Re: Rechargeable Razer
I have had a Braun 7526 with the clean/renew base since 2004. I have replaced the metal cutter three times and the freaking base twice. I have had it with the base! The stupid arm locking mechanism keeps breaking so it doesn't stay down to clean/charge the unit. I use tap on it instead. Only reason I keep using it is because I like the shave. Not as close to the Mach 3 blade as mentioned above, but it saves time. I have had it offs its base for weeks at a time and can get about 2 weeks from it (shaving every other day) before needing to plug it into the wall. Performance dropped at the 5th or 6th shave without the base. Keep it on the base to clean/charge and it'll be ready every time.
My next purchase will be the Braun activator series where on the base there is no arm to break.
I have been had it, lol...
