Go Back   Autopia.org > THE CLUB HOUSE > SPONSOR FORUMS > Product Spotlights
Old 06-03-09, 09:44   #1 (permalink)
PBMA
Meghan@Autogeek's Avatar
Meghan@Autogeek is offline
Contact: Send a message via MSN to Meghan@Autogeek
Polish years off your vehicle with the FLEX XC3401 XMT Intermediate Swirl Remover Kit
When does your new car become just your car? It might be different for everyone, but it’s about the same time those little swirls and fine scratches show up on the paint. You washed it on the weekends and waxed it often. What happened? Inevitably, daily driving and even your detailing method have left their mark on the paint.
Don’t worry. Your vehicle can look new again. All it takes is the right combination of polishes and the right machine to remove the imperfections and restore the showroom gloss. The FLEX XC3401 XMT Intermediate Swirl Remover Kit makes it easy to attain the results you want. And you can continue to call your car “new”; no one will know the difference once you use this kit!
<“FLEX-XMT-int.jpg” caption: "The FLEX XMT Intermediate Swirl Remover Kit includes the FLEX Xc3401 Orbital Polisher. This polisher combines rotary-like paint correction with the user-friendly features of an orbital.” >
The FLEX XC3401 XMT Intermediate Swirl Remover Kit is designed to correct mild to moderate paint imperfections without the risks of rotary polishers. As you may well know, rotary (a.k.a. a circular) polishers spin very fast at a high speed and can therefore burn the paint quite easily. This kit includes the FLEX XC3401 VRG Orbital Polisher, a true orbital polisher. Orbital polishers are safe and, in the case of the FLEX, it removes swirls as well as a rotary.
The FLEX XC3401 VRG Polisher has a random orbital motion, much like a Porter Cable 7424. However, the FLEX has a longer stroke so the pad has a bigger orbit. The FLEX throws the pad 8 mm off center, resulting in a true orbital motion (less jiggle, more polishing).This bigger orbit gives the FLEX XC3401 superior correction abilities compared to a lot of DA polishers. Even with the increased performance, the FLEX XC340 is easy on the paint compared to a rotary. There’s still very little chance of burning the paint with the FLEX XC3401.
The FLEX XC3401 is a variable speed polisher. You can increase the speed as you become comfortable with it. It accelerates smoothly and continues to move in a uniform motion, even under load. The FLEX 3401 includes a 6 inch backing plate that works with all your 6.5 and 7.5 inch pads. Four Lake Country CCS Foam Pads are included in the FLEX XC3401 XMT Intermediate Swirl Remover Kit.
First, the orange pad is your go-to pad for swirl removal. It’s a dense foam that works on everything from water spots to oxidation to swirls.
The white pad is for lighter polishing. The white foam has some density to it but it’s not suited for leveling paint. Use it with finishing polishes and prewax cleaners.
Two gray pads are included. These are very soft. Use them for wax or sealant application. You might also use a very fine finishing polish to jewel the paint.
Now you know what your pads and polisher can do; that leaves the polishes. XMT Series swirl removers are formulated to be easy to use, not fussy at all, and easy on the paint. Diminishing abrasives break down to a fine polishing dust to prevent micro-marring. The XMT polishes are numbered with XMT #3 being the most aggressive in this kit and XMT #1 being the least aggressive. The XMT Carnauba Finishing Glaze is to enhance the shine after polishing.
<“xmt-volvo.jpg” caption: "XMT Intermediate Swirl Remover #3 was used on the right side of this black 1996 Volvo. You can see a clearer reflection and deeper color compared to the left side.” >
The order of application goes like this, assuming you’ve got moderate swirls and you need all three steps:
1. Attach the orange pad to your FLEX. Mist it with the included Pinnacle XMT Polishing Pad Conditioner. This product primes the foam to prevent that initial dry buffing caused when you put dry foam to paint. Squeeze a line of XMT Intermediate Swirl Remover #3 onto the pad and place it onto the paint. Set the FLEX on at a moderate speed and work your way up to that speed as you spread the polish. Make several passes until the polish appears to be broken down. Buff the paint with one of the included towels. If you’re not satisfied, add more polish and go back over the section again. Also remember that your next step will remove any light hazing. Work in 2 x 2 sq. ft. sections.
2. Next use the white polishing pad to apply XMT Ultra Fine Swirl Remover #1. This serves as your finishing polish. Follow the same steps as above.
3. Now put a gray pad onto your FLEX polisher. Apply a line of XMT Carnauba Finishing Glaze to the pad. Turn the machine on at a low speed. Spread the glaze evenly in a 2 x 2 sq. ft. section and then buff with a microfiber towel. The glaze contains carnauba to enhance the shine, but you really should apply a coat of wax for long term paint protection.
4. As you finish with each pad, take a moment to mist it generously with XMT Polishing Pad Cleaner. The cleaner will immediately start breaking up the polish residue in the foam so it’s easier to clean at the end of your detail session.
After using the FLEX XC3401 XMT Intermediate Swirl Remover Kit, you’ll definitely have that new car shine again. The aim of this kit is to be effective, of course, but also user-friendly. You don’t have to be a professional detailer to get excellent results with this kit. So, even though your new car is going to age, there’s no need for it to look old. With the FLEX XC3401 XMT Intermediate Swirl Remover Kit, you now have the products and tools to make your vehicle look new again.
The FLEX XC3401 XMT Intermediate Swirl Remover Kit is available from Autogeek.net.
Polishing Paint to Perfection DavidB Guide to Detailing 0 11-10-06 02:11
Paint Clinic DavidB Guide to Detailing 0 11-10-06 02:10
Using the Porter Cable 7424 Car Polisher DavidB Guide to Detailing 0 11-10-06 02:09
Klasse User's Guide DavidB Guide to Detailing 0 11-10-06 02:04
24 hour wait between coats of Zaino? 50th yr Car Detailing 23 11-18-02 04:35
