Old 12-08-07, 10:46   #1 (permalink)
Scottwax's Avatar
Scottwax is online now
Applied Color's paint touch up kit
Robert of Applied Colors contacted me and asked if I would like to test out a paint touch up kit his company is trying to put together.
The kit includes numerous bottles of touch up paint and a paint match guide, dozens of paper mixing cups, thinners and thickeners, wax/grease removers, comprehensive instruction booklet, numerous touch up brushes of varying thickness, wetsanding block (but no wetsanding paper), etc.
Mostly I have been trying it out like I would be using a bottle of the factory touch up paint. Sometimes I have had to mix together 2-3 of the same color scale to get a proper match. The plethora of brushes make it pretty easy to find the right one for the size scratch you are fixing-unlike factory touch up paint that has one brush size that always seems too thick.
Here is a shot of the kit:
I bought my Maxima a few weeks ago and it had a scratch on the passenger side rear pillar. I figured it would be a good test of a more extensive repair involving the touch up paint, wetsanding and buffing.
Unfortunately, it was cloudy so the scratch doesn't look as bad as it actually is, plus the Lustre Grey color hides defects well. Anyway, the verticle part of the scratch is deep into the primer.
I had to mix two of the silver/grey touch up paints together and it still wasn't quite dark enough when applied so I added a few drops of metallic black and it was very close. I overfilled the scratch a bit to compensate for the wetsanding to follow.
I then wetsanded with 3M Imperial wet/dry (used it wet) 1500 grit followed by 2000 grit.
As you can see, using a folded microfiber towel and Optimum Compound by hand wasn't removing the wetsanding marks-no suprise, just wanted to show that you likely can't remove wetsanding marks without a buffer.
I then used my loaner Porter Cable 7428 rotary, a Soft Edge orange one step pad (amazingly smooth pad via rotary!) and Optimum Compound. Started off on 2, bumped it to 3 for several slow passes and it came out pretty much LSP ready.
I followed with Poli-Seal using another orange Soft Edge pad and finished with the new version of Optimum Car Wax.
It is not perfect, but before it was noticable from 10-15 feet. Now it is more like 2-3 feet, a pretty major improvement for not actually refinishing. There are a couple shallow areas I guess I didn't completely fill, so I'll probably go over them again when I have time.
Overall, the kit seems to be pretty good. Obviously, it won't bring the paint to the level proper repair and repainting would but it does make a pretty big difference. Plus, you wouldn't be charging body shop money either and as long as the customer understands that they can get a very noticable improvement for maybe 10-15% of the cost a body shop would charge, they seem pretty happy.
Scott's Mobile Auto Detailing
Old 12-08-07, 10:49   #2 (permalink)
Scottwax's Avatar
Re: Applied Color's paint touch up kit
Oh yeah, wetsanding was a piece of cake. I may go ahead and wetsand a few areas of my car where there is excessive orange peel.
Old 12-09-07, 07:46   #3 (permalink)
Bright Dynamics Owner
Jakerooni's Avatar
Jakerooni is online now
yea scott looks like you had a good start. Probably could use a better fill. I usually fill let dry fill and wetsand 3 or 4 times before it builds up enough to make it disappear. Not a bad start though. Keep practicing and you'll get to the point where you'll never even know a scratch was ever there from even 2 inches away.
Old 12-10-07, 11:54   #4 (permalink)
AppliedColors's Avatar
AppliedColors is offline
Scott,
You'll want to add 20% paint thickener to your paint mix. Apply paint to the scratch. Heat with a heat gun. Repeat. Repeat. Wetsand and buff. This should create a good "base" for one final layer of paint--reduced 20%--and applied carefully with a narrow brush. You won't get 100% fill, but with damage on a quarter panel, you'll get a 50 - 70% improvement on a scratch that would cost $600 - $1000 at a body shop. $600 - $1000 simply isn't in the budget for most vehicle owners and car dealerships. Paying a detailer $40 - $60 for a quality touchup is a logical compromise.
I saw in a different thread that you have rock chips across the front of your car. Did you get a chance to try the wipe on / wipe off method described in the manual? You won't get 100% fill, but at least the chips won't reflect white. Clean the area first with wax/grease remover. Apply the paint liberally, then remove the excess paint with a paper towel, wrapped around the foam block, sprayed with PaintLeveler. You'll likely entirely remove some of the "good paint"--the paint that's in the chip--from several chips. Simply tap these chips with the paint mixture when done.
APPLIED COLORS
PROFESSIONAL GRADE PAINT TOUCHUP KITS
Old 12-10-07, 12:24   #5 (permalink)
I don't have much to add
SpoiledMan's Avatar
SpoiledMan is offline
How much is that kit?
Black cars are fun!
Old 12-10-07, 12:27   #6 (permalink)
Scottwax's Avatar
Robert-still playing around with the kit a bit, the weather hasn't exactly cooperated as much as I had hoped...drizzle and 37 right now.
I wasn't sure when specifically I should add the reducer or the thickener, but when I go over that scratch again to get as good as possible, I'll try it with thickener.
Any chance of adding a color chart with the blends of two touch up colors to match colors that aren't on the color scale cards, or is that basically going to be a trial and error deal that one eventually learns to eyeball and just know what colors to mix?
Old 12-10-07, 12:28   #7 (permalink)
Scottwax's Avatar
$750 if I remember right.
Old 12-10-07, 01:08   #8 (permalink)
TH0001 is offline
Contact: Send a message via Skype™ to TH0001
You where able to completely remove all tracers with a PC? I usually need a couple passes with a heavy leveler and wool to get the all the sanding marks out.... Looks like a very cool kit, glad your having fun with it...
Old 12-10-07, 02:35   #9 (permalink)
ron231 is offline
Scott, if you wetsand your own car, go with the megs unigrit as opposed to the 3m. The 3m often is uneven and leaves some scratches deeper than the grit the paper is supposed to be.
Old 12-10-07, 03:35   #10 (permalink)
Scottwax's Avatar
ROTARY!!! I am using William H. Bonney's PC 7428. I used the Soft Edge orange one step pad and Optimum Compound to quickly remove the sanding marks.
Ron-all I had on hand was 3M stuff, but I do plan on going by my Meguiars distributor to get the Meguiars Unigrit paper in the very near future.
Old 12-10-07, 04:11   #11 (permalink)
PROServices's Avatar
PROServices is offline
Anyone heard of the "squeege" paint repair method? I do traditional touch up and SSR and some other guy in town uses this squeege thing.. from what Ive seen it it gets really impressive results when you have multiple chips in a front end. THe SSR rocks the house with individual scratches though but its pretty expensive.
Old 12-10-07, 06:32   #12 (permalink)
Jakerooni's Avatar
The "Detail King" keeps popping up in all my google searches for stuff like this. It looks like an interesting process they offer. A little on the high end if you ask me. But interesting none the less.
