By joining our FREE community you will be able to interact with others. Registration is fast, simple and absolutely free so please, join our community today. When you join, this box is replaced with our live chat! |
11-19-09, 04:40
Rickrack79@hotmail.com
RickRack is offline
2010 Porsche GT3 in Guards Red (Clear-bra install, Spoiler repair & Detail) by UCC
This gorgeous 2010 Porsche GT3 in Guards Red was scheduled for a general cleanup and clear film install (clear-bra). The owner plans on tracking the car and wanted to make sure that all critical areas were covered in film to ensure that no damage was done and keep the car looking its best. Despite being new, the owner had a slight mishap and damaged the front lip spoiler. I told the owner I would repair the spoiler while it was at the shop.
Upon arrival, the car was already in great shape, which is expected being a new car. I started by giving all of the wheels, tires & wheel wells an extensive cleaning.
All tires and wheel wells were cleaned with Kleens degreaser and agitated with a soft bristle wheel brush as seen below.
The wheels were treated with P21S wheel cleaner and agitated with various brushes to get every square inch of the wheels spotless.
Once I completed the steps above, I gave the exterior a thorough rinse, paying special attention to all of the cracks & crevices where sand and dirt usually accumulate.
Once the vehicle was rinsed free of all loose dirt and contaminants, I soaked the car in foam using a Gilmour Foammaster II foam gun. I mixed a bit of degreaser in with the soap to help strip away any protection that may have been present.
By allowing the foam to dwell on the surface for several minutes, it helps loosen any grime that is on the surface and reduce the chance of marring the paint when performing the wash. After allowing the foam to dwell for several minutes, the exterior was rinsed for a second time with lots of pressure to remove as much contamination as possible.
Next, the exterior received a hand wash to prep the paint for the clear-bra install the following day.
After the wash was complete, all surfaces were dried and all door, hood & trunk jambs were wiped clean with a microfiber towel. In addition, all cracks & crevices were blow with compressed air to remove any excess water that was hiding…
Now that the paint was clean, I carefully inspected the paint to make sure it was absolutely perfect before the clear-bra install. Although this car was brand new, I did notice some sanding tracer marks on the front bumper, which were overlooked by the factory.
I masked off the front spoiler with blue painters tape and polished all areas being covered with the clear film using Menzerna PO203S on a white foam LC polishing pad, followed by Menzerna PO85rd using a black foam LC finishing pad. After all polishing was complete, the surface was wiped clean with 91% alcohol to ensure that all carrier oils left from the polish were completely removed. This did a great job clearing up any imperfections and left the surface ready for the clear film install the following morning.
Because the owner planned on using the car the way it’s supposed to be, he opted to have a custom kit installed to the front of the car as well as the bottom rocker panels, behind the front & rear wheels, door jambs and the back of the carbon fiber seats. This is a very smart idea, since the car would be visiting the track often and will protect the super soft Porsche paint from getting chipped up.
Door jambs covered in film…
Carbon fiber seats covered in film…
Partial hood & complete front bumper covered in film…
Once the clear-bra install was complete, I inspected the damage to the front spoiler to see what supplies would be needed in order to make it look new again. Below is the extent of the damage…
I took a ride to the local body shop supply store to pick up the necessary supplies to complete the repair. I asked them what products would yield the best results for a factory look. They recommended that I sand the spoiler with 400 grit sandpaper, clean the surface with prep solvent, then apply multiple coats of SEM Black Texture Coating.
Before attempting the repair, I carefully masked off the spoiler with masking tape and covered the rest of the car to make sure no overspray made its way onto the paint. To save a little time, I sanded out the defects using my pneumatic sander using Micro Surface sanding discs.
After most of the defects were removed by machine, I sanded the spoiler a second time by hand using 400 grit sandpaper. Since the car is going to be driven at the track often, I decided to go easy on the sanding to make sure there is plenty of surface left if it needs to be repaired again in the future. I decided to leave some minor defects, which I was hoping would be filled in by the coating. Here is the spoiler after sanding out the major defects…
Once all of the sanding was complete, I wiped the surface clean with prep solvent to ensure a perfectly clean surface. I applied 3 thin coats to the spoiler with about 5 minutes between coats. It went on very nice and gave the spoiler a flat black look. To be honest, it was not the look I was after (I wanted a satin finish), but decided to leave it because the owner needed the car the following day.
Here is what it looked like after the repair…
As you can see, the repair came out great, but I was not happy with the sheen of the coating. I decided to leave it for the time being and told the owner I would give it another shot the next time the car was in for a detail.
After the spoiler repair was complete, I inspected the rest of the car for any imperfections before the application of a paint sealant. I discovered some leftover cosmoline residue on some of the panels, which the dealer forgot to remove as you can see below. To remove the adhesive, I used a microfiber towel saturated with acrylic solvent, which worked great.
Now that the paint was free of any defects and all of the cosmoline residue was removed, I applied a thin coat of Blackfire Wet Diamond paint sealant to the entire exterior, including the clear-bra using a gold CCS concours pad.
I let the Wet Diamond set up for about 20 minutes before removing with a fresh microfiber towel. Next, I sealed the wheels and exterior glass with Opti-Seal, then dressed all tires & wheel wells with Super Blue tire dressing.
The exhaust tips were black and were looking a little dirty…
I sealed them with some Bilt Hamber Auto Balm…
Rick Nelson
Unique Car Care (owner)
Wakefield, MA
11-19-09, 04:45
RickRack is offline
Re: 2010 Porsche GT3 in Guards Red (Clear-bra install, Spoiler repair & Detail) by UC
For the interior, my goal was to do a light cleaning and add some protection to all plastic, vinyl, leather and Alcantara (suede) surfaces. First, I blew out all cracks & crevices with purged air to remove as much loose dirt / dust as possible and gave the interior a thorough vacuum.
