Old 04-20-09, 09:45   #1 (permalink)
1337 Shine Guy
kaval's Avatar
kaval is offline
Cool Make It Shine: 2008 Toyota Highlander
Hello everyone!
Here is a beautiful 2008 Toyota Highlander in Salsa Red! It was purchased last year and has not received any proper detailing until now. I was glad to be able to work on this, as I really wanted to see just how vibrant the colour could look. The dealership had done a relatively good job of caring for the vehicle in the time it sat at the lot and got driven by a few potential customers. Yes, there were some swirls, but nowhere near as bad as I’ve seen Toyota paint. Up to this point the vehicle had only received a couple of washes, so I expected the rims to be quite bad.
Walkaround:
Engine bay was in need of some attention:
To begin, the engine bay was cleaned. The fuse box, distributor, battery and alternator were covered with plastic bags and tied securely to prevent any water from causing damage to the electronics. A pressure washer was used to rinse excess dirt off. Pressure setting was set to 1/3 full to reduce the risk of water entering unwanted areas. Following this, P21S Total Auto Wash was liberally sprayed over the entire bay and left to sit for 3 minutes while I prepared my wash solution. Upon returning, the components inside the bay were agitated using a Meguiar’s Versa-angle brush, and rinsed with the pressure washer at 1/3 full pressure. After removing the plastic bags, the engine was started and left to run for approximately 5 minutes to help evaporate water. After the detail, the rest of the bay was dried with towels and dressed with Shining Monkey Tire Shine
Engine Bay Afters:
On to the body...
Washed with CWG @ Paint Cleanser dilution and dried with WW MFs.
Wheels were cleaned with P21S Wheel Gel. Wheel wells were cleaned with Kleenol and a stiff bristled brush.
The paint was quite contaminated on the lower portions of the vehicle, as indicated by the following picture:
After claying was completed, the entire vehicle was wiped with Isopropyl alcohol to help remove the polymers from ONR clay lube that would interfere with polishing.
For polishing, Menzerna Intensive Polish and an LC Black pad were used at 1400 RPM.
After the paint was carefully polished to a high gloss, it received a foam wash to remove the polishing oils from the Intensive Polish and create a proper bonding base for the LSP.
For LSP, I chose 476S for it’s durability, and distinct look that really made this paint shine. Unfortunately by the time I was done, the sun had gone down, so these pictures are the best I could get.
Final Afters:
Thanks for looking!
Kaval
Make It Shine Automotive Detailing
Old 04-20-09, 09:49   #2 (permalink)
Concourse d'Elegance
stiffdogg06's Avatar
stiffdogg06 is offline
Contact: Send a message via AIM to stiffdogg06
Re: Make It Shine: 2008 Toyota Highlander
Looks awesome Kaval!
Love the SUV but that "limited" emblem on the door is a look killer...
Turbo D Club Member #000001
Old 04-20-09, 10:06   #3 (permalink)
resek's Avatar
resek is offline
Very impressive Kaval!
Only Menzerna IP and it does the trick! wow!
So, considering the fact that you did a one-step polish using IP, we could say that this toyota paint was kinda "soft" ?
Very good improvement in the engine bay, wow!
The 'before' pictures probably look like a lot of car here in Canada that see hard winter! héhé
Again, very nice job!
New to real car detailling.
2004 Flame Red Dodge SRT-4
Old 04-20-09, 10:14   #4 (permalink)
1337 Shine Guy
kaval's Avatar
kaval is offline
Thanks man. The cool thing about this model is that Toyota put a lot of thought into the small details. What's nice about the Limited badge is that when you approach the vehicle at night, there is a light underneath the mirror that lights up the badge, as well as the ground so you don't hit anything while entering the vehicle. The badge looks pretty cool at night. The interior also has some nice touches too.
Thanks resek! IP on a black pad is pretty good. I actually tried FPII on the other half of the vehicle and found it did a better job for gloss, but I wanted slightly more cut so I continued with IP.
No doubt we had a very tough winter this year.
Toyota paint is definitely soft, and quite thin unfortunately. There were a couple of stone chips to the metal on the hood, and you'd be surprised to see that it didn't take much to get to metal.
Old 04-20-09, 11:15   #5 (permalink)
06 F150
jordanrossbell's Avatar
jordanrossbell is offline
Contact: Send a message via MSN to jordanrossbell
Great work Kaval, i really like the vehicle
Old 04-20-09, 11:33   #6 (permalink)
Blake's Avatar
Blake is offline
Gorgeous Colour! Super job under the hood. Not familiar with the Shining Monkey but it sure seemed to work well at finishing off your work.
"If we weren't all crazy..We'd all go insane" Jimmy Buffett
Old 04-21-09, 06:22   #7 (permalink)
1337 Shine Guy
kaval's Avatar
kaval is offline
Thanks!
Thanks Blake!
I was turned on to Shining Monkey by a fellow member here. The kits were on sale for like 10 dollars, so I grabbed one and experimented. I'm quite impressed with their line up for OTC. Some really great stuff. The tire shine smells absolutely amazing too.
Old 04-21-09, 06:40   #8 (permalink)
dublifecrisis's Avatar
dublifecrisis is offline
This latest highlander is one of the few 'cute-utes' that, as a MAN, I would consider owning. I'm not the rough tough redneck type but crossovers never appealed to me.
This Highlander however has just a hint of landcruiser-esque stance and look to it. (darn near a landcruiser-esque price too...LOL)
Fantastic job all around. That collinite looks to have deepened the color a bit too. Not just because the lack of light. It looks deep and wet.
Old 04-21-09, 09:02   #9 (permalink)
Sam's Auto Detailing
artikxscout's Avatar
artikxscout is offline
Contact: Send a message via AIM to artikxscout
interesting combo with the black LC pad and IP. That's the first time I heard of that, but it came out very nice.
-Sam
Serving Northern California (East Bay) from
San Francisco, Berkeley, to San Jose.
Old 04-22-09, 02:36   #10 (permalink)
Advance Paint Correction
bufferbarry's Avatar
bufferbarry is offline
kaval nice work man, that highlander looks sweeeet.
Barry Theal
Presidential Details
