Old 03-24-08, 03:18   #1 (permalink)
dsms's Avatar
dsms is online now
dsms detail - black 330xi
2006 330xi mostly kept outside and never been detailed.
Before shots
A little fender bender, there was some paint transfer that came off easy when polishing, couldnt do much about the deep scratches though
After a quick rinse I foamed the car with Z7 and let it dwell for a couple minutes. Then used the 2 bucket and mitts while using the foam gun w/Z7 also.
First time using the boars hair extension brush, very soft.
I worked on the wheels first before everything else they were a mess. Tons of brake dust and road tar.
Started cleaning w/ Megs safe-D cut 3:1, let it dwell for a while and used a couple brake dust remover sticks. After that came the EZ detail brush to get behind the spokes.
Cleaned the face and between spokes with theh swissvax brush(new favorite wheel tool)
Re-rinsed and applied P21s gel and let it sit for about 10minutes before doing a final scrub with the lambswool brush. Went back later with autoglym intensive tar remover to remove the remaining tar but very little came off.
The final result(tires dressed with CG extreme wet dressing)
I used #00 steel wool on the exhaust followed by Megs nxt metal polish
Old 03-24-08, 03:19   #2 (permalink)
dsms's Avatar
dsms is online now
Re: dsms detail - black 330xi
After drying with CG miracle dryer I clayed the car with pinnacle ultra poly using Adams QD as lube the gave it another wipedown using PB S&W
Checked for swirls in sunlight before bringing it inside
Started correction with the Flex and Megs M105 compund with a LC 5.5ccs pad(later switched to the flat ones and the purple wool)
Before and afters
After trunk 50/50
Old 03-24-08, 03:21   #3 (permalink)
dsms's Avatar
dsms is online now
M105 finished down very nicely, little suprising for such a heavy compund. After correction came an IPA wipedown before Final polish which was 106ff w/ green ccs pad. The car was wipedown again and then I applied 3 coats of Z5pro ZFX'd (cured 20mins between each coat) applyed by CG MF applicator in straight lines followed by Z-CS and Z8
Some before and afters
Lights just got the 106ff treatment with a white pad
Carpets were vaccumed and scrubbed with 303 cleaner cut 10:1 and Megs APC+
Before
(the one that got away...I went back and redid that last stripe)
All the leather was cleaned with Leather masters strong cleaner and conditioned with Z10
Door shuts got Z-AIO and all lower plastic panels were cleaned with 1Z Plastik-Reiniger and magic eraser, rest of the interior recieved 1Z cockpit premium. Glass was cleaned with IG and recieved Z-CS. All exterior chrome trim was polished with Z-AIO and plastic trim was topped with CG extreme wet dressing.
Some final shots
Old 03-24-08, 03:23   #4 (permalink)
kkjv1's Avatar
kkjv1 is offline
Lookin good Dsms. How was the LC Purple compared to the orange pad in cutting power?
Did you notice any hazing, hologram with the LC Purple / Megs 105 combo? Did you use a 2nd finishing step?
Thanks!
Kent
2002 530i Sterling Grau
1992 525i Schwarz
Old 03-24-08, 04:49   #5 (permalink)
Sludge's Avatar
Sludge is offline
Very nice job. Looks like a black car should. Great turnaround.
Old 03-24-08, 05:24   #6 (permalink)
oneshare325's Avatar
oneshare325 is offline
Are you an e90post"er" too???
Old 03-24-08, 05:27   #7 (permalink)
LiCelsior is offline
wow looks amazing! good job dsms.
Old 03-24-08, 07:16   #8 (permalink)
dsms's Avatar
dsms is online now
Thanks!
The purple wool I only used on the trunk basically to test it out. I was pretty impressed, it cut very nicely and really left no holograms either, I spurred the pad a few times though to prevent any gumming up. I finished the trunk same way as I did the rest of the car with 106ff and a green ccs. I went with green because its both a polishing pad and a finishing pad but the way M105 finishes down you really dont need a 3rd step in bewteen correction and finishing. Any minor swirls and marring M105 left behind 106ff took right out. The lights only got 106 btw.
Old 03-24-08, 07:28   #9 (permalink)
truzoom's Avatar
truzoom is offline
Excellent work! Great writeup and pics as well.
Old 03-25-08, 07:04   #10 (permalink)
AZ Ferrari Man's Avatar
AZ Ferrari Man is offline
Great job! What speed were you using with the Flex? You used the Flex Random Orbit correct and not the Rotary...?
"Treat every car as if it was your own"
-Every Detailer
Old 03-26-08, 01:44   #11 (permalink)
dsms's Avatar
dsms is online now
3401, random orbital. With the M105 I spead on 1 and went to 6 straight away, with the 106ff I spread at 1 and moved to 4 for the first minute and then moved up to 6.
Old 03-26-08, 06:30   #12 (permalink)
P1et is offline
Some really fantastic work, especially impressed with the before and afters on the wheels!!!
