Welcome to the Autopia.org. You are viewing as a guest. By joining our FREE community you will be able to interact with others. Plus, when you join you will receive instant coupon codes for special discounts with our sponsors. Registration is fast, simple and absolutely free so please, join our community today!
i was using some small weights designed for anchors, but the were not strong enough. i then came up with a better idea. i went to lowes and bought 4 metal 1 gallon paint cans and 4 long bolts w/ 4 wing nuts. i filled the buckets w/ concrete and put the bolt in and let in harden. i can now set each leg on a bucket through one of the holes and then screw the nut on for safety. the buckets not only hold the buckets down, but also give you 8 more inches of clearance for those taller vehicles.
The bucket and water method is great and what I recommend doing is getting your company logo and info on the buckets in the form of a nice decal and it's free advertising.
If you are only moving the canopy around for like a day or weekend, permanent weights are nice...however; if you are carting this around each and every day using buckets/containers that can be filled on-site will be a lot less work and wear and tear on the vehicle transporting them.
