Originally Posted by silvergray
What a transformation! The interior looks brand new!
BTW - What is OCP? Optimum product, I'm assuming?
Here ya go:
Optimum Polish
OR:
Optimum Polish is the most versatile, effective, and easy to use polish you will ever use! It can be used as a light compound, swirl mark remover, or a finishing polish, depending on your choice of buffing pad and speed of the buffer. It works quickly to remove (not hide) swirl marks, scratches, and other blemishes, while creating a perfect shine on all types of paint. It can be used with any type of buffing pad or buffing machine. Optimum Polish has excellent workability on painted surfaces and will not clog buffing pads. Aggressive enough for paint correction and swirl removal, yet the shine, clarity, and gloss of the paint left behind requires only final protection.
Directions:
When using a wool buffing pad, Optimum Polish will remove 1500 sand scratches and lighter at 1000-1400 RPM. Faster buffer speed is not needed with this product. When using a light cut foam pad at 1000-1400 RPM the polish will remove 2000 and lighter sand scratches on most paint surfaces. A final finishing foam pad will remove swirl marks at 1000-1400 RPM.
Always use enough product to create a barrier between the buffing pad and the paint surface. Wipe off residue by misting Optimum Car Wax on it and wiping it with a microfiber towel for a steak-free perfect finish. Can be used by hand or with an orbital or high-speed buffer. This product contains no silicone or wax. Both Optimum Polish and Optimum Car Wax meet all VOC regulations and are body shop safe.
Deanski
DR SHINE
Member: PCWA
Member PCA-CVR
