Ok I Have O-N-R (Good Product) Old Shool set up Static Source (Water Tank) and Pressure washer, Question what is the best possible set up to use (if possible please post pictures) Should gravity be the way to go or a pump? I saw a city set up that had water tank on Pick-up andPut P.W on ground. Any suggestions/Ideas?
I use ONR as directed on Label, My issue is If I was doing work OLD SCHOOL and had a water Tank (Stactic source) and Pressure washer, what would be the best set-up to PULL water from Tank. Some Customers PERFER old techique hand wash and some like NO RINSE solutions so I try to offer both on mobile rig.
If you use a pressure washer & water Tank unit (static source) can you please post pictures and explain the way you draw water from tank to pressure washer, some of us have the slights uderstanding of these MOBILE OPERATIONS, some people use gravity and others use a external pump to draw water. in advance all help and comments are appreciated
