757, at our shop we use a hot water extractor, specifically the thermax therminator. Our old extractor did not have nearly as much lift as this one and left many cars very damp. This one works much much better and within 30 minutes the seats are dry and usually about 1 hr for the carpet depending on how stained it was and how many passes I had to make.
On lightly stained cars I don't need to scrub at all, I just use the extractor.
I can do a whole car with leather seats in about 15 minutes, cloth seats about 30 minutes and up from there.
Thermax DV12
The Therminator DV12 is Thermax’s newest industrial steam cleaner, which aggressively removes dirt, grime, odors and other embedded pollutants with unmatched efficiency.
Powerful dual two-stage vacuum motors (165” water lift) for faster cleaning, increased recovery speed and quicker drying time.
Built-in 1800-watt solution pre-heating system for quick, uniform temperature control (up to 175°).
11-Gallon hygienic stainless steel solution tank.
12-Gallon large capacity recovery tank with automatic overflow protection shut-off and waste gate empty system.
Single 25' power cord for one circuit operation.
High-impact, chemical resistant housing with conditional lifetime warranty - virtually indestructible.
100 psi high-efficiency demand solution pump (65-psi pump option available for auto detailing).
Engineered for mobility and stability, tip resistant operation.
Built-in dolly handle for greater control and maneuverability.
Large 8” rear wheels make it easy to go up and down stairs.
Marine sealed switches.
