06-16-09, 05:59
dsms is offline
dsms detail - Porsche Turbo S full correction
2005 atlas gray Turbo S booked for a 2 day full paint correction detail
The car is kept very clean, first thing I noticed was the lack of brake dust on the wheels. Even still a full cleaning had to be done to ensure everything was up to the standard.
Gloss it wheel gel was used at 5:1 Yep even at 5:1 you still get solid cleaning ability. Me working the daytona brush on the inner barrels. This car had the porsche factory carbon ceramic brake kit as well.
Some brake dust settled in the calipers, after a little agitation with the SV brush and wheel gel it lifted very easily.
The inner barrels had some tar deposits which were lifted using AS tardis. The tires were cleaned with ARO at full strength to remove the old tire dressing which was fairly thick. After that didnt remove it all i followed up with tarminator and scrubbed for a minute or so and the tires finally came clean.
Tardis doin' work...
After the wheels the wash process began. The paint was pre reinsed at medium presure to remove as much surface dirt as possible, a lot of people like to quickly rinse and then foam but I like to rinse at pressure for a long time before foaming
Foamed with the camspray at CG maxi suds mixed with CG citrus wash clear
After 5 minutes or so, one last rinse of the foam and then the 2 bucket wash. The car was wearing some sort of protection (spray wax) so again CG citrus wash clear was used to help remove it.
Before the 2 bucket wash all the crevices and emblems were agitated with APC 10:1. Trying to fully clean these areas after the car is dry is very difficult without marring the finish badly.
The engine was lightly cleaned using DI water in a pressurized sprayer, not a pressure washer. P-car engines have a lot of exposed wiring, intake etc so I'd rather not drench everything with water.
Before the final rinse I cleaned the ragtop with, uh... Raggtop:thumb: and a SV brush
Before the rain came I pulled the car inside for claying. A very mild clay was needed for this one, Sonus fine green worked well using ONR 6:1 as lubrication
After 1/4 of the car
After claying I did 2 IPA wipedowns to prep the paint for polishing, just in case the citrus wash clear did not remove all the old wax protection. The I took my paint readings, a little inconsistent for a Porsche but nothing too bad
Just to show you the difference bewteen paint thickness and clearbra thickness...
Paint
Clearbra
All trim areas were then taped off
After a test spot I landed on a solid two step combo. The paint (as expected) was very sticky. First thing I grabbed for were my Gloss-It polishes and the Flex 3403... on the last 5 sticky paint porsches I have worked on the Gloss-it polishes have never failed me. I normally prefer to use the rotary but I was able to correct even the deeper defects on this one with the 3403 and a cutting pad, the rotary however was used for the finishing/jeweling stage in conjunction with EVP.
-Gloss-It Extreme cut w/ GI white fast cut foam pad (flex random)
-Gloss-It Evolution polish w/ DD blue finishing pad using Gloss-It EVP (makita/flex rotary)
The hood under halogens, not much fine swirling but a lot of RID clusters
The hood required 2 hits with the extreme cut to remove all the defects
Before
After
Closer up
The entire front nose was protected with a clear bra. I started out with a very gentle polish and pad and moved up in aggressiveness as I found the deeper scratches were not being removed.
Here, using the makita, DD green med. polishing pad and evolution cut w/ a little extra GI EVP to keep the heat way down on the clear bra
Clear bra after polishing
Moving around the rest of the car, front fender before correction
After 2 hits with GI extreme cut
50/50
And after jeweling...
The area by the convertible top had some more severe defects, I immediately broke out the Flex rotary and 3" GI BP... the flex 3401 would not have fit in this area at all
06-16-09, 06:01
dsms is offline
Re: dsms detail - Porsche Turbo S full correction
rear wing/convertible area was also in bad shape, this required 2 hits with M105 (DA version on the rotary), followed by evolution cut, followed by evolution polish to fully correct
Before (taken with a point and shoot)
After
After
The final stage of jeweling helped refine out the last bit of fine holograms and bring up the gloss and calrity
Working the evo polish w/ the makita and GI EVP at 1500rpm before refining the finish at around 1000 for a few minutes
End result, captured with a proper camera this time
The taillights were corrected with Menzerna powerfinish ... before
After correction
Working the rear bumper with a GI cutting pad, 3" BP and extreme cut
After finishing
Worked my way around the rest of the car, back to the flex random machine for the larger flat areas
a 50/50, no more haziness
finished, under standing halogen and straight camera flash
Some jeweling shots...
I finished all the correction work around 9:30pm on day 1, I wanted to leave the finishing stage for the next morning but had a feeling I would need the time to work on other areas.
I made the choice to stay in the garage for a little longer to at least get a START on the finishing polish stage... I ended up jeweling the entire car that night, I hate leaving a half polished car for the next morning. I finished up a little after 2am :
Before I went to bed I snapped 2 shots after everything had been finished down a jewled, pics taken after IPA wipedown
And one under my little light of truth, Fenix TK10
Start of day 2, even with the correction done there was still a lot of work ahead of me.
The ragtop store area needed a good vaccum, I started with the shop vac but couldnt get the hose all the way in where I needed without touching the paint in some way so I used the "household" solution...
06-16-09, 06:03
dsms is offline
06-16-09, 06:19
TroyGLI is offline
Incredible detail, that thing looks beautiful.
06-16-09, 06:30
AJ Auto Detail, LLC
ajnavo61490 is offline
wow nice work on one badass Porsche!
looks like the owner has a few more toys to play with
AJ Auto Detail, LLC
06-16-09, 06:32
Advance Paint Correction
bufferbarry is offline
There is only one thing to say here FTMFW. There is no way to hide a perfectly corrected car in the sunlight. Take notes guys. This is how its done! PERFECT. Great write up, Great detail. I think I need to look more into this gloss it stuff.  David very nice.
Barry Theal
Presidential Details
06-16-09, 06:37
Bigpoppa3346 is offline
Lookin' good!
What do you think of the Daytona Speedmaster Brush? Really any better than the EZ Brush or just Autogeeks marketing hard at work?
06-16-09, 08:49
boostwagon is offline
great details as always. i wish i had the high rate of clientele getting the kind of details you always get to do.
-Matt-
Paint Perfection Specialist's l Serving All of South Florida's Buffing Needs
Removed contact info and picture from signature; neither are allowed at Autopia. --moderator
06-17-09, 04:50
Esoteric Auto Detail
TSC17 is online now
Very nice indeed David! Your passion for perfection shows in the work, the photos, and the great write up. Thank you for sharing! You know me...I like a lot of great photography and writing.
Todd Cooperider
Esoteric Auto Detail, LLC
06-17-09, 05:50
Senior Moderator
Pats300zx is offline
Social:
Fantastic work David. Great writeup as well.
06-17-09, 06:29
SCoach is offline
I was told not to polish on the clearbra, so I left it alone on the Porsche I did... Great job one the car!
1991 Range Rover Black on Tan (gotta submit to the before and after contest)
2002 Subaru WRX Midnight Blue Pearl
