If you're one of the lucky ones who received a high definition television over the holidays – or a navigation unit or a new computer – you’ll want to read this. There's a new kit out that is going to make maintenance a breeze, and you can trust the results. It's called the Diamondite Multi Purpose Screen Cleaning Kit. This kit consists of Diamondite Multi Purpose Screen Cleaner and an assortment of the softest detailing tools you can buy. When you clean your display screen with Diamondite Multi Purpose Screen Cleaning Kit, you’ll know you’re treating it right.
The Diamondite Multi Purpose Screen Cleaning Kit includes
• Diamondite Multi Purpose Screen Cleaner
• 2 Cobra Felt Microfiber Towels, 12 x 12 inches
• 2 Cobra Microfiber Applicators
• 12 Cotton Detailing Swabs
• 1 Retractable Lint Brush
The Diamondite Multi Purpose Screen Cleaning Kit is the essential care package for all navigation units, display screens, monitors, and televisions.
Diamondite Multi Purpose Screen Cleaner is the easy way to take care of your electronics because it's an all-in-one product. It's a water-based, non-abrasive cleaner and protectant that removes dust, fingerprints, and smudges and leaves a clear, anti-static finish.
Don't be fooled by the word polish. In this case, it simply refers to Diamondite Multi Purpose Screen Cleaner's ability to remove the hazy fingerprints and smudges to give the screen a clean, polished look. There are no abrasives at all. By removing dust, smudges, and body oils (fingerprints), Diamondite Multi Purpose Screen™ clarifies the screen. The difference is pretty amazing on touch-screen navigation units.
Diamondite Multi Purpose Screen Cleaner will not create an artificial shine or glare on screens. If you have a no-glare LCD monitor, it will still be no-glare after using Diamondite Multi Purpose Screen Cleaner. Likewise, glassy, reflective screens will still have their shine. Your television, computer monitor, or display screen will look visibly cleaner but Diamondite Multi Purpose Screen Cleaner will not affect the screen itself.
Diamondite Multi Purpose Screen Cleaner is alcohol and ammonia-free, which is imperative for a screen maintenance product. These chemicals will dry out all plastics over time. Diamondite Multi Purpose Screen Cleaner is water-based and slick enough to protect delicate display screens.
To further help protect your screen from dust or abrasion, the Diamondite Multi Purpose Screen Cleaning Kit includes a retractable lint brush for pre-cleaning the screen. Use this little brush to whisk away any dust and debris before you apply Diamondite Multi Purpose Screen Cleaner. This brush is a quick way to dust the instrument panels any time, too. The bristles are silky soft, so they'll never scratch. When not in use, the brush retracts into its handle.
To use Diamondite Multi Purpose Screen Cleaner for cleaning, spray it on the screen and use one of the soft Cobra Microfiber Applicators to gently wipe the surface. The applicators have a looped texture that helps clean, and they’re made of very soft, split weave microfiber. Of course, microfiber attracts dust so you’re getting the smudge-removing benefits of Multi Purpose Screen Cleaner and the dust removal ability of the microfiber. If the screen or monitor is off while you’re doing this, you’ll be able to see the smudges more easily. Look at it from a few angles to make sure you haven’t missed anything.
Apply Diamondite Multi Purpose Screen Cleaner using the Cobra Microfiber Applicator to remove fingerprints and smudges.
Then use a cotton detailing swab to remove dust from the screen's crevices and corners.
Next use a cotton detailing swab to clean the corners of the screen where dust accumulates. Dampen the tip of the swab with Diamondite Kleen Screen™ and wipe out those edges. If your monitor or navigation unit has buttons as well, the pointed end of the swab is great for cleaning around buttons and knobs.
Finally, apply a fine mist of Diamondite Kleen Screen and wipe dry with the felt microfiber towel. This final anti-static coating will protect the screen from dust and fingerprints.
Next use a cotton detailing swab to clean the corners of the screen where dust accumulates. Dampen the tip of the swab with Diamondite Multi Purpose Screen Cleaner and wipe out those edges. If your monitor or navigation unit has buttons as well, the pointed end of the swab is great for cleaning around buttons and knobs.
Diamondite Multi Purpose Screen Cleaner leaves an anti-static, smudge-resistant coating that’s perfectly clear. How long it lasts depends on usage, of course, and touch screens will require more frequent application to keep those fingerprints from appearing. It takes so little Diamondite Multi Purpose Screen Cleaner to protect the average navigation unit, its still a great value. All the microfiber products are washable and reusable. (Remember, no bleach or fabric softener. Dry on low heat or air dry.)
Keep the Diamondite Multi Purpose Screen Cleaning Kit in your car, your desk, or your entertainment center for regular care and cleaning of your monitors, nav units, and televisions.
The Diamondite Multi Purpose Screen Cleaning Kit comes in this reusable drawstring bag, which keeps towels and applicators clean between uses.
Now that you’ve finally gotten your dream television, take good care of it. The Diamondite Multi Purpose Screen Cleaning Kit is the easy way to clean and protect all your LCD, LED, plasma, and DLP screens. Plus, it’s by Diamondite, the glass and plastic care specialists.
Save on the Diamondite Multi Purpose Screen Cleaning Kit for a limited time!
