Just finished doing a complete detail on this 2004 Vette. The paint was really nice and I decided to dry sand it with 4000 grit sandpaper. It totally helped bring out the clear coated metallic finish. This paper, when used dry, cuts into the finish much less than if you used water and the marring is barely noticeable. After buffing, it makes it feel so buttery soft, that I couldn’t help avoid doing it. The whole detail process took about 6 hours and came out flawless. I decided not to take any befores because the car was in decent shape. It just needed to be perfected as if it were my own car. Here’s what I did:
PREP:
Auto Magic(AM) Wash & Wax via ShMitt
AM Special Cleaner door jambs and engine
Power washed complete exterior of vehicle + floor mats
AM Magnificent wheels, tires and wheel wells
EXTERIOR:
4000 Grit Dry sand paper
Goof Off removal of tar
AM GS-1 via EDGE yellow foam pad
AM BC-2 via EDGE blue foam pad
AM Paint Sealant
AM Magic Dressing – Tires + Wheel wells
INTERIOR:
AM Special Cleaner scrubbed with tooth brush
AM Leather Conditioner – 2 applications
AM E-Z Clean HD Shampoo by hand
AM Clear Difference window cleaner
ENGINE:
AM Super Dress It
