Old 10-18-09, 04:10   #1 (permalink)
toyotaguy's Avatar
toyotaguy is online now
lets talk overspray
so, I had a car yesterday and I only had real time for 5 hours on it...needed interior work, exterior work. I ended up with 7 hours on it total, and skipped out on the rest of my day I had planned. Oh well, the client was extremely happy with the results.
car: 2001 toyota celica
damage: dents and dings, extreme road rash on the front (needed repaint)
mileage: 152K
interior was pretty hammered, this is her commuter car!
exterior: lots of scratches and deep scratches, plenty of swirl marks and TONS of OVERSPRAY
I spent 20 min claying the car from the front end back. then I attacked the overspray with megs red clay, clay magic red, ADS purple, 3000K megs unigrit paper, and rotary/cutting wool/105 = NOTHING WORKED efficiently in the 2 hours I spent on the front portion of the hood, the front of the fenders, and the WHOLE front bumper! I only got it about 40-50% out, but called it good enough based on time and needs/condition of the car.
I called up Patrick and asked his thoughts...he recommended I try a couple of things, but only had time to work with what I had on hand...prep sol wipe down and soak prior to the claying. Thanks for the tip! It worked a little faster, but the larger stuff was remaining STUCK on...nothing would budge it!
WHAT DO YOU USE IN THAT SITUATION? I want the proper product on hand for the next time there is extreme amounts of road paint all over the car!
*now offering PDR, window tinting, bumper repair and repaint!*
Old 10-18-09, 04:40   #2 (permalink)
www.6speedonline.com
the_invisible's Avatar
the_invisible is offline
Re: lets talk overspray
Sometimes painting material such as urethane, paint, solvent, lacquer, glue, etc etch into the paint down to the metal. In some cases, I've seen road paint creating an indentation on the metal surface. When that is the case, it will need to be sanded. Even after sanding down to the bare metal, a small needle sized dent still remains on the metal.
Old 10-18-09, 07:07   #3 (permalink)
Bright Dynamics Owner
Jakerooni's Avatar
Jakerooni is online now
A heated pressure washer ( I know I know not very mobile at all) would've washed it all off like a regular garden hose on a dusty hood. There are defiantly more aggressive chemical attacks you could use but I wouldn't recommend them without knowing exactly how they would react to the paint. Prep-sol is probably the least aggressive and safest way to go. Still probably going to take some time. mineral sprints would also be highly effective. you could also use a plastic razor blade on the paint and a regular razor blade on the glass with a little varnish on a MF towel on the rubber. All have very dire consequences if not done with an extreame amount of care..
Old 10-18-09, 08:27   #4 (permalink)
Advance Paint Correction
bufferbarry's Avatar
bufferbarry is offline
I would have used micro-surface's 4000 grit micro mesh! great **** there
Barry Theal
Presidential Details
Old 10-19-09, 01:09   #5 (permalink)
To Shine and Protect
salty's Avatar
salty is offline
Z-bar clay, if it is still available, mars paint like 3000 grit right out of the case. It works well, but expect to compound/polish after.
Mark
deluxedetailing
Old 10-19-09, 03:12   #6 (permalink)
gigondaz is offline
If there's loads of overspray, and i hv not been given sufficient time, and the owner has been informed of the risks, I always wipe with acetone first. Won't damage the paint finish at all. but avoid the non-metal parts. Dampen the sections for 5mins with acetone, rinse and thenclay as usual, and it'll be OK.
O.C.Detailing (Lynchburg, VA.) - 1987 Mercedes 300 SDL (Acrylic overspray removal!!!) adrock2003 Pro Details Before & After 11 09-28-09 04:21
Premium Detailed 2005 Honda Shadow Sabre (severe overspray!) Premium Pro Details Before & After 4 06-18-09 05:26
Overspray Removal Advice RAG Car Detailing 22 06-28-06 06:47
I find paint overspray removal tedious and unsatisfying Scottwax Professional Detailer General Discussion 8 09-14-05 08:00
Removing Overspray on 10 cars rlspringer Professional Detailer General Discussion 13 10-27-04 10:44
