07-27-08, 09:58
JoshVette
JoshVette is offline
1966 Pontiac Lemans Show Car, Full Sanding and Polishing
Final Pics of the Lemans completed and put back together with lights, bumpers and trims and waxed two times are on the last page. It look killer. 9-19-08
The complete write up is now finished, the majority of the process is at the bottom of this page and on the rest on page 2. The final pics are on page 3. If you have questions please read through the whole right up first since I wrote it in order for everyone to understand what it takes to do a process like this.
Also I put text that I felt more important in Bold so it would be easier for you to find....
Thanks
Okay, here's the teaser pics. I will get an early start tomorrow with the lengthy write up.
I spent about 30 hours just polishing the paint.
I will do a very indepth write up covering my exact movements on this entire process so please stay tuned.
Josh
Perfection Is In The Details
Ottmann Detailing
07-27-08, 10:59
King of Gloss!
rydawg is offline
Re: 1966 Pontiac Lemans Show Car, Full Sanding and Polishing
NICE!!!!!!!! Can't wait to see the afters.
By the way those white MF's from Target are the best I have ever used. They are for one use only, but for the price they are a bargain. I get no marring at all, no die transfer, and no lint.
Ryan Blanchette
07-27-08, 11:17
AC Detailing
d00t is offline
Stunning teasers! I noticed the stack of pads you've accumulated. At what point do you decide you need to start with a new pad? When the entire pad is soiled, does it lose cutting power so it's a good idea to switch?
Aaron
Owner- AC Detailing
07-28-08, 12:23
iDetail is offline
amazing. love the half and half shots.
07-28-08, 12:56
///Member
lecchilo is online now
Subscribed!
I love those towels as well (my favorite by far is Meg's supreme shine mf though) and I have the same tripod for what it's worth haha
Half/half looks amazing, I'm really looking forward to hearing about the process, mostly about what products were used with the pads since you went from PFW to white. Good job man!
-Ivan
LUSTR Auto Detailing
07-28-08, 09:02
lt1_man is offline
Wow, very impressive I look forward to the full writeup.
-Brandon
Brandon Hey
1995 Firebird Formula (sold)
1989 BMW 325i Alpine White Daily Driver
1989 BMW 325i Spec E30 race car
07-28-08, 09:15
JoshVette
Yea, I can typically get 2-3 used out of them at the most, but the ones that start getting dirty or whatever get used on engine bay, rims and interior.
Ottmann Detailing
07-28-08, 09:21
JoshVette
It's kind of a learnt knowledge about when the pads are needing to be switches, but basically I'll use one till it starts caking up to the point of spitting out alot of dried compound build up and or it starts to skip a lot and I can't really hold it steady anymore. Alot of times it just starts to cake up and leave a nasty mess as you're buffing.
Most times I'll try to get the entire side of the car with one pad and all top surfaces with another whole pad and the other side with another new pad, but sometimes I need more pads then that. Also quite a few of those pads were used for testing and finding the right pad/polish combo which took me about 3 hours and 6 pads total since I did not want to mix polishes on the same pad.
Josh
Ottmann Detailing
07-28-08, 09:42
JoshVette
Okay guys, I'm going to take a quick minute to basically describe the process before I go into detail with pics and writing.
The owner called me to "rub out" his home painted 66 Lemans, I thought no way am I going to put my name on a car that was painted in a garage. (his friend has a paint booth set up in his garage where the car was painted, not the garage I did all the work in)
The owner is 70 years old and this sort of thing is just getting a little harder to do on his own.
The car is just over 17 feet long front to back not including the bumpers that are off the car at this point.
So I went to evaluate it and after seeing the condition of the paint before sanding it was to my surprise very clean with little orange peel except for just a few panels were it was worse so I decided to take on this project and gave him a conservative quote of $2500++ as a ballpark which was way on the low side as I was to find out as the total process from sanding to polish took about 49 hours so the bill would have been closer to $3800. Considering that quote was based on sanding the bad areas with 1500 and refining with 2000 and 2500 and on the good areas going with 2000 and then 2500 so the whole car would be without OP and finished with 2500 grit.
