Old 04-05-09, 04:06   #1 (permalink)
Esoteric Auto Detail
TSC17's Avatar
TSC17 is offline
Contact: Send a message via Yahoo to TSC17
08 Lexus RX350. Esoteric Auto Detail
2008 Lexus RX350 Pebble Beach Edition in Truffle-Mica.
I’m not sure where the Lexus design/marketing team came up with the color name “Truffle-Mica”, but I’m glad they came up with the color! The Pebble Beach Edition is the only RX model that this color is available on. It has hues of grey, copper, blue, purple, and even a little bit of green too. The color varies slightly depending on the type and angle of the light, sometimes giving it a grey look, sometimes copper, and sometimes a slight look of purple.
The owner of this vehicle also has the 08 LS460L that I worked on a few weeks ago, and both of them are scheduled for every 4 months with me.
Other than being in need of a thorough cleaning, this one was in pretty good condition with the exception of some heavy scratches on the rear bumper, and some that went down the entire right side of the SUV. We agreed that the best approach would be a (modified) one-step polish, with a focus on reducing the severity of the scratches as good as I could. The interior would also need some work to clean up for the Ohio winter, but he said that a light cleaning would suffice. We were not going for a full-correction job.
Here’s the RX350 when it arrived:
First up was a wash of the exterior. My go-to wash when preparing for polishing is Chemical Guys Wash & Clear. I also used P21S Total Auto Wash to pre-treat the front end, and to clean the wheels, tires, and wheel wells.
After washing, I clayed all of the exterior surfaces with Riccardo clay using Optimum Instant Detailer and Gloss Enhancer as a lube. I find that the Optimum ID provides a super-slick surface for the clay, which reduces the risk of marring the finish (especially on soft Lexus paint). As is normal, I found the rear of the car as well as the areas right behind the wheels to have the most contaminants to be removed by clay. The horizontal surfaces were surprisingly in good shape.
After claying, I foamed the car once again with Chemical Guys to rinse off the Optimum ID, and then pulled it in the garage for polishing.
The water is sheeting nicely, which means no remaining waxes or sealants!
After washing, I always use my Blaster Sidekick blow dryer to dry the vehicles. This product is marketed to the motorcycle industry, but I find it’s perfect for cars. If you don’t blow dry, you’ll find a lot of water hiding in emblems and seals…water that either comes out when polishing to make a mess of things, or worse yet comes out when the customer drives away and then streaks all down the sides of their car! Whatever method you have access to (compressed air, leaf blower, whatever), I highly recommend using them!
Before my client arrived, I went ahead and got my tools ready in anticipation of a rotary/PO203S session since it worked so well on his LS460L.
After inspection and a brief discussion however, I opted for the PC with an orange LC pad and Optimum Poli-Seal (OPS). I like using OPS because it provides light correction, and contains polymer sealants that provide months of protection (3 or 4 in my experience). It also leaves the slickest finish of any AIO products that I have used. And did I mention that it is incredibly easy to work with? It only requires a small amount of polish, and it doesn’t take a lot of time to work in and break down like traditional polishes do…allowing for a much quicker application. Once finished, there’s very little residue to remove which is a huge plus in my book. I also love the look of Poli-Seal on darker colors too!
Now onto polishing:
Hmmm, what have we here? Obviously our 10 month old Lexus has had some paint work done in the past because here’s overspray on the hood! I found out that the paint work had been done on the LR of the car, yet I find overspray on the hood…go figure. I also found a bit of overspray and poor sanding and blending work done on the rear quarter.
This is the one area that I did use the rotary…Meg’s yellow 2.0 polishing pad with Menzerna PO203S cleaned it up. There were a few deep defects on the hood that remained.
I pulled it outside for a quick inspection in the sunshine to see how it came out. Notice all of the colors in this paint.
I’ve quickly moved down this side of the vehicle with Poli-Seal, PC, and an orange pad, and thought this made a good photo:
Todd Cooperider
Esoteric Auto Detail, LLC
Old 04-05-09, 04:09   #2 (permalink)
TSC17's Avatar
TSC17 is offline
Re: 08 Lexus RX350. Esoteric Auto Detail
Now on to the back of the car. As I’ve said before, the Menzerna bottles make great props for trunk lids so you can access the bottom part of it with the polisher.
I knew that I had some heavier defects to deal with on the bumper and right side of the car, and here you can get a good picture of what I had to deal with. You can see a lot of vertical scratches on the bumper (hiding underneath the swirls). Since I had the PC in hand, I thought it would be a great opportunity to use the infamous Kevin Brown PC Method (KBPCM) with Meguiars M105 to correct them.
All of that corrected with one hit of M105 and the KBPCM! Afterwards I finished it with Poli-Seal. And yes, I went back and cleaned up the 105 residue that made it onto the plastic trim underneath…
Moving back up the right side of the Lexus I had to deal with this…scratches that went all the way from the front bumper to the rear! Once again with PC/orange in one hand and a bottle of M105 in the other, I was prepared for battle!
