This is a friend's car. in fact, the owner of this car is the guy who got me into waxing cars... but i took it to a much higher level after that!
Anyways, the car is usually zaino'ed or waxed every so often, and usually washed by the owner using a sheepskin mitt and, for the most part, proper washing media. However the car hasn't been polished since it was purchased back in 2006.
the car was scheduled for just a 2 step SIP/85RD polishing job, but once i got started, that combination wouldn't have been enough to take out all of the imperfections. after talking it over with the owner, he told me no matter the price, he wanted the car to look as good as i could make it.
total time on this detail was around 30 hours over three days.
Exterior[b]
Wash
-1Z Anti-Insekt
-Valugard ABC paint Decontamination
-CG CWC
-Meg's mitt
Wheels
-CG CWC
-CG Citrus Sticky Gel
-EZ detail brush
-Swissvax wheel brush
-OXO tire scrubber
-black shMITT
-ARO (tires)
Wheel Wells
-Simple Green
-EZ detail Brush
Clay
-CG gray clay
-ONR lube
Polishing
Exterior paint
-Meg's
unigrit 2000 paper
-Meg's
unigrit 3000 paper
-Meg's sanding block pad
-M95 via Black Wool pad @ 1000-1800RPM
-Menzerna SIP via
Orange CCS pad @ 1000-2000RPM
-Menzerna PO85RD via blue 3M UK Ultrafina pad @ 1500-2000RPM
-Makita 9227C
-3M Yellow Foam Backing Plate
-1000w halogen lights
-ISA 50/50 wipedown
-DD Uber MF towels
Exhaust
-#0000 steel wool
-1Z chrome polish
LSP
Paint
-Swissvax Cleaner Fluid
-Swissvax Mystery
-FK1 # 425
-CG 530XL MF towels
Wheels
-Swissvax Autobahn
-FK1 # 425
-Optimum opti-bond tire gel
-CG Barebones (wheel wells)
Glass
-Stoner's Invisible Glass
-Aquapel
Rubber trim
-1Z Gummi Pflege
Interior
-CG Leather Cleaner
-ARO (rubber mats)
-Aerospace 303 (floormats)
-1Z Cockpit Premium
Before:
The paint didn't even look black... it had a hint of gray in it from all the oxidation and imperfections. it had some pretty severe rain etching and RIDS.
the front bumper used to have a lip attached to the bottom, but it fell off from running over a parking stop. hence the scratches and leftover betalink on the bottom portions.
i was really surprised to see how dirty the clay was after only doing 1/2 of the roof, considering how the owner actually takes care of the car!
and from the other 1/2
up close shot of the scratches
now this scratch seen here is from a peice of a tire smacking the front of the car while driving on the highway. most of it was too deep to completely remove, but i tried as best i could without removing an excess of paint.
so i first tried
M95 with a black wool pad to see if that would have enough bite.
as you can see, it looked better, but not good enough for me. so i decided to wet sand the scratch a little bit to round out the edges of the scratches to make it less noticeable. I decided to use 2000 grit followed by 3000 grit sanding paper for this.