Needless to say the owner opted to sand it himself. It took him and a few others a total of about 24 hours to fully color wet sand it with the process I explained.
Meg's Unigrit sandpaper was used at my request for this wet sanding process.
After it was fully sanded and ready to be polished, I started with the trunk as the tester panel and spent about 3 hours with about 8 different combinations before I came up with what I felt to be the deepest cut with the cleanest finish the fastest. It was difficult to find this combo as the sanding marks needed at least two passes with a heavy compund to really get underneath them and remove them 100%. Then I would need to finish it down and remove the holograms.
I'll explain more in the pics about the testing.
The combo that won the trophy was surprisingly Menzerna Power Gloss on a Purple LC foamed wool pad at 1700 rpms which cut deep and removed a most of the sanding marks and then another heavy hitter to cut deep again to clean up any marks the PG missed and with a beautiful finish using Meg's M105 on a LC white pad at 1500 rpms with much jeweling.
Believe it or not I knocked out all the sanding marks and swirls with a two step heavy compound/polish combo knowing how well M105 finishes down required very little perfecting with Menz Final Polish II.
By the end of it all I would judge this paint to be about a 5 on a hardness scale of 1-10 with 10 being the hardest.
I am not finished with the car, once the owner gets all the trim, lights, bumpers, covertable top all put on and a few panels realigned I will go back to touch up any areas and then seal the heck out of it so there's still just a little more to do but for now the finish is nearly ready for show.
Okay, enough talking, onto the pics which I will also provide write ups with as I post so please be patient.
Josh
Ottmann Detailing
07-28-08, 09:53
JoshVette
Okay, so here's what I'm dealing with.
A 1966 Pontiac Lemans Convertable that the owner has spent nearly 3 years restoring and perfecting to show quality standards to give to his daughter as a birthday gift two years ago.....
The entire car has been sanding between 2-3 times depending on how bad the OP was per panel and all is finished down with 2500 grit using Meg's Unigrit paper which took nearly 24 hours total just to sand.
The cover was still on the front of the car so I didn't take pics of the front sanding marks till I got around to polishing it them out.
Now for the intial test to find out which pad/polish combo I was going to start off with.
From left to right are 1 Gloss It Extreme Cut (left) 2 Menz SIP (middle) 3 Meg's M105 (right).
I am trying out a new line called Gloss It to see how I like it so please understand this is the first time I've used the polishes and there is a slight learning curve involved with any new product, but to be fair I did use it with the same pad and rpms as all the others were tested with.
Ottmann Detailing
07-28-08, 10:13
JoshVette
So onto the test.
First off Meg's M105 on a purple foamed wool pad at 1700rpms for one pass properly worked. I dob it all around then spritz it with a shot of water then quickly spread it at 600rpms and then up to 1700 and once worked in and broken down I turn it back down to 1100 then 700 and am finished. All were wiped down with IPA 90% which can leave a slight hazing behind itself. fyi.
All the polishes were done with this exact same process so that I could really see who has the better cut and finish for this custom black paint job. Also to note all the polishes are supposed to be able to take out 2500 grit sanding marks.
M105 sure it looks good under floresense as they all do for now....
Not bad for one pass but still has significant marks and swirls left behind. (to note holograms/buffer trails and swirls are two different things)
Menz SIP
Notice it did not cut as deep as the M105 or finish down as well either, now I did not expect it to cut as deep, but I did expect it to finish down better then M105 so I was a little surprised.
Now for the new kid on the block, Gloss It Extreme Cut, this is Gloss It's heaviest cut polish and after lengthy talks with the owner and other detailers that use the product I wanted to give it the true test.
Please understand this is my first time to use it so there's always a learning curve involved and I don't believe I got it's full potential out of it as others have and as I did with the other two polishes I was using.
It looks good as far as cutting power but doesn't finish down near as well as M105.