Since the car was brand new, the Alcantara surfaces did not need to be cleaned, but I wanted to make sure it was protected and make cleaning easier in the future. All Alcantara surfaces were treated with Leather Masters Nubuck Protection as seen below.
Next, I cleaned all interior surfaces with a damp microfiber towel saturated with1Z Einszett Cockpit Premium and used a variety of brushes to get into hard-to-reach areas. All surfaces were blown off with compressed air to minimize dust from sticking to the damp surface.
After all interior surfaces were clean, I treated all vinyl surfaces with Meguiar’s Quick Interior Detailer for UV protection and a factory sheen.
Finally, the interior windows were cleaned and the carpets received a final vacuum before I installed the floor mats, which I had covered in protective plastic.
Interior after…
Rick Nelson
Wakefield, MA
11-19-09, 04:48
RickRack is offline
Rick Nelson
Wakefield, MA
11-19-09, 04:49
RickRack is offline
Rick Nelson
Wakefield, MA
11-19-09, 04:52
RickRack is offline
PART 2……. A few weeks later!
So this is what the car looked like a few weeks later after a visit to the track...
Maybe it’s just me, but it sure looks like the front of the car is smiling… I’m sure it has to do with being able to spend some time on the track!
As you can see, this GT3 does a great job killing bugs!! In addition to the bugs, it had its fair share of rubber and accumulated dirt on the finish. I’m sure there would have been a few stone chips as well if the owner decided not to install the clear film…
The owner wanted a quick cleanup and some additional clear film pieces installed to the lower rocker panels to protect the areas from stone chips at the track. I also planned on taking care of the spoiler to see if I could make it look a little better, since I wasn’t 100% happy with the way it came out.
I started off by soaking the car down with foam to loosen up as much dirt & grime as possible.
For the washing process, I followed the same steps mentioned previously. Since I had applied Blackfire paint sealant a few weeks prior, the paint was well protected and everything literally fell off the car. After the vehicle was washed, dried and all jambs were wiped clean, I decided to see what I could do with the front spoiler.
After masking-off around the spoiler with blue painters tape and covering the car in plastic, I cleaned the spoiler with 91% alcohol to make sure it was free of any wax or silicone that could cause improper adhesion of the coating and/or cause fish eyes in the finished product.
Next, I sanded all areas with 400 grit sandpaper by hand…
Before applying the coating, I blew off the spoiler with compressed air and wiped it clean with 91% alcohol using a lint-free cloth to ensure a perfectly prepped surface. I applied 2 thin coats to the spoiler about 5 minutes apart and applied the third coat a little heavier to add a slight textured look to it.
After the coating dried, I was very happy with the end results. It was exactly the sheen I was looking for and could pass for being stock. If you look really close, you can see some minor scuffs in the spoiler, which I left purposely in case this should happen again in the future. This way, there will be plenty of surface left for future repairs. Below is the final product…
Much better!
Now that the spoiler repair was complete, I decided to apply some Collinite Marque D’Elegance Carnauba Paste Wax #915 by hand for added looks and durability.
Last but not least, all windows were cleaned, the tires were dressed and another coat of Opti-Seal was applied to the wheels to protect against brake dust.
Here are a few random during/after pics…
Rick Nelson
Wakefield, MA
11-19-09, 06:10
Bright Dynamics Owner
Jakerooni is offline
Awesome Awesome Awesome Rick! Hey I think I missed it but the coating on the bumper the 2nd time around. It wasn't the same as the first? Looks to be a different color (or maybe it's just the sheen) What made the difference there?
11-19-09, 06:14
Senior Moderator
Pats300zx is online now
Social:
WOW....What a car Rick. Fantastic work.
The bumper repair came out amazing.
11-19-09, 06:15
Esoteric Auto Detail
TSC17 is offline
Rick...once again raising the bar! It's great that you're offering much more than just polishing services. And tackling the front bumper was a sign of a true pro.
Wonderful work my friend, and an informative write-up as well.
It looks like the shop is coming along nicely!
Todd Cooperider
Esoteric Auto Detail, LLC
11-19-09, 06:18
Boyce The Choice
TheMethod is online now
Amazing work all around Rick! Your shop looks reallllly nice too!
Boyce the Choice
11-19-09, 06:28
bcgreen is offline
What paint do you end up using on the spoiler?
I may end up doing the same to one of my cars
11-19-09, 06:35
RickRack is offline
Jakerooni- Thanks a lot, Jake!
Not sure if you read the whole thread, but I wasn't happy with the way the spoiler came out the first time I did it, so I used a different product the second time around. The first product I used was flat black, but didn't look right, so I sanded it down and used a coating with a satin finish which was the look I was aiming for.
Pats300zx- Thanks Pat!!
I definitely fell in love with this car while it was at the shop (if you couldn't tell from all the pictures!). I had the chance to drive on a while back and it is definitely the sickest car I have EVER driven! I would definitely lose my license if I owned this car!
TSC17- Thank you very much, Todd!
I do quite a bit of clear-bra installs and have a few other services I offer in addition to detailing.
The shop is almost there... I am hoping to get my T5HO lights up soon and get the floor refinished between the holidays if things ever slow down...
TheMethod- Thanks a lot!
Rick Nelson
Wakefield, MA
