09-05-09, 05:46
dsms is offline
dsms detail - 3 days with an Aston Martin DB9...
2008 Aston Martin DB9 Sport Pack
Car was booked for a 3 day full correction and show preparation.
Wheels came first, tires pre cleaned using ARO. P21s wheel gel was left to sit for a few minutes, even though the wheels were very dirty I just dont believe in letting wheel cleaner sit on the wheel for 20 or 30 minutes. If it works, it will do the job in a few minutes or so... otherwise you need a stronger wheel cleaner but thats just my opinion.
Behind the spokes, calipers, hub mounting face etc. all cleaned with various brushes. Wheel wells received APC 4:1 scrubbed with a MF mitt.
Everything was rinsed thoroughly...
After, inner barrels de-tarred with Tarminator later on before polishing.
Paint was rinsed at high pressure, then foamed using a mixture of CG maxi Suds and a Biodegradable APC to help strip some of the prior LSP
Rinsing off the foam
2 bucket method carried out using CG citrus wash and clear.
Before the sun came back out I pulled the car inside to dry it and begin claying. Megs mild clay and ONR lube were used. The clay picked up a good amount of grime, some areas like the hood and truck were clayed twice.
Before starting correction I worked on the interior
Interior, although small took me about 2 hours to get back to 100%. All plastics, glass, trim, doorjambs and leather were treated.
Doorjmabs were hand polished and sealed, the rubber trim around them was dressed with TRV too.
Some finished shots (Passport 9500i properly hardwired and discrete like it should be, so many of my customers have valentine 1 wires hanging from the windshield:shakehead
The aluminum trim around the shiftboot was hand polished using wet mirror finish, which has proven to be a killer all around product. After
Trunk jambs were cleaned and sealed as well...
during
After...
After claying the car was given 2 IPA wipedowns to ensure all prior waxes or sealants were stripped off as well as any clay residue. Good test to see if the finish is well stripped if to place your finger tip on a panel and gently rub, if it squeaks instantly your usually okay to move onto correction.
All delicate areas and trim were tapped off. Paint readings were taken after that, the driver side front fender had been repainted but was a surprising perfect match to the rest of the car.
(Yes I got a haircut as the heat was getting to me)
The front nose and headlights had clear film protection. I started with those areas. While the paint was rotary corrected I found that Bob's DA method works best on the clear film.
I used the Flex 3401 and a polishing pad with Menzerna 106FA to correct, and then followed up with 106FA again on a finishing pad. I like the FA on the film because its pretty oily so it helps keep the heat down.
Under the halogens
The car had some RIDS and wash induced stuff. Nothing major but this was not a 95% job, this was a 100% so I chose a 3 step process which would properly correct and finish down the paint the way I wanted it.
Menzerna Power finish w/ a polishing pad
Menzerna 106FA w/ a polishing pad
Menzerna 85rd w/ a glazing pad
Working the hood with Power Finish. I started at 1100,1500, 1900rpm then backed down to 1100rpm. I finished down each stage as thoroughly as possible to really ensure the finish was properly leveled.
This being an Aston my main concern was sanding scratches which come from the factory. The car seemed to get away clean except for a few select areas like by the lower blinkers.
This same area on the blue vantage Bob and I did has a ton of issues. Spotting them in the halogens on the silver was tough but with the lights off in the garage the fenix picked up some pigtailing and RIDS.
I switched up to M105 with a 3" tufbuf wool pad, and then followed up with the 106FA and 85rd again.
Some various correction shots...
Working 85rd with a 3' finishing pad
The passenger side had a tiny scratch just above the door handle. After a few attempts at compouding it didnt budge so I had to wetsand it with 2500grit and follow up with the wool. Its lightened a bit was not able to be removed 100%.
Some more cut was needed on the passenger side so I stepped up to the DD yellow cutting pad from the green. Very surprised at the level of cut and finish you get with this, much more smooth than the orange foams.
Powerfinish breaking down
Trunk under the halogens, 2 steps down.
