| Re: need touch up paint repair guy like actual touchup guy or paint repair guy? there is a difference.. touchup guys can only do so much.. small chips on the hood, door edges, chipped side moldings, any chips the size of the tip of a pen is doable and thats the only times where it would look "passable". you will most likely still be able to see touchup work if your looking for it.. sometimes its very noticeable depending on the skill of whomever applys it and the color of the car. anything else wouldnt look right or to me looks cheap. filling scratches, big gouges, bumper scuff, anything bigger than a tip of a pen, etc doesnt work out so well and fusterating as hell! touchup is just that.. touchup.. nothing fansy.
then there is the actual mobile paint repair guys. they will come to you and spray areas with a gun and blend area around it. they also do full bumpers, mirrors, and plastics. the law usually says you cant spray more than a 2x2 area outside and you also cant put a certain amount of toxins in the air.. that usually means not enough pressure and not that good of a finish; however bumpers, plastics, and small blended areas are hardly noticeable if its orange peely or disorted, unless your anal.
hope that helped. |
