Jump to content
Dynabrade Dual Action Buffing Head
  • Please log in to reply
62 replies to this topic
#1 Kevin Brown
Kevin Brown
    Forum Sponsor
  • Members
  • 636 posts
Posted 14 March 2009 - 11:36 PM
My friend Mike bought the Dynabrade Dual-Action Buffing Head:
Posted Image
Posted Image
Posted Image
The aluminum housing measures 4-3/4” in diameter.
Posted Image
Posted Image
With the backing plate removed, the innards are easy to see.
Posted Image
Posted Image
When the power slide button is engaged, this latching pin is raised.
This locks the entire housing to the drive, and the backing plate is forced to rotate.
Posted Image
When the power slide pin is disengaged, the latching pin is lowered.
The aluminum housing is able to rotate freely. This is set to the random-orbital mode.
Posted Image
Posted Image
We removed the backing plate to cut the size down. It uses a standard 5/16”-24 spindle.
Our plan was to remove the white foam along the outer edge.
This way, we could fit the Meguiar’s 7” pads to the backing plate.
Posted Image
This shot shows the overall diameters of the housing and the three plates we were going to use.
Posted Image
The Mirka plate will be used as the primary plate for the 7” pads.
The modified Dynabrade plate will be used as a backup.
Posted Image
See? the Mirka plate is nearly identical in size to the plastic part of the Dynabrade plate.
Posted Image
This is the Meguiar’s Soft Buff 7” Foam Cutting Pad. It is getting rave reviews.
Our goal was to allow Mike to attach the trio of foam pads to the attachment.
Mike will also be using the So1o Pad system, which wil fit nicely once we are done.
Posted Image
An X-acto knife and some hand sanding easily removed the unwanted foam.
Another way to cut the foam is to mount the backing plate onto a drill.
Then, carefully push the X-acto into the foam as the drill rotates the plate.
Posted Image
Voila! The plate fits perfectly into the recessed part of the foam cutting pad.
Posted Image
The Meguiar’s WWHC7 So1o Wool Heavy Cutting Pad will work well with this machine.
Posted Image
Here is a shot of the pad mounted to the machine. You can really see the offset!
Posted Image
The slide pin.
Posted Image
Wow, what an offset. This machine feature a 3/4” (12/16”) diameter orbit.
For comparison, the Meguiar’s G110 features a 5/16” diameter orbit.
Posted Image
Posted Image
Posted Image
We run the Makita at various RPM settings. It seemed to like 2,700 rpm with this 6-1/2” pad.
Posted Image
Posted Image
Posted Image
Posted Image
Keep in mind that this attachment was designed for use with larger pads than we were using, so the counterbalance was weighted accordingly.
From what I understand, Dynabrade spent a lot of time dialing in the balance for 8” and 9” pads.
If you plan on using smaller pads and plates, count on some vibration.
In terms of comfort, the optimum speed setting will be easy to find by adjusting the speed on the fly.
Thanks to the 3/4” orbit size and the power and rpm capabilty of the rotary machine, you will be hard pressed to stop the rotation of the pad in random-orbital mode (even at slower speeds) .
This is a time saver, and if you are comfortable with a rotary machine, you will really dig this baby!
#2 Peachstate Detail LLC
    Top 9 detailer in the US to serve you in Atlanta
  • Members
  • 7,168 posts
  • LocationAtlanta, GA
Posted 15 March 2009 - 12:36 AM
Kevin, How would you rate the vibration? Same as a PC?
Thanks for putting this together.
Bryan Burnworth
Atlanta Car Detailing
Selected as one of the top nine detailers in the US by Autoweek
Published in the 356 Registry
The only exclusive Opti-Coat Pro specialist in Atlanta
All PPF work done by the best in Atlanta Derek Johnson of Atlanta Protective Films
Follow Peachstate Detail LLC on Facebook here.
#3 topnotch
topnotch
    Registered User
  • Validating
  • 677 posts
Posted 15 March 2009 - 02:25 AM
I am also thinking about this, I am thinking of sticking it on an old rotary I have sitting around. Where should I buy it?
Paolo
Top Notch Detailing
Rochester, NY
#4 Barry Theal
Barry Theal
    Registered User
  • Members
  • 3,948 posts
Posted 15 March 2009 - 07:22 AM
Holy whips and chains batman! can you say mcgyver! wow thats looks very interesting!!! i have a dynabrade backing plate hmmmmmm!!!! lol great right up kevin!
#5 salty
salty
    Registered User
  • Members
  • 2,152 posts
Posted 15 March 2009 - 11:49 AM
Good idea and nice write up.
