07-05-08, 07:07
dsms is offline
dsms detail- Gloss It put to the ultimate test...
UPDATED
I started with a scrap hood that I use to test products on. The finish was already clean so I used fine grade steel wool followed by a stiff bristle carpet brush to induce heavy swirls marks, marring and some fine scratches.
The finish looked like this after. (I labled the center tape w/ sharpie in my handwriting to show that the side I corrected was in fact as trashed as the other)
Left side will be corrected Right side will not
You get the idea of how bad the finish was
I took a quick reading to make sure I had enough clear to work with
After a thourugh IPA wipedown and inspection with the Infratech I thought I may have been a little to "aggressive" in marring the finish and that it would need more than machine corretion, perhaps wetsdaning.
I decided to begin with Gloss It Extreme Cut on a 6.5inch Lake Country purple foamed wool
After working the panel with slow passes at 1500rpm to my suprise the finish looked like this, a very good amount of defect was removed but some deep swirls and RIDS still remained along with holograms
I used Extreme Cut one more time, this time bumping the speed up to about 1700 on the Makita hoping to work out those deeper RIDS with teh PFW. After this step the majority of defect was gone and it was time to move to a less aggressive pad and polish.
I used Gloss It Evolution cut( a milder cutting polish) with a new Edge 3K CCX 8" cutting pad)
After this stage the finish looked like this
Just about all the defect was gone at this point, now onto refining the finish and polishing out any last fine swrils
I chose to use Evolution cut with a green CCX 8" polishing pad from edge for this
The result after Evolution cut and an edge green pad and an IPA wipedown, at this pint I was very happy with teh correction and finished achieved. The panel was LSP ready..but I decided to go one more step to make sure it was really perfect before applying Gloss Finish
I used a LC white polishing pad and Evolution polish at no more than about 1000rpm to refine the finish further and to bring out maximum gloss while removing any slight holograms which may have remained after the correction
Evoution polish working
The result after an IPA wipedown with no LSP.
some 50/50 shots
Mind the lights cord in this picture
Now that the panel was fully corrected and finished it was time to apply Gloss It Gloss Finish.
I sprayed the panel with Gloss It Gloss Enhancer QD spray as prep (similar to Zaino Z6) and then appied a dime size amount of Gloss Finish to a hand applicator and spread evenly across the panel, a little goes a long way with this stuff!
I then buffed the panel, Gloss Finish doesnt need to cure for a very long time and no additives are needed. It buffs off super easy with no streaking at all.
This is a 50/50 in my dark garage after 1 coat of gloss finish and then a quick Gloss Enhancer QD wipedown. I fliped the panel upside down so I could take some photos thats why the corrected side is now on the right.
The before
The after
I ended up correcting both sides and leaving the center piece of the panel uncorrected, you can see how dull the finish is and the light is refracted all over the place
Gloss finish really brought out the flake
07-05-08, 07:09
dsms is offline
Re: dsms detail- Gloss It put to the ultimate test...
07-05-08, 07:32
Paint Correction Expert
tdekany is online now
Great reading!!!
Does it dust?
07-06-08, 10:50
dsms is offline
Originally Posted by tdekany
Great reading!!!
Does it dust?
Thanks. The two correction polishes dust a little but not as much as most other products and the Evolution polish doesnt dust at all! Very similar to working with Ultrafina.
07-06-08, 11:20
TH0001 is offline
Thanks for the great post. Very nicely done, it looks like you removed 95 percent of the defects using the system, removing all but a couple rids.
Thanks for sharing, I have heard nice things about the system.
07-06-08, 11:45
0 to 60 in one paycheck!
SuperBee364 is online now
Wow, very nice work!
Question.... besides the halogen, what is the other light source used in most of your pictures? I'm impressed at it's ability to show holograms. The combination of your light sources and photographic skills *really* did a great job at showing defects/paint condition. Great stuff.
Originally Posted by Danase
07-06-08, 12:53
dsms is offline
I was very pleased with the correction ability of Gloss It Extreme cut/Evolution cut combo and Evolution polish is just a pleasure to work with. I believe with the lambswool Gloss It pad using extreme cut I would have been able to achieve 100% correction in less steps as well, I should have mine tommorow and I may post another review with it. Rich Light, the owner of Gloss It called me yesterday and we spoke about some things and I think he spoke to you Todd about his products. Comming from Menzerna and Zaino (2 brands you frequently use Todd) I will say that Gloss It is certainly an easier system which works well from heavy correction all the way down to Gloss Finish as LSP.
07-07-08, 12:12
roadmaster_Tx is offline
looks good! how many coats can you layer in one day?
07-07-08, 02:27
lt1_man is offline
Great correction I am going to the local pick and pull and grabbing some hoods to practice on as well.
-Brandon
Brandon Hey
1995 Firebird Formula (sold)
1989 BMW 325i Alpine White Daily Driver
1989 BMW 325i Spec E30 race car
07-07-08, 08:48
dsms is offline
You dont need to layer Gloss Finish. 1 coat is good enough, if you feel inclined to add a second than you can apply it after the first. You dont need a curing additive, just prep the car again with a gloss enhancer QD wipedown.
07-07-08, 09:02
silvergray is offline
WOW! Thats awesome!
I'd keep that hood for promotional work, like explaining correction to customers!
2004 BMW 325i - Silver Gray
2005 BMW X5 - Titanium Silver
07-08-08, 03:52
dsms is offline
Originally Posted by silvergray
WOW! Thats awesome!
I put some of those 50/50 shots into an email pack im working on which will be sent to interested clients. They say a picture is worth a thousand words
