In a post on Autopia someone stated that
Klasse AIO would help remove oxidation by applying after wash/clay/then the AIO, after that use the polishing product of choice to remove the swirls/scratches/leftover oxidation.
The procedure of putting the Klasse AIO on before polishing would go a long ways towards removing "oxidation". Sounds reasonable since AIO is a chemical cleaner.
Is this procedure what the pros would recommend to treat oxidation/get rid of oxidation.
Before this I thought that the act of polishing the paint with the appropriate polish would solve the oxidation problem, but evidently oxidation is sort of a seperate/combined beast that is a lot harder to get rid of than I thought!!
Products on hand: Sealents- Klasse AIO/SG, Jeffs Werkstaff Prime Strong /Acrylic Trigger.
Polish/compounds = 3M 05937 Machine Glaze, 3M 05933 Rubbing Compound.
Menzerna PO 106FF.
Tools: Porter Cable, 9724, all pads
Cyclo, all pads.
Rotary: Not yet purchased, waiting for "The Edge" connector.
Question: Should I approach the problem of oxidation as above, or what, I am getting a lot of controversal thoughts, so I think what the Pro's use is the information I need. Please don't let the lack of the proper equipment/product sway your reply. Just tell it like you see it. If I need it, I'll get it.
Changeling