Ottmann Detailing
07-28-08, 10:38
JoshVette
After that first step in the testing process I basically narrowed it down to Meg's M105 as the heavy cutter to remove the sanding marks with, it seemed to cut the deepest as well as had the best looking finish. But I still wanted to see what the Gloss It line had in it so more testing with Gloss It.
Now what I'm wanting to do is remove the holograms and see what's truely left underneath the heavy cutting compounds and for this I'm going to use a medium cut polish and see what is left over as far as sanding marks and swirls are concerned. Also to note this is PPG paint and clear coat but cut with what thinners and hardeners I don't know, so at this point I have no idea how hard or soft the clear is at all.
To do this I used the LC white pad and dobbed the polishes all around then spritz with water, then quickly spread them at 600 then up to 1500 to work it in and break it down then back down to 900 to jewel. All the medium polishes were used with this exact same process to see where they all stood when it comes to finishing down.
I basically excluded the SIP panel since I did not plan on using it on the rest of the car for the intial heavy cutting so it's down to the M105 and Gloss It line....
So to start off with I went back to the Gloss It line and used there own medium cut polish called Gloss It Evolution Cut.
I used the Evolution cut to refine the Extreme Cut and see what it would show me.
Gloss It Evolution Cut over the Extreme Cut panel.
I was impressed with the fact that most of the sanding marks looked like they were gone but the final finish still had much holograms in it.
To top the M105 I first tried Menz SIP then I also tried Gloss It Evolution Cut.
First SIP over M105
The finished looked nice but I'm still not happy with the cutting ability of both together to get 100% of the sanding marks removed as you can see so this is still not enough.
Gloss It Evolution Cut over M105
I thought the M105 and Gloss It Evolution Cut had a slightly better cut and nearly the same finish as the M105/SIP combo so I think the M105 and Gloss It Evo Cut is the winner between these two.
But even though I've narrowed it down again, as you can clearly see in the pics the swirls are still very very evident and so I am thinking at this point it's not a two step at all, but obviously needs two heavy compound passes to remove the sanding mark and swirls before I can go to a medium cut polish to refine, so back to square one.
Now I need to rethink my game plan. So for this I decide to throw Menz Power Gloss into the mix and see what happens.
Now the next test is between Menz PG/SIP and Meg's M105/Gloss It Evo Cut.
We'll see who wins this one.....
Ottmann Detailing
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/pro-details-before-after/109898-1966-pontiac-lemans-show-car-full-sanding-polishing.html
| Posted By |
For |
Type |
Date |
| Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polished - Corvette Forum |
This thread |
Refback |
01-07-09 02:06 |
| View topic - wet sanding |
This thread |
Refback |
01-05-09 03:30 |
| Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polished - Detailing World |
This thread |
Refback |
11-21-08 04:09 |
| Difference between show car and dailey driver - <B>Autobodystore Forums |
This thread |
Refback |
10-10-08 09:22 |
| Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polished - Bimmerforums - The Ultimate BMW Forum |
This thread |
Refback |
08-31-08 08:44 |
| Nissan GT-R being Detailed - BMW 3-Series (E90 E92) Forum - E90Post.com |
This thread |
Refback |
08-18-08 07:44 |
| Supra Detail upcoming.. please advise!! - Bimmerforums - The Ultimate BMW Forum |
This thread |
Refback |
07-29-08 07:38 |
| View topic - Sand scratches come back, after a week. |
This thread |
Refback |
07-29-08 05:39 |
| Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polished - 6speedonline.com Forums |
This thread |
Refback |
07-28-08 02:52 |
| Full Write Up, 1966 Pontiac Lemans Show Car, Fully Sanded and Polish - TeamSpeed.com |
This thread |
Pingback |
07-28-08 02:23 |
| Atlanta Pontiac Dealers » Blog Archive » 1966 Pontiac Lemans Show Car, Full Sanding and Polishing |
This thread |
Pingback |
07-27-08 11:08 |
