| I've tried a few "specialized" slip solutions and I found no real advantage or disadvantage, one way or the other. With the cost of J&J shampoo, using only a small amount, the cost is negligable. I think Llumar is about the easiest to work with, but I haven't used EVERY brand out there. There are some I will not use again, but past experiences with giving my opinion on products I don't like have gotten others in hot water. I don't want this site to end up like others that I've seen: members fighting and arguing as to a products ups and downs, and the site admin catching flak from manufacturers claiming slander.
As for the question on extra for wrapping edges, it depends on several things. Some companies that cut out patterns leave enough for wrapping, others do not. I use bulk material and I cut freehand. Using software and a plotter reduces waste by using as much as possible of the width of the roll but makes the mobile install a real pita if you screw a piece up and have to go back to your shop to cut a new piece. |
