| Re: Will a Vac N' Blo cut it? Extraction is all about HOT water injection and very powerful suction/lift.
Shampooing with foam and brush will begin to clean most carpets, but it is not going to clean dirty carpet. Go slow, and use a narrow nozzle - crevice tool. Use foam only, otherwise you'll never get the carpet dry.
Just know that after you think the carpet is clean, an extractor would still pull soiled waste water from that carpet. It is just a more thorough process.
When you are ready for (and can afford) an extractor, be prepared for big dollars. We started with $1200 units, and now we depend upon a $2400 unit. Yes, there is a huge difference.
Hope this helps. Good Luck!
Jim
Proud Member of NAPDR
Thank a Veteran.  :
