Guys...looks like there will be more than one lesson learnred in this ordeal for me...Lesson 1: No matter how busy you are it's not an excuse to let required maintenance slide. I'm often times too proud to let anyone else work on my cars for anything as I prefer to do all of my own work. With my schedule I need to learn to pay someone else to do the work when my schedule doesn't permit...you'll see my hosed wheel in one picture that will be a reminder until I can get the spare (curb rashed) rim on the car.
Enough of that moral. Found the FK system relatively close to me and drove an hour to go get it. Tried it on the car and while it took out alot of the contamination it did not clear up the rear bumper and trunk like I had hoped. Sooo...onto the wetsanding option. I don't have much experience with it...for me it's too much of a liability to do on customer cars so I just don't do it. My "buddy" who does paint work said to come down to his shop and he'll show me how it's done.
I get there and observe as he wetsand the roof, rear bumper, trunk, and rear fenders that still had minor contamination issues. He wetsanded with 1500 grit 3M paper, then followed with 3M rubbing compound on a 3M white waffle pad on the rotary at around 1600 rpm. Under the florescent lights in his shop the car looked good. I told him that I'd take care of the remainder of the finishing work when I got home and went on my way.
The next morning when I got the car out in the sun I see the disaster that really was left behind and now I have to fix another mess.
Here are the shots of the current condition of the car...tell me what needs to be done.
In my opinion from researching the wetsanding should have been finished with 3000 grit...and likely a sanding block as well. BUT then again alot of this looks like it could be rotary induced. I attempted to use my rotary with a cutting pad and everything I own (OHC, PG, SSR2.5, SSR3) and all I've manged to do is dull the surface and not take out any of these markings.
Sooo...do I need to get a sanding block and some 3000 grit and start over?...or should this come out with the rotary. Keep in mind this is Audi clear hence it's not exactly easy to work with.
Thanks for any additional help. I will come out of this a better detailer in the end with and expanded skill set...I'm determined to get it right. Luckily I have you guys to leverage for knowledge unlike the issue I'm having with a stored procedure this morning at my "real job".
Andy
during:
Picture of roof. Wetsanded with 1500 and polished with white waffle weave 3M pad and 3M rubbing compound. Untouched by me at this point.
Picture of Trunk Lid. Drivers side where it's dull I've attacked with nearly everything I own with very little progress.
So that you guys don't think that I'm crazy...this is what the remainder of my 140,000 mile paint looks like...not perfect but not bad either (excuse the fact that it's a little dirty this morning).
