02-26-09, 03:26
dsms is offline
36hr "Mini Resto" vs. NSX: 130pics+Vids by dsms...
These past 3 days have been quite long thanks to this 1992 Acura NSX...
No need for a lengthy introduction about how great the NSX is or why it was so "ahead of its time". Yes it was/is a great car and we all know it deserves a place in automotive history , now lets move on
On with the detail that is... couple suprises along the way too:shrug:
Upon arrival the car appeared to be fairly clean, even still the usual wash process was carried out routinely.
First up a thick foaming of CG Maxi Suds after a very through pressure wash. I make it a point to pressure wash the paint, wheels and trim throughly before moving on to any form of washing. If there is any surface dirt on the car it usually will be taken write off with the initial high pressure rinse, that way the foam can do a better job of breaking down or at least loosening up some of the tougher dirt and grime.
I let the foam sit and began working on the wheels and tires. The foam was left for about 6 or 7 minutes, I wait until most of the heavy suds are off the car, never until the the paint has no suds on it! In the middle of cleaning the first wheel I stopped and PW'ed off the foam leaving the car shampoo free and then went back to the cleaning the wheels.
I used the Gloss It (GI) wheel gel with the EZ , boars hair, Swissvax and DD spoke brushes. I like using a few different brushes to make for easier cleaning of every part on the wheel, in this case the Volks were not very dirty to begin with but nonetheless they needed to be spotless from every angle.
Me on the racatac rolling creeper, this is a great little seat for wheel cleaning and polishing down low.
Using the detailersdomain spoke brush to agitate the inner wheel. The tires were cleaned with Megs APC 3:1 as well as the wheel wells. After the tires were pre cleaned with the APC I used Stoners Tarminator, yes TARminator to clean the tires again. I learned this trick from a good friend and fellow detailer Bob from AutoConcerige. Basically the mild solvent based Tarminator helps to further breakdown the grime really trapped in the rubber.
You would be surprised at the excess dirt which is pulled off the tires even after cleaning with strong APC or degreaser.
After the wheels were in order, I PW'ed the paint once more before the hand wash. Again I used CG CWG as my shampoo of choice, the NSX was wearing some form of protection as the paint was beading pretty well during all the rinsing so I used a heavy mix of CWG to hopefully strip away at the current LSP which was applied by the owner.
I used the new LC blue sponge to wash the paint, have heard rave reviews about it so I picked up 2 and am very happy with it.
I snapped some sun shots of the paint defects before pulling the NSX inside, didnt seem to terrible with the exception of some deep RIDS.
A-pillars were pretty hacked
The wash process went rather quickly until the final DI rinse where some of the water froze on the paint, the temp dropped considerably during the end of the wash process so I quickly pulled the car inside to begin claying.
I used sonus' fine green clay with Megs LT 1:1. Very little contaminants were picked up on the bar. The nose of the car was covered in a clear bra and had some residual rubber marks from the track (this NSX is a bonafied track car)
Heres the rubber marks on the bra'd nose
These were taken out using Tarminator (again) and a lot of elbow greeese.
Now onto the fun part, paint correction. I took tons of paint readings and found the car to be very very inconsistant. Some panels averaged 7mils and other up to 14mils:yikes:
I later came to find out the car had areas re-sprayed because the hood and drivers side were the original formula red single stage paint and the trunk and passenger side panels were re-sprayed and no longer single stage. My guess would be the re-spray was done a very long time ago as the defects were the same around the entire car. I couldnt tell by eye the car was re-sprayed.
Heres the headlight under the Fenix LED light, not soo bad here...
Little worse
I did a test spot to find the best combo and landed on 3 polishes for correction. I thought a 2 step would be sufficient to correct and finish the paint but in order to get 100% or as close to that as possible I found using a 3 step did the trick far better.
I started my first stage of correction with Gloss It extreme cut compound and a GI pre polymer white cutting pad on the flex rotary. This knocked down the deeper rids and swirls, I worked the extreme cut at 1900rpm to achieve maximum correction before backing down to 1400rpm and then 1100rpm, I did the same with the second step of correction with Gloss It evolution cut and a yellow GI pre polymer med. polishing pad.
