Originally Posted by Soarer5
RaskyR1, what is your technique for power washing and not getting the interior wet?
BTW I just noticed where you're from, my wife used to work at the Walmart before moving to VA.
NO real technique...and really I only do it when the door jambs are very dirty as I feel it save a lot of time and I don't want to trash my mitts and brushes. I just pre-treat with an APC, rinse with pressure washer and then clean normally with a seperate mitt and various brushes if needed. Follow that up with a quick final rinse. If a few drops of water happen to land on the interior I wipe it up with a towel. It's not like water doesn't land on door panels when you get in the car during a rain storm...
Originally Posted by LoiG37
Definitely not like that! I won't go above the window line and my pressure washer is set at a MUCH lower psi. I also have a shorter wand on my pressure washer.
Originally Posted by JimmyCutlass
I soak with Safe D-Greaser, agitate with slide-lock brush and use the mist setting on my hose head. I call it the discontinued Meg's method.
LOL. Yeah, bummer they discontinued them.