After correction..
Some old wax residue by the plate
Fixed
09-05-09, 05:48
dsms is offline
Re: dsms detail - 3 days with an Aston Martin DB9...
Dressing applied on front cover as well
Under the hood was cleaned and sealed using Werkstat, in an area like this a sprayable selaant really helps.
After cleaning and sealaing...
The DB9 had a QuickSilver exhuast system, even at idle it just sounded great. Stock tips kept everything looking as it should however, I like that.
Tailpipes before..
polishing with #0000 steel wool and white diamond metal polish
After
Lower rear valance was dressed as well for a dark matte finish
Wheels and brakes were hand polished with CG wet mirror finishm then sealed with 2 coats of JW acrylic jett
All finished with the undercarrige dressed
Glass was hand polished and then sealed using Werkstat again
All metal trimwork polished as well...
Wiper cowl cleaned and dressed
As a finishing touch I like to spay some lightly scented de-odorizer in the interior. Back in the day (about a whole 2 years ago) I would spray some Febreez but Bob showed me Ozium (glycol-ized air fresherner) and I loved it.
I like the smell of well treated leather but I also want a lasting fresh scent in the car when the owner opens the door.
After all the finishing touches were taken care of I applied.... a carnauba wax? :shead:
To be honest I have not put a nuba on my own or a customers car in about 8 months, I just prefer sealants. But I decided since the Aston was on its way to a show (concourso type event) than a nice nuba may add something to the finish.
Phil gave me a sample of the new Lusso Oro wax to try and I figured this would be a great test bed. I applied one thin coat to the DB9 and let it cure for a little bit and buffed off. It is a very very hard wax, but goes on very smooth and buff off easy.
I had no issues with sweating either as I went back and checked the finish hours later.
Okay, enough of my longwinded explanations and some final shots...
Of course, cloudy skies however:waiting2:
(The plate is just too cool to blur out)
Before the rain came I pulled it back in
Halogens only as backlighting
Total time: 22.5hrs
Always enjoy these longer details, get a chance to do everything all out.
Thanks for looking
09-05-09, 07:03
Goose is offline
Great detail! Car looks amazing, time well spent.
The brushes that you are using to do the rims and the interior.. both have long handles (one black the other wooden) and have red on them...
Who makes them and where did you get them?
1995 MTX SHO
58k
09-05-09, 07:06
moorfan is offline
Absolutely beautiful!
Please help me...what is TRV? I can't find it in the decoder ring?
09-05-09, 07:17
Got_Leather is offline
Awesome Dave, just awesome. I'll have to make my way up there sometime and do some work with ya. Great job again buddy.
DJ Mayo
Reflections Detailing
Paint Correction Specialist
09-05-09, 08:16
BMW Fanatic
jopa489 is offline
Looks fantastic, Dave! Thanks for sharing and great write up!
09-05-09, 09:16
Hi.I are Paul.
dmw2692004 is online now
looks amazing! great write up!
Owner
09-05-09, 11:03
ninobrn99 is offline
Wow, I've got 2 friends that have recently detailed a DB9. They didn't get to keep them for 3 days. Great work!
Hitachi SP18VA and PC-XP
09-06-09, 12:08
AZ Ferrari Man is offline
Looking great! I have a few questions. The leather, did you use the gloss it leather conditioner, and what type of applicator do you use to apply foam or mf? On any vinyl interior pieces and exterior black plastics did you use TRV and then buff it to achieve the matte finish? The Mirror wet glaze you use, have seen any durability from it? Thanks for your help!!
"Treat every car as if it was your own"
-Every Detailer
09-06-09, 12:32
thump_rrr is offline
Gloss-it's 16oz T.R.V. Protectant and Dressing
09-06-09, 05:14
Advance Paint Correction
bufferbarry is offline
Your a machine. This car looks awesome. You did another great job. Ill bet it killed ya not to get sun shots on that one. I know here in pa its rain, rain, rain. grrr but great detail bud!
Barry Theal
Presidential Details
