The tools of my degreasing/decontaminating:
As you can see, just by the condition of the exhaust tips, a thorough degreasing/decontaminating of the paint, etc goes a long way in speeding up the process down the road. While they aren't perfect (and will be later on) they're certainly cleaner, and making my life easier:
As I had mentioned earlier, I fought through the whole detail to find good lighting to highlight the defects needed to be removed. I ended up having to adjust my camera in manual mode, because automatic did nothing but blow out the shots and overexposing everything. So this in itself took longer than expected.
As you can see, no real wash induced marring, which I found VERY surprising. The only real damage present was heavy RIDS.
So with my game plan in my head.. I set out on the easy stuff. The highlights/taillights! I corrected these with my Makita 9227c, 4" LC White Pad, and 106fax2:
(sorry forgot afters!)
After that was complete I began my testing process. I thought since there was no real washed induced marring, just the RIDS, I would start with a 3M UK Green Compounding Pad, my 9227c, and SIP. I tackled the hood. Pulled it outside, and the BMW Cermiclear laughed at me with one of those "IS THAT ALL YOU GOT?!" kind-of laughs. So then, I went at it with
M105+Green. No such luck. I have heard that PFW works really well with cermiclear paints. And the same went with me as well. 2xPFW at 2100rpm with
M105.
Results after just
M105:
As you can see, all of the RIDS were tackled, and all that was left was the PFW marring that is to be expected.
Also.. M105+PFW Was acting really weird. It would have "blotches" left over that was like REALLY sticky/dried up polish that took real elbow grease to get off. At first, I thought it was strike-through. But it wasn't thank god. Then I thought it had to do with not getting enough heat to the panel, but even when working the "blotches" alone, they wouldn't come out. Any ideas?
Artsy shot:
As you can see in this shot, the clarity of the paint is definitely being restored from original condition:
Now the paint is finally getting restored to it's better than new luster.
My attempt at 50/50s. As I was saying.. I was battling with lighting the entire time.. so it make take a little bit of searching to find the "line"
In an attempt to find swirls, etc under halogen lighting, I had all the lights off but the one, and it made for an interesting shot:
After working in the M105+PFW, I switch to the 3M UK Green pad with SIP. Here I am working around the side vents with the 80mm pad:
After SIP+3M Green pad, I moved on to PO85rd with a 3M UK Yellow Pad. This pad is very versatile I have found. it can be a finishing pad on hard clears with the right polish, or on soft clears, can be a medium polishing pad, much like the LC White pad. But I believe it's a lot more controllable than
LC pads.
I began to work in the 85rd+3M Yellow:
With the process of the 2xPFW+M105, 1xSIP+3M Green, 1x85rd+3M Blue, I was able to achieve about 98% correction. The car was then taken outside for a much needed bath. It was rinsed down under pressure to remove dust, as well as blue tape adhesive. The shots were taken before any lsp, and right after the wash
(in this pick there was this weird circle in the middle of the hood, I confronted the owner before picking the car up, and they said it was a rock chip or somethign like that that was filled).
After the entire outside was finished, I moved to the interior. I first vacuumed everything up with my Metro Shop Vac. Then the carpets were cleaned and extracted with CG Extratimator, and a MyteeLite2. I then focused my attention on the leather, which received LeatherMasters Strong Cleaner, Vital, and Protection Cream:
Unfortunately I forgot to take befores.. but it was pretty bad.
The plastics were cleaned with a combination of 1Z Cockpit Premium, and Megs APC+ 10:1. Then it was all dressed with 303 Protectant. The glass was cleaned with Stoners IG and then followed up with DI water to get rid of any last streaks. The trim was treated with a combination of Megs HyperDressing 3:1 for a satin finish, and 1Z Gummi Plfedge on the seals to plump and dress them.
The engine bay received 303 Protectant as well. I felt it was important to use this dressing as it adds a nice satin finish to the plastic, as well as reduce static cling which reduces dust considerably.
The exhaust tips were polished with Mothers Polish:
