03-26-08, 07:12
Rickrack79@hotmail.com
RickRack is offline
Acura TL in Nighthawk Black Pearl Revived!
Rick Nelson
Unique Car Care (owner)
Wakefield, MA
03-26-08, 07:13
RickRack is offline
Re: Acura TL in Nighthawk Black Pearl Revived!
Rick Nelson
Wakefield, MA
03-26-08, 07:14
RickRack is offline
Rick Nelson
Wakefield, MA
03-26-08, 07:15
RickRack is offline
Rick Nelson
Wakefield, MA
03-26-08, 07:16
RickRack is offline
I carefully inspected the paintwork and noted any imperfections and areas of concern. The paint thickness was measured on every body panel using a paint thickness gauge to see what the total coating thickness was before any aggressive polishing was performed.
^^ As you can see, the paint was EXTREMELY thin. I got readings that ranged from 5.6 mils to as low as 3.9 mils in a few areas.
My goal was to make the paint as perfect as possible without sacrificing an unsafe amount of the vehicles clearcoat. I started by using the least aggressive approach to meet the desired results and slowly moved up to a more aggressive product that worked well enough at removing the imperfections and would not harm the clearcoat. Wetsanding was not an option, so I did the best I could with what I had to work with.
Paint thickness was measured periodically throughout the polishing process and on completion to monitor how much clear was removed. Most of the panels did not show any loss in paint thickness, besides a small area on one of the panels that required a wool pad to remove some more serious defects. This particular area was reading 5.2 mils before any polishing and read 5.1 mils after, so a total of .1 mil was removed. The paint meter does vary slightly, so it is impossible to measure exactly how much was removed. I use it more as a guide than anything, so I always use extreme caution when doing heavy correction work.
I was able to remove a considerable amount of the defects and was quite pleased with the results after pulling it outside in the sun. Not 100% perfect, but definitely a huge improvement from how it looked when it arrived.
I decided to take some pictures of the car before the sun went down. I was not quite finished, but the pics below give you an idea of how well it came out considering the circumstances.
Rick Nelson
Wakefield, MA
03-26-08, 07:17
RickRack is offline
Rick Nelson
Wakefield, MA
03-26-08, 07:18
RickRack is offline
After taking the pics, I pulled it back in the garage for the finishing touches (exhaust tips, windows, removed compound/polish from all the crevices, etc.).
The paint gave me a considerable amount of trouble due to excessive outgasing. I tried a variety of different products and pads which were all acting very finicky. My guess is that some sort of silicone product was deeply embedded in the paint which was causing these issues.
~My total process ended up being:
Hand wash exterior
All tires, wheels and wheel wells cleaned
Clay bar treatment to complete exterior
Rewashed exterior
Solvent wipedown
Measure paint thickness
Masked all vinyl/rubber moldings, gaskets, etc. with tape
Spot-buffed a small area (heavily scratched) with M105 using a yellow Edge 6-inch wool pad
Buffed complete exterior with M105/Ultrafina mix at low rpm’s using a yellow Meguiars Solo foam pad for several sets of passes until I removed a satisfactory amount of heavy defects.
Buffed complete exterior with Ultrafina using a gray CCS pad at 1800 rpm for the first set of passes and a blue CCS pad at 1400 rpm for the second set of passes.
Wiped down paint surfaces with solvent to remove any oils, silicone, wax, etc. that may have been left behind from the compounds/polishes
Viewed the paint under full sunlight and artificial xenon light to ensure that there were as little paint imperfections as possible
A base coat of Finish Kare’s 1000P was applied by hand
A top coat of Pinnacle Souveran was applied by hand
Tires and wheel wells dressed with Super Blue dressing
Detailed logos & trim and removed excess wax/residue from cracks, crevices and jambs
Final wipedown using Optimum Instant Detailer and Gloss Enhancer
Rick Nelson
Wakefield, MA
03-26-08, 07:22
Afinn4 is offline
wow nice job on saving that car!
03-26-08, 07:25
Afinn4 is offline
when you clayed the entire car how did you keep the clay bar clean of all the dirt that was picked up??
03-26-08, 07:34
RickRack is offline
Thanks!
I actually used up two bars for the car
I used a purple (agressive) Kar Kraft clay far for the heavies
and went over the car a second time with green (medium) Kar Kraft clay
Rick Nelson
Wakefield, MA
03-26-08, 07:38
King of Gloss!
rydawg is offline
WOW! That thing was quite past it's point of correction, you really must have worked hard on this one.
Amazing job at bringing it back and giving a new glossy look. Looks like a different car.
Ryan Blanchette
03-26-08, 07:39
mattgg11 is offline
I've got one question I can't seem to figure out. You state...
"The paint thickness was measured on every body panel using a paint thickness gauge to ensure that a significant amount of clear was present before any aggressive polishing was performed."
I assume that a paint thickness gauge measures the total amount of "paint" on a body panel, which would include primer, color, and clear coats.
So if you get a reading of 5.1 mills, how do you know how much of that is clear coat? The primer and color coats could be 5 mills thick and the clear coat only 0.1 mills thick.
Explain how you "ensure a significant amount of CLEAR is present" with a PTG.
