Jump to content
How To Correctly Use Meguiar's Ultimate Compound
  • Please log in to reply
10 replies to this topic
#1 mesterious
mesterious
    Registered User
  • Members
  • PipPip
  • 10 posts
Posted 23 July 2010 - 08:32 AM
I am going to be detailing my car soon and UC is my first step. Well o was debating on m105 and UC. I read that if you use UC correctly it will work the same as m105. Well I'm new to usuing a PC so how do you use UC correctly?
Edited by mesterious, 23 July 2010 - 09:06 AM.
#2 sulla
sulla
    Registered User
  • Members
  • 158 posts
Posted 23 July 2010 - 10:09 AM
Read this...very comprehensive and concise guide on polishing with 105/205 combo
Polishing How To with Meguiar’s M105 / M205 – Detailed Image
The technique in that blog will work for UC as well.. UC+NXT2.0 is a heavenly match combo and will work well for most paint
Some will say finish with SwirlX or M205.. But I guess that beats the point of using UC since it's meant to be a compound that finishes LSP ready
#3 Dubbin1
Dubbin1
    Registered User
  • Members
  • 361 posts
Posted 23 July 2010 - 10:23 AM
That's because it will finish down even better with a polish.
Dwayne
#4 BluBrett
BluBrett
    Registered User
  • Members
  • 293 posts
Posted 23 July 2010 - 01:36 PM
I used UC followed by SwirlX on a rotary and completely got rid of haze and swirls on my Acura (soft paint). They left some very light holograms, so you will may need to finish off with something milder than SwirlX.
2013 Lexus CT200h
1995 Acura Legend
2000 Chevy Tahoe LT
#5 ThrillHo
ThrillHo
    Registered User
  • Members
  • PipPipPip
  • 146 posts
Posted 23 July 2010 - 07:43 PM
IME the individual car/paint will determine whether or not you need a finishing polish. I did two different Jags ('99 and '07) with super hard clears that needed a fine polish after the UC. On the contrary, I did my brother's 2006 Neon SRT-4 that finished BEAUTIFULLY (after two passes) with UC. But this is slightly off topic. The OP is asking how to use it. That was a good link that you provided. I have an order of m105 on the way, so I can't directly compare the two but I was honestly not impressed with the level of cut it provided on the hard clears of the Jags, and even having to do two passes on the Neon. Just trying to tell you not to worry!
#6 ThrillHo
ThrillHo
    Registered User
  • Members
  • PipPipPip
  • 146 posts
Posted 23 July 2010 - 07:45 PM
You were using a rotary, he's using a PC. Plus it doesn't get much milder than SwirlX!
#7 BluBrett
BluBrett
    Registered User
  • Members
  • 293 posts
Posted 23 July 2010 - 08:04 PM
True. :xyxthumbs
2013 Lexus CT200h
1995 Acura Legend
2000 Chevy Tahoe LT
#8 mesterious
mesterious
    Registered User
  • Members
  • PipPip
  • 10 posts
Posted 23 July 2010 - 08:13 PM
Wow thanks for all the replys guys! That link really helps.
I wonder if my car has a hard clear.
Thrillho, when you say you had to do 2 passes on the car, are you saying that you used UC on an area then wipe it off then used it again and wiped it off? Or did one area at a time and do the whole car and did it twice?
I'm new to machines so any (PC 7424xp) tips are a lot of help.
Edit: Also I have 2 orange pads for UC, Will that be enough orange pads?
Edited by mesterious, 24 July 2010 - 06:45 AM.
#9 sulla
sulla
    Registered User
  • Members
  • 158 posts
Posted 24 July 2010 - 05:44 AM
Yes no doubt UC will finish even better with a finishing polish.. That's why I stated the combo 'will work well on most paint' :)
#10 Dubbin1
Dubbin1
    Registered User
  • Members
  • 361 posts
Posted 24 July 2010 - 08:29 AM
Sure if you keep cleaning them as you go.
Dwayne
#11 mesterious
mesterious
    Registered User
  • Members
  • PipPip
  • 10 posts
Posted 24 July 2010 - 08:36 AM
Cleaning them as in cleaning them with a brush?
Like this?
Foam Pad Conditioning Brush cleans and reconditions foam and wool pads on the buffer. remove excess caked wax and polish from buffing pads.
