Kaval, that's some 1337 work on those Honda lights!! The JDM Integra lights look awesome.
Originally Posted by vtec92civic
All i can say is wow! Those lights are crystal clear! I don't think one would be able to tell those from one's brand new and out of the box.
Question for you. Can all lenses be brought back and how do you determine that? I had some trouble with some BMW X5 headlights. Things drove me crazy. Didn't come out the way i had hoped they would ya know.
Great work though!
Most
headlight lenses are VERY hard and can be safely sanded down. Also they are quite thick. Even after some vigorous sanding, you're barely removing any plastic from the lenses.
However, when polishing the lenses with a compound, heat can be quite an issue. There are many
headlight restoration "kits" out there thrown together for drill applications. I find the electric drill to be too tedious to operate. While spot repair air-driven drills are workable because of their weights, I find the electric drill too heavy for proper polishing. Rotary is the best machine to use even for headlight restorations.
