Originally Posted by JoshVette
Nice job, I'm still playing with the gloss it stuff and trying to figure it out.
How exactly are you applying the sealant? I know that's a dumb question but I tried it the other day and got a lot of streaking.
Rich told me to work it in harder and longer and it seemed to do the trick but what's your approach?
I always use the PC when waxing/sealing.
Josh
At first I tried applying the Gloss Finish by hand like I did Zaino using a soft MF applicator but it streaked quite a bit and I wasn't able to spread it thin. I now use the
Flex w. a LC blue final finishing pad (non CCS) on speed 1 or 2 using back and fourth motion. I find that I use less product compared to hand application with the
Flex and I'm able spread it very thin and evenly across the finish with no problems. Try the same method with your PC, using a non
CCS pad is my preference for a smoother more fluid spread of the sealant. And I think a blue or red LC pad is the only way to go, IMO even the black pad isnt soft enough to apply a sealant.
BTW I just ordered one of those Polishing Pal's from AG and im going to see if I can spread gloss finish by hand using the polishing pal and a red LC, might be a time saver if you dont wanna break out the PC. I'll keep you updated on how that works out.
