10-14-08, 12:14
dsms is offline
dsms detail- MR2 Turbo, the swirly revival**
Always had a thing for the MR2, this one isnt my style in particular but it's still a terrific car and quite the bandit around a race track. This MR2 in not a DD at the moment and usually spends it time in a garage, but it being over 15 years old it has its share or wear and tear.
One with the detail...
During the wheel cleaning process, a bit of a 50/50 picture if you will. The front wheel is cleaned and the rear isnt.
Now a more in depth look at the process on the wheels
Starting point, overall not bad. A bit of caked on brake dust but the wide openings between the spokes and tiny calipers made for easy access to clean the wheel inners all the way through (a very important thing to me)
After applying the Kleenol APC to both the wheels and tires, big plus about the Kleenol is its ability to be used on both tires and wheels safely. The cleaning power is pretty good but not excellent.
Using the swissvax brush to agitate the dirt on the wheel face, im still on my first swissvax brush since I bought it about 45 cars ago. Im really happy I found this brush, its gotten me though a lot of messy wheels
Then onto cleaning the inner wheel area using the spoke brush which is great for heavy scrubbing, an area where the EZ brush lacks big time.
Now scrubbing the tires
And finished off with the EZ brush which helped to agitate the brake dust behind the spokes, its flexible handle allows for easy cleaning in tighter areas like behind the spokes and brake calipers
Rear wheel before...
Rear wheel after...
I then dried the inside of the wheels and removed any excess loose dirt with an old MF towel
Now moving onto to wash process. The MR2 was given a thoroughh rinse, after seeing that there was no prior LPS still on the car I did not need to focus on stripping it. I used the P21s TAW as a quick pre wash and also I used the Surf City road grime destroyer to loosen up some light tree sap and road tar from the ower panels and hood, specifially by the wheel arches... a popular spot for slung tar etc.
The grime destroyer is really a fantastic product!
I then used the 2 bucket method with grit guards to wash the MR2. My shampoo choice was Gloss It Gloss shampoo and 2 foam shmitts. The Gloss Shampoo suds up very well and is super slick.
After washing and drying the car I inspected the finish in direct sunlight to determine the type of correction work which would be needed. Under the time constraints a 100% full correction detail could not be provided but instead the owner aksed for my 2 step polish/correction job.
Here is the damage...:yikes:
I wasnt too concerned with the finish, I assumed that is was the standard Toyota clear coat but the owner informed me that the car was repainted about 3 years ago and it does have clear on it. Judging by the flatness in the finish the re-spray was not very high quality.
I pulled the car in my garage and proceeded with claying, Meguiars mild blue was used in conjunction with the meguiars last touch QD at 1:1. The car was suprisingly un contaminated. I used about 1/4 of a claybar.
After the hood section was clayed...
Now it was time for the correction work, I inspected the finish under dual 500w halogens and the Infratech CM5300 hand held inspection light.
As I have been doing lately I grabbed the Cyclo orbital polisher to see if it was up for the job...after doing some spot sections I found the Cyclo was correcting very nicely so I stuck with it for 90% of the car.
The car was re-sprayed and the paint avergaed about 225microns
The correction process was as follows:
Gloss It extreme cut compound on orange cutting pads with the cyclo
Gloss It Evolution cut on yellow cutting pads with the cyclo
Gloss It One step machine polish on yellow polishing pads with the cyclo
Some before and after shots of correction
The engine (not trunk) area needed compounding, the extreme cut on orange pads worked very well after 2 passes the finish was about 95% perfect. The beauty of the cyclo is that you can really lay on the pressure to polish out those deeper defects, I worked the hell out of the polishes with this thing:headbang:
after spreading with the cyclo
And after full correction
Here is the engine section after polishing with no LSP, the clarity and depth was brought back at this stage
This is my favorite picture of this detail, I dont know why maybe its the lighting. Anyway here are the halogens inspecting the side panels. I keep them further away to see swirls on a larger scale.
The sides of the car did not need heavy correction work so I only used the gloss it machine polish and yellow pads, then followed up with green pads to finish it out
10-14-08, 12:18
dsms is offline
Re: dsms detail- MR2 Turbo, the swirly revival**
After polishing, no LSP is on the car
The hood needed more attention than the rest of the car so I stepped it up to the Makita to ensure I could polish out the deeper defects. I used the Meguiars burgandy cutting pad with gloss it extreme cut and then finished it out with the gloss it machine polish using yellow pads on the cyclo again.
Here is the makita spinning at 1500rpm, I kept the finish slick with the gloss it QD so I could keep working the product, this method helped me to reduce any fine swirls or holograms left in the finish after compunding. I worked the gloss it extreme cut at 1500rpm before jeweling it down to about 900rpm. Then came finishing with the cyclo.
The hood after correction, before all the swirls were causing the halogens to reflect light in a dozen different directions, now its much clearer
The hood after polishing and an application of the Gloss It concourso polish, its bascially like a finishing polish that I apply via the cyclo. It has zero cut, its soul purpose it to add depth and shine to the finish. I think it works like a charm, even on white!
I then polished up the exhaust using 2 members of the Adams family :giggle:
Before..
During
After...
This was an exterior only detail but the owner did ask if I could restore his faded dash. I used the Gloss It TRV cleanr and protectant via MF applicator. I only used this product once before on beige and it worked great but in black its outstanding... so far im very happy with just about every product I have used from that company. Soemtimes you find something new that just works..and ya stick with it!
Here is a 50/50...no prior cleaning is needed to apply this. And the finish really isnt shiney at all its just the other side was super dull.
After...
After the dash I went back to apply the LSP to the car. I used Gloss It Gloss Finish sealant after applying the concourso polish. I used the Gloss Finish with a red pad and polishing pal. I used 2 coats and let it cure for about 10mins.
10-14-08, 01:50
Concourse d'Elegance
stiffdogg06 is offline
Awesome job. That mr2 was is bad shape.
Turbo D Club Member #000001
10-14-08, 02:02
Loves cars
99blackSE is offline
Nice writeup and nice recovery!
Brad
1998 Civic Si - black - the gas pumps don't hurt as bad!
10-14-08, 02:02
Esoteric Auto Detail
TSC17 is offline
I have to agree...those are cool little cars. Nice work and great write-up.
Todd Cooperider
Esoteric Auto Detail, LLC
10-14-08, 02:33
95supra is offline
Wouldn't use those brakedisc's if I where him. aftermarket drilled discs tends to crack on trackdays. Only ferrari and the big ones can pull it off. :P tried several brands and they all did it unfortunately.
Nice looking car, great recovery. gotta love those little machines. Its a pita to work on those tight engines though:P
10-14-08, 03:12
BigAl3 is offline
awesome job
10-14-08, 11:14
Drsuce is offline
looks crazy deep!
10-15-08, 02:24
robert is offline
White done nicely.  That Concourso polish is peaking my interest. How do you like the Glos It brand compared to other polishes you've used?
10-15-08, 09:17
Late Registration
mr.ikon is offline
Very nice work. I'm a huge fan of the MR2's myself. They are beautiful cars. Excellent work once again.
10-15-08, 12:34
Flight Sim. addict!!
bigfoot is offline
Social:
Beautiful job! I'm amazed with the amount of correction given with the Cyclo
Owner of Major Auto Works. Serving the eastern half of Puerto Rico
