Old 06-04-08, 07:14   #1 (permalink)
U Bring It - I Bling It
David Fermani's Avatar
David Fermani is offline
2007 Black Corvette - Complete Paint Correction
This past weekend I had the opportunity to work on this 2007 black Corvette. The vehicle was dropped off at my house late afternoon Friday and the owner allowed me all weekend to make sure the vehicle was brought back to better than new condition. This client recently had this vehicle “professionally” detailed at one of S. Florida’s premier Car Washes and their “technician” created extensive clear coat marring. This marring was initiated from their failed attempt to gently buff the surface with a cutting wool pad coupled by piss-poor technique & silicone fortified compounds and glazes. After installing deep buffer gouges throughout the entire vehicle, the shop covered up their mess with a healthy portion of silicone based LSP. Late Friday night, my 1st concern was to thoroughly
remove/decontaminate/cleanse the finish of all possible waxes, dirt & silicone so that the correction process could be performed without any hiccups. I knew as soon as I took my garden hose to the hood that the already dulled finish was coated with a healthy portion of LSP. The water was beading like it was just freshly waxed.
After power washing the exterior to loosen any and all loose dirt & grit, I proceeded to presoak each section with a strong mix of Auto Magic (AM) Red Hot degreaser and hand washed the surface with Dawn soap.
After rinsing, the water on the surface was laying flat and there was little to no beading. After rinsing the exterior and engine compartment, I clayed all the painted exterior surfaces with AM blue Clay Magic & AM Body Shine lubricant. After drying the finish with terry cotton towels, I 4000 grit sanded the surface using Lacquer Thinner as my gliding lubricant. Because the finish was contaminant free by this time, the 4000 grit sandpaper barely induced any further marring into the finish. This process finally insured that there would not be anything on the surface that would interfere with the buffing process to follow.
Here’s what the buffer pad damaged finish looked like under Halogens at night:
Here’s what it looked like in daylight. The finish was so marred up, that it gave off the illusion of having metallic paint!
After taping off all critical areas where my buffer pad could inflict marring/burning, I started off leveling the finish down with Meguire’s 105 compound with a fresh Lake Country Purple Foamed-Wool (PFW) pad. This product instantly cleared out any and all micro marring and left the finish with a nice glossy finish under 500 watt halogens. After working the my 1st pass for about 20-25 seconds, I laid down another bead of product and refined the compound induced marring by buffing for 10-15 seconds and then wiping the buffed section.
I propped the hood & trunk open with stacks of towels so that I could safely buff each panel edge without fear of burning:
Originally Posted by GoudyL
Old 06-04-08, 07:16   #2 (permalink)
Re: 2007 Black Corvette - Complete Paint Correction
Test Panel:
Here’s how it looks after 105 via PFW:
After buffing the entire car, I then high pressure washed it again to remove any and all compounding dust and residue.
After experimenting with several Menzerna polishes and pads densities, I decided on going with Super Intensive Polish (SIP) with LC white CCS foam pad as my middle stage treatment. This step by itself refined the gloss and removed all micro marring that the 105 installed in the finish. After final micro fiber wipe down, I finalized the buffing process with 3M Perfect-It 3000 Ultrafina SE (swirl eliminator) with a LC blue CCS foam pad. This final step insured that the finish would be “buffer trail” free and in addition would even out the dynamics of the gloss.
After glazing over the finish, I then re-washed the vehicle again. This time with Meguiar’s 00 Hi-Tech car wash soap. I prefer using this product right before applying a paint sealant because it does a great job of gently cleaning the surface of all lubricating oils and doesn’t contain any protectants that would interfere with most sealant’s bonding/cross-linking properties.
Here’s some late evening sun shots right before sealing:
Toward the end of this 12 hour paint correction, I applied 2 thin coats of 1Z Einszett Glanz Wax “Hart Glanz” sealant by hand. I called it quits for the day and in turn this allowed for this sealant to fully cure overnight. The next morning I applied 2 light coats of Zymol Carbon and was completely impressed with how black, deep and shiny the finish appeared in day light.
1Z/Zymol stacker:
Interior received a very quick wipe down/vacuum and all the inner/outer weather-stripping seals were coated with 1Z Gummi Pfledge. The roof panel was removed so to gain access to clean/protect inner seals.
Engine just was rinsed and wiped down.
Unfortunately, there was hit & miss cloud patches (see clouds in reflections) and full sun shots per were “prime pickins”.
Old 06-04-08, 07:28   #3 (permalink)
evenflow's Avatar
evenflow is offline
Amazing write up and before and afters. That car was REALLY hacked up. Nice correction
Old 06-04-08, 07:36   #4 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
looks great
one question ........ why is you kid playing with your wool pad?
Old 06-04-08, 07:41   #5 (permalink)
Kyny is offline
Hi, David
Amazing Work like always.
Elkin
Zymol
Old 06-04-08, 07:44   #6 (permalink)
lt1_man's Avatar
lt1_man is offline
wow good turn around I can't believe some of those "professional" detail places that just swirl the paint even worse then it was to begin with. That black looked very deep in the final pictures. Also how did you like the 3M product, has it easy to buff off?
-Brandon
Brandon Hey
1995 Firebird Formula (sold)
1989 BMW 325i Alpine White Daily Driver
1989 BMW 325i Spec E30 race car
Old 06-04-08, 07:45   #7 (permalink)
AJ Auto Detail, LLC
ajnavo61490 is offline
Contact: Send a message via AIM to ajnavo61490
nice work, man
AJ Auto Detail, LLC
Old 06-04-08, 07:45   #8 (permalink)
OCDer for life
gators241987's Avatar
gators241987 is offline
I dont comment here often, but great job. You did an awesome job. I have yet to use the 1Z glanz wax, any other sealant its comparable to?
Old 06-04-08, 07:59   #9 (permalink)
Paint time machine
shine's Avatar
shine is offline
Great job. It's a shame what those "professionals" can do, but it keeps you in business.
Old 06-04-08, 07:59   #10 (permalink)
joyriiide1113's Avatar
joyriiide1113 is offline
Good job David. Seeing you buff in person, I have no doubt the finish was spectacular.
Old 06-04-08, 08:11   #11 (permalink)
Hi.I are Paul.
dmw2692004's Avatar
dmw2692004 is offline
Contact: Send a message via AIM to dmw2692004
great correction! sounded like the car wash "technician" really knew what he was talking about ...not.
Owner
Old 06-04-08, 08:12   #12 (permalink)
Legacy99's Avatar
Legacy99 is offline
Terrific turn around, excellent write up and photos.