Mark
deluxedetailing
#6 bsibold96
bsibold96
    Registered User
  • Members
  • Pip
  • 9 posts
Posted 15 March 2009 - 12:58 PM
how much weight is added to the machine once the head is attached?
#7 Denzil
Denzil
    Registered User
  • Members
  • 1,949 posts
Posted 15 March 2009 - 01:09 PM
Thanks for putting this writeup together Kev.
Devil Pad
Professional Automotive Detailing
#8 Detailing Technology
    Registered User
  • Members
  • 2,660 posts
Posted 15 March 2009 - 01:57 PM
Calling Westchester Lacquer tomorrow. Got to try one of those.
Detailing Technology - specialista vernice di correzione
#9 Anthony Orosco
Anthony Orosco
    Registered User
  • Members
  • 3,636 posts
Posted 16 March 2009 - 08:17 AM
Ron and I have been using a Dynabrade for 2 years now, even posted up info on it if you do a search.
It's a nice tool but it adds a fair amount of weight to the buffer, it has broken twice but was repairable.
It doesn't have anything much over the Flex orbital....in fact we think the Flex may have more umph.
Anthony
"The Art & Science Of Auto Detail"
#10 gbackus
gbackus
    Registered User
  • Members
  • 597 posts
Posted 16 March 2009 - 08:26 AM
Anthony
Yeah, but this is the newer model with forced rotation, I was always a fan of the original(except the weight) and am curious to see how much more powerful the newer model is.
#11 Kevin Brown
Kevin Brown
    Forum Sponsor
  • Members
  • 636 posts
Posted 16 March 2009 - 08:57 AM
Anthony
Hi Anthony...
If you have been using the Dynabrade for two years, perhaps you have the #61374, which is a random-orbital head only?
This one is switchable and allows you to use a random-orbital mode or a forced rotation.
#12 Apollo_Auto
Apollo_Auto
    Registered User
  • Members
  • 1,126 posts
Posted 16 March 2009 - 09:26 AM
Hmm, got me thinking about this one... thanks for the post, Kevin!
Wolf's Chemicals Detailing Products
#13 gbackus
gbackus
    Registered User
  • Members
  • 597 posts
Posted 16 March 2009 - 10:40 AM
Hi Anthony...
*points up* A little late Kevin....:D
#14 Kevin Brown
Kevin Brown
    Forum Sponsor
  • Members
  • 636 posts
Posted 16 March 2009 - 10:45 AM
Ahhhhh... I was thinking 'what is he talking about?' :think:
Then I looked back and saw your post!
I get an e-mail notification and I clicked the link to the post and responded... Completely missed that you mentioned the part numbers. :wall
#15 gbackus
gbackus
    Registered User
  • Members
  • 597 posts
Posted 16 March 2009 - 11:09 AM
Your response was actually much more informative, I just wanted to give you a hard time :up:
#16 Anthony Orosco
Anthony Orosco
    Registered User
  • Members
  • 3,636 posts
Posted 16 March 2009 - 03:01 PM
Hi Anthony...
Yes, we have the older model......the throw on the Dynabrade is so large that it's hard to see the difference by looks alone.
If the cost wasn't so high on the Dynabrade I would try out the new one but not going to spend the money just to "try it".
Take care,
Anthony
#17 blk45
blk45
    Registered User
  • Members
  • 470 posts
Posted 17 March 2009 - 05:56 AM
$82 is high? :nixweiss
Dynabrade 61379 - Dual-Action Buffing Head
#18 SuperBee364
SuperBee364
    Registered User
  • Members
  • 4,563 posts
Posted 17 March 2009 - 05:59 AM
Sheesh, blk45, I think you and I have been shouting in deaf ears; they must not have seen your post about that place to get DynaBrades for 82 bucks.. Maybe you should delete that post so we can keep it a secret from those that weren't paying attention in class... ;)
Sage advice from Greg Nichols: "Hey, Supe? Always make sure your pressure washer tip is firmly attached to the end of the high pressure wand before pointing it at the windshield of a car, mmmkay?"
#19 blk45
blk45
    Registered User
  • Members
  • 470 posts
Posted 17 March 2009 - 06:00 AM
:chuckle: Did you order yours yet?
#20 Denzil
Denzil
    Registered User
  • Members
  • 1,949 posts
Posted 17 March 2009 - 08:34 AM
I'm curious to observe how well this products actually works but I'm definitely not ready to drop the cash for it, LoL.
Devil Pad
