used the bone and regular MF, which do you prefer and why? So far I've tried MF Mitt, Sheepskin Mitt, and zymol and lowes sponges. I liked the Sheepskin the best. Am going to try plush mf next, but would consider the bone as well if people really like it.