Guess who won that battle! These next few “after” photos are immediately after M105…no finishing polish (OPS) yet.
You can see that the scratches continue down the side, and there’s a nice scrape there too (I told you that the color on the car changes depending on the light!)
After:
Before:
After:
Todd Cooperider
Old 04-05-09, 04:10   #3 (permalink)
TSC17's Avatar
TSC17 is offline
The M105 made quick work of the heavy defects, and then the Poli-Seal went smoothly on the rest of the car. There was sunshine outside, so I took the opportunity to pull the car out and get a few reflection shots since I didn’t know if I’d be able to the next day when I had the car all finished because the weather was supposed to change.
This is before finishing up the wheels/wheel wells, trim, glass, etc.
On this one you can see where I still had the tape protecting the Clear Bra.
Since I had the car all weekend, I closed up shop for the day so I could take my 8 year old son to Monster Jam for the evening. He had a blast!
The next morning rolled around and now it’s time to finish up the Lexus. While having breakfast I had the car key sitting on the table in front of me, noticed that it was dirty, and thought hmmm, I bet I could clean that up. So my OCD got the better of me and I took some M105 to polish it up a bit.
This is why we call it detailing!
Now I’m moving on to the interior. Here’s what we’re dealing with:
I did a very thorough vacuum job, then cleaned all surfaces with Woolite/water and a MF towel, and cleaned the gauges, controls, and console area with Meguiars Quick Interior Detailer.
Todd Cooperider
Old 04-05-09, 04:11   #4 (permalink)
TSC17's Avatar
TSC17 is offline
Here’s an area that can get missed. The only way to access this is to fold the rear seats forward. It’s like a catch-bin for “stuff”. This view is looking back into the hatch area.
After:
The driver’s seat was the dirtiest as per usual. It had a bit of grime built up, and some dye transfer issues as well. I first wiped it down with Woolite and water, and then sprayed Leatherique Prestine Clean on the seat and worked it in with a Swissvax leather brush. Afterwards I wiped it all down with a damp MF towel.
Before:
After:
Some other interior after shots:
I cleaned the foot rest on the left (as well as the pedals and rubber floor mats) with Meguiars APC+.
Now that the interior is all finished up, it’s time for a few finishing touches.
The chrome and emblems got cleaned and protected with Klasse All-In-One.
Before:
After:
Todd Cooperider
Old 04-05-09, 04:12   #5 (permalink)
TSC17's Avatar
TSC17 is offline
Exhaust tip before:
After polishing with M105: Note…that is not polish residue that you see where the plastic trim meets the bumper. It’s actually adhesive (I found it in several areas…perhaps leftover from the body work that had been done on it).
Don’t forget to clean the area on the trunk above the license plate:
And clean up the backup camera lense:
Ready for some after shots?
I couldn’t decide between these next two photos, so I added both.
You can tell it’s spring! If you look closely, you will notice the magnolia tree blossoming in the reflection.
Todd Cooperider
Old 04-05-09, 04:13   #6 (permalink)
TSC17's Avatar
TSC17 is offline
You can see how the color looks a bit different in this photo than it did in the sun shot I took the day before.
Final. You can see how the Clear Bra distorts the clarity a bit. Just compare the top of the red ceiling stripe to the bottom.
Total time: 7.5 hours (this one went quickly!!)
Thank you as always for checking out my work!
Todd Cooperider
Old 04-05-09, 04:16   #7 (permalink)
Farm Kid
wagonproject is offline
Very nice work mate!
Old 04-05-09, 04:22   #8 (permalink)
Blake's Avatar
Blake is offline
Nice Job....I have the same vehicle but it is called "Flint Mica". It is a beautiful colour. My 2004 is my avatar (traded for the '08)
"If we weren't all crazy..We'd all go insane" Jimmy Buffett
Old 04-05-09, 04:28   #9 (permalink)
David Strum
weekendwarrior's Avatar
weekendwarrior is offline
Great job as usual Todd. Do you have any issues getting your pad clean after using Poli Seal? I use to use it quite a bit, but never could get all the polish out of the pad, no matter how much I washed it, or what I washed it with.
DS Mobile Detailing, LLC
Old 04-05-09, 04:41   #10 (permalink)
XRtrix90's Avatar
XRtrix90 is offline
Another impressive detail on the lexus Todd. After seeing the SUV today, looks better than showroom condition.
Old 04-05-09, 04:48   #11 (permalink)
chromecarz00 is offline
Great job, its really quite a nicely done car and writeup.
Old 04-05-09, 05:20   #12 (permalink)
Fine Polish Aficionado
GoodnClean's Avatar
GoodnClean is offline
Contact: Send a message via AIM to GoodnClean
Flint Mica is a different color, this is Dark Truffle Mica and its a special color offered only on the Pebble Beach ES & RX. In person its very different from the Flint Mica.
Looks awesome! I love that color. Luckily its coming out into the normal rotation, the new RX350 has it as an option now without the pebble beach edition.
Steve
03 Lexus ES300 Black Garnet Pearl/Black Interior