Using the 4inch yellow med. polish pad with evolution cut and EVP (pad primer)
Here is the hood after stage 2 of correction, all the big stuff was knocked out. This is under the infratech CM5300
Close up of the defects
After finishing with a 5.5inch red ccs pad and menzerna micro polish at about 1400rpm jeweled down to 1100rpm (used the micro polish with GI EVP to extend the working time) As with every step prior, I used an IPA wipedown to check my work
50/50
Just a camera flash
Now under the Fenix LED light before the micro polish, some light trails need to be cleaned up still
Center all finished
The left side headlight cover was in a little worse condition, here it is under the fenix LED
After correction
02-26-09, 03:28
dsms is offline
Re: 36hr "Mini Resto" vs. NSX: 130pics+Vids by dsms...
Before
The trunk area is where the car was resprayed on, no more single stage so the defects were a little more difficult to polish out and needed the use of a lambswool light cutting pad from GI
After the second step of correction I moved onto jeweling with micro polish and a red 5.5inch css once again, heres a short video
The sun came in through the garage so I snapped a pic after polishing
Onto jeweling the rest of the car
Please note
I dont wear the ear protection to look like a nerd, for anyone who owns the Flex 3403 you will know that it has a considerably louder drone compared to a makita. After endless hours of paint correction that constant high decibel drone can cause some damage to your hearing. I learned from a fellow detailer that after years of exposure such noise as the whine of a polisher can cause damage to your hearing, permanently. Im young and will continue to do this for a while so I figured its better to be safe than sorry.
Back to the detail
This is the passenger side roof under the LED
Now after correction,
That part of the roof was particularly sticky, I switched up a few different foams to get the least amount of hop. I found the new green uber pad from Phil at DD buffs really smooth on sticky paints, I used that for the middle step of polishing with evolution cut on the roof area
After correction I rinsed the car inside with DI water in a pressurized hand pump sprayer. I find this helps to blast away some of the polish splatter caught in between the trim of the car. I lightly dried it with a WW MF and did one last IPA wipedown to prep the finish for LSP. I also dressed the tires..
here is the NSX after correction no LSP
Now that the grueling paint correction was finished I went to work on the interior, shouldnt be a problem after all its a 2 seater track car :
Well this car unfortunately has a little incident at the track as I was informed by the owner. He was doing about 90mph and went off the track onto the dirt... BOTH WINDOWS were open at the time if the mishap and dirt, gravel and dust flew in both sides of the car.
The result
I took the seats out to better clean the interior and get into all the cracks and crecvices
A good 1/2lb of sand made its way into the trunk jambs..
After some vacuuming I agitated the area with APC and an SV brush
Here the drivers side after
Back to the lovely interior
The sand was un-escapable
02-26-09, 04:05
Rupert Pupkin
jdoria is online now
Great work and great write up.
Detailing Technology
02-26-09, 04:21
Anthony Orosco is offline
Excellent work  Enjoyed the pictures and write up, great job.
Anthony
02-26-09, 04:39
Advance Paint Correction
bufferbarry is offline
i said it once and ill say it again! at nineteen you are so far ahead of the game! you make it look like you 10 years of quality work under your belt! outstanding detail! very nice work! great write up! seriously congrats on another good detail!!!!!!  and by the way nerd or no nerd i always say huh and what now! i wish i would have gotten into wearing ear protection when i started!!! good work man!!!!
Barry Theal
Presidential Details
02-26-09, 05:02
Banacheq is offline
Top job. Excellent work.
What a beast that interior was. I'm betting you're thankful that it was as small as it was.
I wish I had a proper driveway for that wheelie-ma-bob you're kneeling on.
~Brett
02-26-09, 05:40
harold97 is offline
VERY nice!! I love the early NSXs that had the fixed roof, and the blacked out canopy look, but most of the ones that I see now are in rough shape...especially the red ones. It is good to see one brought back from that condition!
Would the process you used on the seats work on a TL with a parchment interior as well?
02-26-09, 05:53
connorb850 is offline
Amazing work! Thanks for taking the time to post all those pics and do a writeup.
