05-15-08, 12:08
| | Dewey, Buffet & Howe
JuneBug is offline
Join Date: Sep 2006 Location: Heart of North Carolina Posts: 1,490 | Megs Solo System? Has anybody tried this? and if so - what do you think?
Appreciate the feedback.
Thanks | |
05-15-08, 02:48
weekendwarrior is offline
Join Date: May 2007 Location: Charlotte, NC Posts: 766 | Re: Megs Solo System? I have all the Solo pads and backing plate, and love them. I haven't used the polish, as I understand it is designed for new paint.
DS Mobile Detailing, LLC
05-15-08, 04:00
07e90 is offline
Join Date: Dec 2006 Posts: 94 | Re: Megs Solo System? I love the gray foam solo pad, one of the best finishing pads I've used. | |
05-15-08, 06:55
TTWAGN is offline
Join Date: Oct 2007 Location: Melbourne, Australia Posts: 236 | Re: Megs Solo System? The solo pads are slightly expensive and wear out quicker than average.
These would be the worst pads on the market if you were a Professional detailer doing multiple cars.
HOWEVER
They are extremely smooth to use and probably the best beginner pads on the market. The general opinion is that wool is best for defect removal and foam is best for final gloss.
So if you are only going to do your car or a couple cars only then these pads would be a good investment.
The solo liquid is pretty good. Its a moderate to high cutting compound that finishes well and has a short to medium working time. It uses similar technology to M105 but that cuts more and has a shorter (too short) working time.
If you are new to the rotary and have a car with soft paint then i would reccomend a finer polish to use on the solo finishing pad, such as Meguiars #3 machine glaze. The solo compound on the finishing pad is still fairly strong so it may take some practice to get right. If you have a PC or orbital buffer i'd just use that for the last step until you perfect the solo.
I've moved onto the Edge 2000 system, and as i do a lot of cars its much more cost effective for me. Less than half the price in pads for the same work done. | |
05-15-08, 07:36
| | Up Theyah for the Summah
themightytimmah is offline
Join Date: May 2005 Location: Portland, Maine Posts: 3,168 | Re: Megs Solo System? I tore up a SOLO wool pad in one car's worth of use. Hopefully they'll replace it, as it was 15 bucks at the body shop supply  .
Their foam pads are nice, but I'm not sold on the one liquid system. I got to demo it, but honestly I find the same failings that I find with all of the pad dependent polishes out there - it doesn't cut fast and hard enough for me on a wool pad, and it doesn't finish quickly enough for me on a foam pad or perfectly on all paint types.
It fills someone's need for sure, but not mine.
05-15-08, 09:17
| | Superior Shine Detailing
Superior Fine is offline
Join Date: Jul 2006 Location: Los Angeles County, California Posts: 459 | Re: Megs Solo System? I love the solo system even on cured paint. I have had foam pads since last summer and still going strong.
“Your destination isn’t important, how good your car looks while you're driving there is what matters!” Superior Shine | |
05-15-08, 11:51
TTWAGN is offline
Join Date: Oct 2007 Location: Melbourne, Australia Posts: 236 | Re: Megs Solo System? Quote:
Originally Posted by themightytimmah it doesn't cut fast and hard enough for me on a wool pad, and it doesn't finish quickly enough for me on a foam pad or perfectly on all paint types. | Definitely!
It doesn't cut strong enough on the hard clear coats even with the heavy cut pad.
It doesn't finish fine enough on the soft clear coats leaving holograms even on the finishing pad.
On the majority of clear coats though, it can remove all defects with the heavy cut pad and finish hologram free on the finishing pad.
To cover all paint types you need atleast two liquids (fine and strong) and three pads (cutting, polish, finish) | |
05-16-08, 03:29
JuneBug is offline
Join Date: Sep 2006 Location: Heart of North Carolina Posts: 1,490 | Re: Megs Solo System? Thanks ya'll, I thought the same as TTWAGN about detailing "you need atleast two liquids (fine and strong) and three pads (cutting, polish, finish)"
But I've learned the hard way (empty wallet) on new products, that it's better to ask someone who's tried it, before I jump and get it. I read a little last night on MOL about the Solo pad issues - seems some have them and a few others didn't, the fact that there is an issue bothers me. | |
05-16-08, 04:44
danponjican is offline
Join Date: Mar 2007 Posts: 337 | Re: Megs Solo System? I think S1 is what the Solo system is not. It takes it to the next level in defect removal ability and quality of the pad (Edge pad). | |
05-16-08, 05:38
Join Date: May 2007 Location: Charlotte, NC Posts: 766 | Re: Megs Solo System? I don't think you can compare S1 and Solo. Solo was designed for new paints, and says so clearly on the Meguiar's site. Sure, a lot of guys may have success with it on established paints, but it isn't what it was designed for.
05-16-08, 05:40
JuneBug is offline
Join Date: Sep 2006 Location: Heart of North Carolina Posts: 1,490 | Re: Megs Solo System? Weekend is right, apples and bananas again. I was confusded a bit about the Solo line but I read more on MOL and it's not for the beaters I deal with. | |
05-16-08, 05:52
TTWAGN is offline
Join Date: Oct 2007 Location: Melbourne, Australia Posts: 236 | Re: Megs Solo System? New car paint or old car paint. Any product that works with one works with the other.
So its a fair apple to apple comparison IMO.
System one suffers the same problems. On soft clear it can hologram as the polish is too strong no matter how soft the pad is. So you can do the job on 90% of the cars.
To cover all paint types you need atleast 2 liquids and atleast 3 pads.
Strong polish - Meguiars M105
Light polish - 3M ultrafina
Cutting pad - Edge black wool
Polishing pad - Edge blue wool
Finishing pad - Edge white foam
Those 5 products could remove any defect from 99.99% of the paint jobs on the market. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 05:28. | | | |
